is possible to format chinese phone only with usb cable? Hi all, I have a restart problem with my ZTC phone so I need to format it. Is possible to format only with usb cable and flash software? :confused: Thx all for attention. |
Regards |
Due To Limited Cable Availability In The Market, It Is Absolutly Inposicant... U Have To Simply Modify A Cable Or Get A Professional Box... U Can Simply Cut Any Serial Cable Direct To Pc And Locate Rx Tx And Gnd... Phone Has These Points On Pcb....... Although Not All..:d |
Thanks for your answer m8! Can you send me a scheme for this?? PS: My phone is CECT T689 |
Ok thx all for explanation. Do you know exact pinout about ZT321-1 (solar charge) ? |
1 Attachment(s) Quote:
bomba01 suit On you shell ver. 1,21 infinty support shel ver 1,22 ok.. |
u use mtk softwar and use 261 cabol pinout |
hallo sir helpe spidermaen exe plees use in ufs box or jaf box china mobile format and flash |
need help format eprom area with multi lite hello amit here, i have a hantel 6088, i tried connecting with multi lite, message comes hold on button then timeout.please guide the correct procedure and how to find pinout i used the normal cable which i use for charging , the same cable i found in multi lite cables |
what is the problem with "obayed_gsm" he is thanking everyone without any reason !! excess of everything is bad. |
china mobil format jaf or ufs box viwe metherte |
can we flash or format china phones using usb cable or serialport cable ? any idia? |
