Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
04-23-2016, 09:50 | #1 (permalink) |
Junior Member Join Date: Apr 2016
Member: 2563467 Status: Offline Thanks Meter: 0 | Samsung Grand Neo GT-I9060 (MediaTek MT6575) Flash Problem I have Samsung Grand Neo GT-I9060 It wasn't work correctlly so I just downloaded Flash file and flashed it with SP Flash if i use any downloaded file with its scatter file i get error MTP Changed, It must be downloaded and if i use my Scatter file with any file it flash it without errors. so I opend MTKDroiedTools and get scatter file for my device and then used it to flash downloaded file flash complete without errors but my device doesn't boot any more this is what i get when turn it on (Sorry i can't post photos because i'm new so please just add 'com' after 'tinypic.' and delete spaces to get the right link) i68. tinypic./3509kd1. jpg and when turn it off and charching get this i64. tinypic./29w1rih. jpg on the back of device is show it's GT-I9060 i66. tinypic./2vhz09s. jpg but when check it with MTKDroiedTools it show this Quote: Hardware : MT6575 Model : GT-I9082 Build number : ALPS. JB. MP. V1. 16 Build date UTC : 20151106-003404 Android v : 4. 2. 2 Baseband v: MAUI. 11AMD. W12. 22. SP. V23, 2014/11/29 16:46 I tried to flash it with option Format All + Download but it give me error Quote: S_DA_HAND_FLASH_NOT_FOUND I tried it with Meta Driver Mode give same Error I Downloaded many files all give same erros and i don't know what to do now It's my friend phone and he wanted me to fix it but i just bricked it. I hope will find help to get it work again Thank you |
04-23-2016, 10:04 | #2 (permalink) |
Moderator Join Date: Nov 2009 Location: Italia Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,105 | Your Firmware Not As Same Fast Read Info By Professional Tools Than Find That Correct Firmware Which One Need For Your Set After Try With That Right Firmware With Flash Hopefully Your Problem Willbe Solved
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
04-23-2016, 10:20 | #3 (permalink) | |
Member: 2563467 Status: Offline Thanks Meter: 0 | Quote:
It's first time i work with MediaTek phones. How can i find the correct Firmware and what tools should i use? and now it's dead phone only can use it with SP Flash Tool. | |
04-23-2016, 23:56 | #4 (permalink) |
Member: 2563467 Status: Offline Thanks Meter: 0 | After many tests now it's running but screen is black, white, coloured vertical bars, I hope it's now easier to fix? (Please remove spaces to get right link) http : //sendvid . com/x3lnu0s0[/url] |
04-24-2016, 13:23 | #5 (permalink) |
Member: 2563467 Status: Offline Thanks Meter: 0 | More Info Now I just made Screenshots for mobile (without see anything just guess everything position and tab it) I noticed that when I go to system settings screen goes horizontally but when go to main menu goes normal I remember system properties and now I'm sure the system is exactly same as original so where is the problem? (Please remove spaces from the links) i63. tinypic . com /15oc684. jpg i64. tinypic . com /2lm2jd3. jpg i65. tinypic . com /2lc72n4. jpg |
