Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 10-11-2016, 10:19   #1 (permalink)
Member: 2085676
Thanks Meter: 299
samsung clone s7 g930f no service
samsung clone mtk 6580 cpu no serice , i try change imei but same after change
The Following User Says Thank You to samicool88 For This Useful Post:
Old 10-11-2016, 10:35   #2 (permalink)
M - Soft's Avatar
Member: 2408771
Thanks Meter: 152
please Read Info In miracle Box and copy Logs Here
Old 10-11-2016, 10:52   #3 (permalink)
Member: 2085676
Thanks Meter: 299
Welcome to use Miracle Box
(World's First Fuzzy Logic Based Tool)
Update:16-01-09
Connected OK.
Fuzzy Logic Method is very safe and reliable !
Check Authentication...
Network connected error
1. Power Off Phone , Remove Battery, Insert Battery Back
2. Insert USB cable. In some cases Required Hold BootKey
3. Use Miracle Boot Key In cases Boot key not Find
4. Battery Should be Charged more then 50%
Open Port Err:
*** the Port be occupied.
Waiting for USB Port...
Set
Open Port Err:
Open Port Err:
Set Tinno S9320AE PreLoader USB VCOM (Android) (COM5)
Please Hold "ON" to connect with the phone...
Connected to Phone.
CPU: MT6580 SW:0000 Ver: CA00
Downloading Boot8 ...
EMMC Size: 0x01D2000000
Flash Type: EMMC
INT/EXT RAM Size: 0x0+0x0
Reading infr(EMMC)...
id:LMY47I test-keys
version:6.0.1
model:SM-G930F
brand:samsung
manufacturer:samsung
PROINFO BaseAddr:0x80000 Size:0x300000
NVRAM BaseAddr:0x380000 Size:0x500000
PROTECT1 BaseAddr:0x880000 Size:0xA00000
PROTECT2 BaseAddr:0x1280000 Size:0xA00000
SECCFG BaseAddr:0x1C80000 Size:0x40000
LK BaseAddr:0x1CC0000 Size:0x60000
BOOT BaseAddr:0x1D20000 Size:0x1000000
RECOVERY BaseAddr:0x2D20000 Size:0x1000000
PARA BaseAddr:0x3D20000 Size:0x80000
LOGO BaseAddr:0x3DA0000 Size:0x800000
EXPDB BaseAddr:0x45A0000 Size:0xA00000
FRP BaseAddr:0x4FA0000 Size:0x100000
NVDATA BaseAddr:0x50A0000 Size:0x2000000
METADATA BaseAddr:0x70A0000 Size:0x2760000
OEMKEYSTORE BaseAddr:0x9800000 Size:0x200000
SECRO BaseAddr:0x9A00000 Size:0x600000
KEYSTORE BaseAddr:0xA000000 Size:0x800000
SYSTEM BaseAddr:0xA800000 Size:0x60000000
CACHE BaseAddr:0x6A800000 Size:0x10000000
USERDATA BaseAddr:0x7A800000 Size:0x156780000
FLASHINFO BaseAddr:0x1D0F80000 Size:0x1000000
>>Done.
Old 10-11-2016, 11:40   #4 (permalink)
M - Soft's Avatar
Member: 2408771
Thanks Meter: 152
Info
Flash Type: EMMC
INT/EXT RAM Size: 0x20000/0x40000000
BT_ADDR:000046658001
WIFI MAC:000000000000
IMEI1:35535707FFFFFFF
IMEI2:FFFFFFFFFFFFFFF
id:LMY47I test-keys
version:6.0.1
model:SM-G930F
brand:samsung
Link Here
Please Read Backup Before Flashing
B.r
M - Soft
Old 10-12-2016, 07:00   #5 (permalink)
Member: 2085676
Thanks Meter: 299
what i do bro , flashing?
Old 04-13-2017, 13:05   #6 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
Originally Posted by M - Soft View Post
Info
Flash Type: EMMC
id:LMY47I test-keys
version:6.0.1
model:SM-G930F
brand:samsung
Link Here
B.r
M - Soft
hi,
what's is your backup info plz ?
i wanna fix mine, it's virus infected, this is my phone info:
Wait for phone...
Phone found! [ 20 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 11010030303447453001CC5262901207
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x11 , OEM : 0100
[eMMC] : FLASH_INF : [TOSHIBA] , 0EG40
[eMMC] : FLASH_CID : 11010030303447453001CC5262901207
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID    : 0x6ADE9514A6305D642BBDB1F4F72CEE23
INT RAM    : 0x00020000
EXT RAM    : 0x20000000 [512 MiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand     : alps
ProdName  : full_best6580_weg_l
ProdModel : best6580_weg_l
Device    : best6580_weg_l
AndroidVer: 5.1
MTKxCPU   : MT6580
MTKxPRJ   : ALPS.L1.MP6.V2.19_BEST6580.WEG.L
MODEM :
BaseBand  : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V6_1_wg_n
EXTRA :
LCD : Not info available :(
LCD Res : 1280x720
TOUCH [0] : GT1XX
CAM [0] : ov9762_mipi_raw
CAM [1] : ov5647_mipi_raw
CAM [2] : ov9762sub_mipi_raw
MODEM : 889_capid
LOCALE : en_US zh_CN zh_TW es_ES bn_BD pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES
Done!
Elapsed: 00:00:11
Reconnect Power/Cable!
i want to know if your file in compatible with my phone.
thanks you.
Old 04-15-2017, 13:46   #7 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
Info
Flash Type: EMMC
id:LMY47I test-keys
version:6.0.1
model:SM-G930F
brand:samsung
Link Here
B.r
M - Soft
there is no scatter.txt in the file you gave ! how can you flash it ?
Old 04-15-2017, 13:58   #8 (permalink)
Member: 2333595
Sonork: wwwsonork.com
Thanks Meter: 120
FIRST root your device in manually
second try MTK Droid Tool...https://androidmtk.com/download-mtk-droid-tool
after first time not done
try second time
your problem will solved
Page generated in 0.22073 seconds with 8 queries
