Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 07-05-2008, 18:01   #1 (permalink)
sameer918's Avatar
Member: 754208
Thanks Meter: 67
Network problems in China Mobiles..
Mostly china mobiles are coming for network cases. Emergency, Or tower is full but call failed. Set is fresh. What to do?
The Following User Says Thank You to sameer918 For This Useful Post:
Old 07-05-2008, 18:12   #2 (permalink)
Member: 806752
Thanks Meter: 44
china mobile
china mobile me 1 bhi network kam nahi karta he to kya karu
Old 07-06-2008, 08:43   #3 (permalink)
sameer918's Avatar
Member: 754208
Thanks Meter: 67
Network problem
just heat up network ic
Old 01-08-2011, 13:17   #4 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 957
check imei may be only one imei on the screen now you need to rewrite both imei your problem will go 80% and 20% cases are mostly in M3, M1 dual battery type phone i have seen in some cases mobile work 100% at supply at 4.5 volts but one battery showing emergency and some cases on smal battery work good and on big battery same like first emergency. this problem from power section may be any resistance has lost its value. i am still searching. it seems problem comes from dual battery switching system.
can some one point out dual battery switching system area or have any diagram for this?
thanks
Old 04-27-2011, 11:08   #5 (permalink)
Member: 1450499
Thanks Meter: 3
yaar dont know but these things really *****
Old 04-27-2011, 11:10   #6 (permalink)
Member: 1450499
Thanks Meter: 3
GOOGLE GEO..... Search may be you can get some
Old 04-27-2011, 16:57   #7 (permalink)
GPGDragon Help's Avatar
Member: 1428349
Sonork: 100.1597111
Thanks Meter: 13,139
1.the mobile IMEI no ok,need change it with the dragon box
2.is MTK 6235 or 6253,after format this promble come
like this you can use the dragon box read back the working mobile NV and flash to bad mobile
3,if i no have the NV i can use the inram boot flash full flash file to mobile
Old 04-30-2011, 13:54   #8 (permalink)
Member: 1517589
no natwork u808 g five
pzz
sms
9370012067
Old 09-15-2011, 15:11   #9 (permalink)
kapilpanday's Avatar
Member: 951882
Thanks Meter: 323
network fail problem not solved ?
Old 09-25-2011, 11:20   #10 (permalink)
Member: 1386905
Sonork: 100.1620543
Thanks Meter: 8
e to kya karusir merav yei problem hai!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 10-25-2014, 12:14   #11 (permalink)
Member: 1923044
when search network in manual mode its showing network search failed what is problem
Old 10-30-2014, 13:29   #12 (permalink)
Member: 2281088
version info sum..[MMI]: CoolMMI (-1)-r4294967295
[BUILD TIME]: 20140814Thu1148
[Release Verno]:LC66_LUHU_Lcd7735s.68116_CAM 6123_ESPP_V0.0.6
BV5_P44_20130403[Lcd ID]: st7735 cptJYF
So,sir this is the phone info after dialing *#8375#..I bought this phone from online it was labelled as LAND RONER its both IMEIs are same when i put sims(indian) it does not access network and always in "EMERGENCY" showing..i connect via USB but only MASS STORAGE option is avilable....please tell me what is the problem and how can i fix it?Thanks.
Plz Help Inset Sim in china mobile yrgant brain00000 Chinese Models & Cloned Phones 7 11-10-2010 17:36
Flash write error in china mobile umesh garg Infinity-Box 10 05-10-2010 17:27
how to check model in china mobile if not slip in back of battery mohd.asim Chinese Models & Cloned Phones 1 06-20-2009 13:13
can i add farsi in china mobile Mohsin-* Infinity-Box 4 06-07-2008 15:47
Page generated in 0.22206 seconds with 10 queries
