Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
07-05-2008, 18:01 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 754208 Status: Offline Thanks Meter: 67 | Network problems in China Mobiles.. |
The Following User Says Thank You to sameer918 For This Useful Post: |
01-08-2011, 13:17 | #4 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: My Computer
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | Quote:
check imei may be only one imei on the screen now you need to rewrite both imei your problem will go 80% and 20% cases are mostly in M3, M1 dual battery type phone i have seen in some cases mobile work 100% at supply at 4.5 volts but one battery showing emergency and some cases on smal battery work good and on big battery same like first emergency. this problem from power section may be any resistance has lost its value. i am still searching. it seems problem comes from dual battery switching system. can some one point out dual battery switching system area or have any diagram for this? thanks | |
04-27-2011, 16:57 | #7 (permalink) |
No Life Poster Join Date: Oct 2010 Location: china Age: 35
Member: 1428349 Status: Offline Sonork: 100.1597111 Thanks Meter: 13,139 | 1.the mobile IMEI no ok,need change it with the dragon box 2.is MTK 6235 or 6253,after format this promble come like this you can use the dragon box read back the working mobile NV and flash to bad mobile 3,if i no have the NV i can use the inram boot flash full flash file to mobile |
10-30-2014, 13:29 | #12 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2281088 Status: Offline Thanks Meter: 0 | version info sum..[MMI]: CoolMMI (-1)-r4294967295 [BUILD TIME]: 20140814Thu1148 [Release Verno]:LC66_LUHU_Lcd7735s.68116_CAM 6123_ESPP_V0.0.6 BV5_P44_20130403[Lcd ID]: st7735 cptJYF So,sir this is the phone info after dialing *#8375#..I bought this phone from online it was labelled as LAND RONER its both IMEIs are same when i put sims(indian) it does not access network and always in "EMERGENCY" showing..i connect via USB but only MASS STORAGE option is avilable....please tell me what is the problem and how can i fix it?Thanks. |
Plz Help Inset Sim in china mobile yrgant | brain00000 | Chinese Models & Cloned Phones | 7 | 11-10-2010 17:36 |
Flash write error in china mobile | umesh garg | Infinity-Box | 10 | 05-10-2010 17:27 |
how to check model in china mobile if not slip in back of battery | mohd.asim | Chinese Models & Cloned Phones | 1 | 06-20-2009 13:13 |
can i add farsi in china mobile | Mohsin-* | Infinity-Box | 4 | 06-07-2008 15:47 |
