Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 07-01-2008, 06:40   #1 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 23,897
new problem apper in china sets
in a few days new problem apper in china set imei is 135688***xx ande when u put this sim in set set show u sim card registerion failed.... any one know about this problem ....only ufone sim working fine this these sets ....
Old 07-01-2008, 07:12   #2 (permalink)
Member: 802887
Thanks Meter: 6
you have to download chinese "imei changer"(search) conect the phone(on) to the usb, then load the soft, search for com port 30 o 31(this new com should appear after you connect the phone, if you want you can first load the soft(before conecting the phone), look at com ports, then exit) with the phone conected set the baudrate, write the imei that the phone has in the sticker below the battery and change the Imei...
You should check the engineering mode(search for your code) of your phone and in Devices===>UART===>PS change to USB so you can use the USB to change IMEI.
Old 07-01-2008, 07:14   #3 (permalink)
Member: 802887
Thanks Meter: 6
I have a problem, may be you can help....
I have an IFOE P168+ (CECT P168+) with the MT6225 Chip, dual sim. I have flashing software, imei changer, MTK Format, and so on... Have the USB Standard Cable and one Serial made by me.
The problem is that i made a mistake: I changed PS to USB (instead of UART) and entered a dangerous code: *#6810# that DISABLED THE ENGINEERING MENU and several other codes. The question is:
HOW CAN I CHANGE THE PS TO UART without entering the engineering mode? Is there a way to do that? To change to UART or to revert this bad code so i can use the Engineering menu.
I've reseted the phone, entered all the codes i have found but nothing happened, and searched the forum for two days.
If you could help me i would be very glad, so i continue investigating ways to modify my phone. Thanks in advance.
Regards, Robert.
Old 07-01-2008, 07:19   #4 (permalink)
Member: 399832
ok i test it set is working fine just change imei .....thanks
Old 07-01-2008, 07:22   #5 (permalink)
GsmEasy's Avatar
Member: 608359
Sonork: 100.1576815
Thanks Meter: 6,309
see here problem and solution
http:///vbb/showthread.php?t=558654
Old 07-01-2008, 07:27   #6 (permalink)
Member: 802887
Thanks Meter: 6
Hi, can you tell me a solution to my problem? To re-enable engineering mode on the phone....
Thank you...
***New resseller updates in china 14-3-10*** DITS DISTRIBUTER & RESELLER SECTION 1 03-15-2010 10:53
how to bilt imei number in china set bgreat Chinese Models & Cloned Phones 2 11-27-2009 14:31
how to fing problem is in software or hardware in china sets shahidali109 Chinese Models & Cloned Phones 1 04-07-2009 15:40
HOT HOT New problem 6020 in two phones rodrigo.gsm Nokia Hardware & Hardware Repair 8 10-24-2007 14:31
New OLD Fones in China gesundheit Chinese Models & Cloned Phones 0 10-23-2006 10:33
Page generated in 0.27768 seconds with 8 queries
