GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Chinese Models & Cloned Phones (https://forum.gsmhosting.com/vbb/f457/)
-   -   re :nokia E75 chinese make (https://forum.gsmhosting.com/vbb/f457/re-nokia-e75-chinese-make-751130/)
ndugwaez 05-14-2009 09:16
guys can any one assist me with the flash file of this phone;)
regards
FasGsm 05-14-2009 10:37
Post ur phone orignall flash file version.
ndugwaez 05-14-2009 14:51
this is what it displays
module v2.78
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:C503:0004
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
Warning: probably flash chip is empty, erased, incorrectly flashed or damaged !
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
operation terminated by user
error: critical error#1 during ffs/eeprom size detection
error: can't detect ffs/eeprom address/size
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 112 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
modou 06-13-2009 21:10
module v2.78
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
115200
Set baud Done
What to do:
.damaged firmware
.damaged hardware
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
same problem now phone dead need full flash of this phone:(:(
Page generated in 0.12196 seconds with 6 queries
