Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
02-12-2011, 06:48 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 449617 Status: Offline Thanks Meter: 1,034 | Not allowed to dial in china mobile Not allowed to dial in china mobile I try to formate also full Flash & imei change But same Modle china M9 Any Goog Solution 4 this thanks |
The Following User Says Thank You to gsmstyle_1 For This Useful Post: |
02-12-2011, 06:52 | #2 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Asia Mobiles Repairing (Swabi)
Member: 435412 Status: Offline Sonork: 100.1608142 Thanks Meter: 289 | Still Same Problem Here I Have 4 Pcs... During Incoming Call all Keypad is Not Working |
The Following User Says Thank You to asia_gsm For This Useful Post: |
02-12-2011, 06:59 | #4 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: Mardan
Member: 897494 Status: Offline Sonork: 100.1581481 Thanks Meter: 1,102 | Quote:
Q75."not allowed to dial" problem with Cesim A9530 01. Make sure two SIMs are online with good coverage, WLAN switched off. 02. Press the "call"-button and type in *#9646633# 03. The phone shows "Engineer mode" with a menu of 10 different items. 04. Go to No. 10 "RF test tool", using the up/down button at the left side of the mobile. 05. Choose "GSM" 06. A message shows up "Wifi....blabla", just confirm with OK 07. Choose "Power Scan" 08. Select your local GSM frequency (in my case DSC 1800 for Germany) and press OK. 09. The mobile will freeze now, because its adjusting itself. Leave it like this for about 2-3 minutes and wait !!! 10. Connect your mobile via USB cable to a PC, DO NOT CONFIRM any connection mode at your mobile, just and ONLY connect the cable!!! 11. Press the Menu button (second from the left, the one with the seven small dots on it) until you you the main menu with the 12 icons on the display. 12. Go to "Settings" --> "Network Setup" --> "SIM1 network setup" 13. Go to "Preferred mode" and choose "GSM preferred" or "GSM only" 14. The mobile will switch to your selection, but the message that it will stay on display. Do not press anything else, just wait for about 10 - 15 seconds. 15. Disconnect the USB cable from the phone, it will show you that it has switched to your selection. 16. Get back to main menu, switch off and restart the mobile --> DONE. | |
The Following User Says Thank You to Gsm Mardan For This Useful Post: |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
