Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
10-23-2010, 12:52 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | NKTEL 2008 Audio Player Problem here is flashing log. ==== [10/23/2010 3:55:42 PM] ==== COM12 [VCP0] selected module v3.24 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware N96_ABROAD_PCB01_GPRS_MT6225_S00.N96_ABROAD_SPANS_ S5LCD_V2_3_6__w_eeprom.B0E.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:6003:000E status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.750BF7D9.[N96_ABROAD_PCB01_GPRS_MT6225_S00.N96_ABROAD_SPANS_ S5LCD_V2_3_1.BIN_151AEC82].rpl rom info detection finished device-id: 750BF7D9 rom info ver: 04 sw version: N96_ABROAD_PCB01_GPRS_MT6225_S00.N96_ABROAD_SPANS_ S5LCD_V2_3_1.BIN project-id: N96_ABROAD_SPANS_S5LCD_V2.3.1, 82EC1A15 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 96_ABROAD_PCB01_GPRS_MT6225_S00.N96_ABROAD_SPANS_S 5LCD_V2_3_1__system_log_750BF7D9_151AEC82_20101023-155623.B0X.bin Area: Firmware flash: 98000300000001:18E59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 96_ABROAD_PCB01_GPRS_MT6225_S00.N96_ABROAD_SPANS_S 5LCD_V2_3_1__system_log_750BF7D9_151AEC82_20101023-160644.B0X.bin Finished, time used: 10 min 58 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to alamgarh For This Useful Post: |
11-12-2010, 08:21 | #3 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Narayanganj
Member: 888599 Status: Offline Sonork: 100.1600952 Thanks Meter: 124 | I think its not software prob. Just Format the memory card and reload it. If Problem does not solved Go-- Memory Drive and open it then Tools--Folder option-view- show hidden files and folder check now it will show hidden files of memory card & delete mp3 list.log file or txt file. Finally put the memory to phone . restart and add music to music player from memory. It wil solve your prob. |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
