Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
10-02-2012, 10:45 | #1 (permalink) |
Junior Member Join Date: Oct 2003 Location: newcastle upon tyne Age: 63
Member: 42900 Status: Offline Thanks Meter: 2 | samsung s3 clone gt-i9300 but cannot i have all the settings but one in the list below item 5 i cannot find on phone any help please 1. Tap Apps 2. Tap Settings 3. Tap More settings 4. Tap Mobile networks 5. Make sure that Use packet data box has a tick in it (tap box to change) 6. Tap Access Point Names 7. Tap the Menu soft key 8. Tap New APN 9. Tap Name and enter O2 Mobile Web then tap OK 10. Tap APN and enter mobile.o2.co.uk then tap OK 11. Leave Proxy as Not set 12. Leave Port as Not set 13. Tap Username and enter o2web then tap OK 14. Tap Password and enter password then tap OK 15. Leave Server as Not set 16. Leave MMSC as Not set 17. Leave MMS proxy as Not set 18. Leave MMS port as Not set 19. Tap MCC and enter 234 then tap OK 20. Tap MNC and enter 10 then tap OK 21. Tap Authentication type and tap PAP 22. Tap APN type and and enter default,supl then tap OK 23. Leave APN protocol as IPv4 24. Leave Enable/disable APN as ticked 25. Leave Bearer as Unspecified 26. Tap the Menu soft key 27. Tap Save 28. Tap the circle next to the new profile so a green dot appears in it 29. Press the Back key four times to return to the main menu. |
10-02-2012, 15:26 | #2 (permalink) | |
Moderator Join Date: Feb 2006 Location: Bangladesh & Bahrain
Member: 233205 Status: Offline Thanks Meter: 5,014 | Quote:
if no.5 menu item is messing then u would need to reset your phone, hope it will help u back this setting. | |
