pls help reset usercode n70 chip skyworks i have vepro,box,spiderman box,i had scan pinout phone's but can't read code,or reset use code,please help. thank!:o |
try this code- *#3424# *#987*99# *#19740829# *#2004*#2004# *727793# also i do skywork by cpf-box, for me its working good, plz try. |
:*#987*99# or use CPFBOX2 read flash and make backup and then click password search tool. |
back side label "cect jr777i"(like n70 copy) front side label "Diamond" Cpu type "skyworks" it's 2*5 pin jeck............ RX=10,TX=5(searched by pinfinder) Problem - Restart with sim Now give the right solution...... |
first try to initializing/restore/write API (must backup first you old/current API) with a good api file, if still same, next try to flash |
Current Port:COM33 Waiting for phone's response,press the Power on the phone. Boot downloading...44% Communication failed! Waiting for phone's response,press the Power on the phone... Boot download finished! Flash Reading: Start Address: 0x1000000 Read Length: 0x1000000 Communication failed! Waiting for phone's response,press the Power on the phone... Boot download finished! Flash Reading: Start Address: 0x1000000 Read Length: 0x1000000 >>Communication failed! i have 2 phones 1 is on usercode and second is on silent mode when i select ring mode it automatacly revars on silent mode please post its solution thanx in advance |
which device u use? when read or write flash file, press and hold power button till start read. that means, when soft tell you to press power button for phone boot, press and hold, now its show you flash size, bootloder, hardware info etc than its start read flash 1%...50%...100% than when device start to read or show start 1% read, this time release power button or some seconds before. try plz. |
Current Port:COM33 Waiting for phone's response,press the Power on the phone. Boot downloading...44% Communication failed! Waiting for phone's response,press the Power on the phone... Boot download finished! Flash Reading: Start Address: 0x1000000 Read Length: 0x1000000 Communication failed! Waiting for phone's response,press the Power on the phone... Boot download finished! Flash Reading: Start Address: 0x1000000 Read Length: 0x1000000 >>Communication failed! |
are you try with battery and power supply both? if cable have vcc pin, not need any extra power to give on batt conn. if all is ok, than now check phone hardware. |
i have same set with same problem.pls help me moderator sir to solve my problem. i use spiderman and cpf dongle |
