Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
06-11-2013, 17:13 | #1 (permalink) |
Insane Poster Join Date: Jun 2013
Member: 1957367 Status: Offline Thanks Meter: 4 | spreadtrum samsung unknown brand too many patterns i have chinese based android samsung tab and its now locked at too many patterns i pressed vol - and power it shows up a test menu with no factory reset option so what can i do i installed the driver and tried to use the android tools to wipe the data but the program didnot recognize the phone |
06-11-2013, 18:09 | #4 (permalink) |
No Life Poster Join Date: Feb 2009 Location: Algeria-Cne Age: 47
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | what is written under battery?? and if you plug in USB cable on phone how PC detect it AS ANDROID DEVICE OR SPREADTRUM DEVICE??? |
06-12-2013, 16:41 | #9 (permalink) |
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | give a picture for your device (the two face) i was facing a dual sim tablet but realy it is too hard finding firmware for it really cant give you a big help until you provide the maximum informations about your tablet. good luck |
06-12-2013, 17:13 | #10 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Hello you have to add Vendor id in adb_usb.ini until you can not detect this type of device in adb . you can also use attached my file to replace it at %USERPROFILE%\.android don't forget to backup your existing. ps: wiping data is not safe and need root be careful. |
The Following User Says Thank You to stanner_austin For This Useful Post: |
06-12-2013, 20:35 | #11 (permalink) |
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | is this changing the connection mode between device and PC i mean instead of detecting phone as spreatrum it will be detected as android device???? or i am wrong |
06-13-2013, 08:47 | #12 (permalink) | |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Quote:
this will just fix adb shell error device not found issue. you must have spd driver installed and usb debugging on in phone. Regards, Chevli | |
06-13-2013, 12:49 | #13 (permalink) | |
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | Quote:
in this case only a recovery img on a flash using the aproprite firmware can help him. but this is really very hard to do. @ constantinexx for the first solution ( recovery image i mean) you can follow the link to xda developper forum use researche download to put recovery image in your tablet and try to get recovery menu if you successed to do it you will probably be able to wipe data. if no success you need a rom you can see here maybe you can find the right firmware one other question is it a copy of samsung tablet?? good luck and waiting for picture for your tablet | |
The Following User Says Thank You to adelkaha25 For This Useful Post: |
