Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 05-18-2009, 04:30   #1 (permalink)
ahmadge's Avatar
Member: 603971
Thanks Meter: 714
nokia 5330 pinout needed
i have china 5330 phone i want to flash it bcs my phone dead but i have no pinout for this mobile any one help pleaz 12 pin jack
The Following User Says Thank You to ahmadge For This Useful Post:
Old 10-31-2009, 08:02   #2 (permalink)
gsm-world's Avatar
Member: 582790
Thanks Meter: 378
COM8 [VCP0] selected
module v2.96
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
Do you want to make ffs/eeprom backup before format ?
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:7103:000B
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 01227E22202200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.14A33569.[JIA5310_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN_F255F89A].rpl
rom info detection finished
device-id: 14A33569
rom info protocol ver: 04
ver. sw 1: JIA5310_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN
ver. sw 2: MAUI.07A.W07.52.MP.V2, 9AF855F2
address offset: 00000000
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E40000
Detected ffs/eeprom address is non-standard: 00E40000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00E40000
detecting ffs/eeprom size...
ffs/eeprom size: 001C0000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E40000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
ffs formatting...
Finalization Done
pinouts r near batery terminals.
here is diagram.
nokia n91 and nokia v300i pinout needed GOODNESS Infinity-Box 1 04-29-2008 21:26
Nokia N73 pinouts needed astana2007 Infinity-Box 1 03-04-2008 18:22
Nokia N66 pinout need urgent sadaf2706 Various 1 02-01-2008 00:44
nokia tp012 pinout need tenma Infinity-Box 2 01-13-2008 15:15
CHINESE NOKIA N78s PINOUT NEEDED maplegsm Infinity-Box 1 09-04-2007 13:45
Page generated in 0.26601 seconds with 9 queries
