Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 05-20-2008, 15:07   #16 (permalink)
Member: 95476
Thanks Meter: 185
red another full flash seme model phone and fla**** in your phone ok)))))))))))))))
just red full flash from same model phone and writ in your phone. for same flash in support aria???..............
Old 05-20-2008, 15:07   #17 (permalink)
Member: 95476
Thanks Meter: 185
this method tested be me ok
Old 05-21-2008, 05:54   #18 (permalink)
Member: 77549
Sonork: 100.89357
Thanks Meter: 11
this setting is working,thank you very much sir.
The Following User Says Thank You to jobykjoseph For This Useful Post:
Old 05-22-2008, 10:42   #19 (permalink)
Member: 525482
Thanks Meter: 21
thax dear this code is working and tested by me ..........
Old 05-22-2008, 14:18   #20 (permalink)
Member: 701311
Thanks Meter: 55
I tested with sets , the above said method is working fine. thanks
Old 05-28-2008, 09:29   #21 (permalink)
rkinfo_imran's Avatar
Member: 548824
Thanks Meter: 13
just backup eeprom file from working mobile and write back to the phone
and enjoy
tested on 12 phones working 100000000000000%
Old 05-29-2008, 02:29   #22 (permalink)
Member: 185776
Thanks Meter: 73
After resetting camera error now set shows error instead of insert simcard?
Old 05-29-2008, 13:49   #23 (permalink)
Member: 191089
Thanks Meter: 8
thanks nice jobbbbbbbbbbbbbbbbbbbbbbbbbbbbb
Old 05-29-2008, 14:11   #24 (permalink)
Abussabah's Avatar
Member: 412813
Sonork: 100.1594692
Thanks Meter: 353
enter *### and select "sensor option" activate back camera
Old 05-30-2008, 08:15   #25 (permalink)
Member: 667112
Thanks Meter: 8
thanks for this good solution
Old 05-30-2008, 08:27   #26 (permalink)
KUMARANSUGUMAR's Avatar
Member: 726340
Sonork: 100.1624264
Thanks Meter: 86
thank you.i will test it
Old 05-30-2008, 09:39   #27 (permalink)
smartengghelp's Avatar
Member: 740993
Thanks Meter: 75
Wink
Originally Posted by vijeeshkannur View Post
the Big Solution
No Need To Flash Or Format The Fone For "camera Module Not Ready" Complaint
Just Do These Steps And U'll Sort Out Your Problem
Just Dial *### And U R On Factory Mode Section
Now Click On Select Type Sensor
Choose Gekewei And Press Ok.
Now U R Ready To Use Camera
I Chkd In Many Sets Pls Try And Post Replies
Br.vijeesh
Thx
Thanks Brother This Solution Is Also Working But Plz Keep In Mind Camera Modle Not Ready Is Also Due To Hardware Failure But This This This Solution Works ............
Old 05-30-2008, 12:11   #28 (permalink)
Member: 652513
Thanks Meter: 30
Great !!
I returned more than 50 phones with same problem,
Thanks for solution.
Will test and reply here.
Old 06-03-2008, 09:49   #29 (permalink)
Member: 704979
Thanks Meter: 14
the big solution
no need to flash or format the fone for "camera module not ready" complaint
just do these steps and u'll sort out your problem
just dial *### and u r on factory mode section
now click on select type sensor
choose gekewei and press ok.
now u r ready to use camera
I chkd in many sets pls try and post replies
br.VIJEESH
thx
thanku so much sir nice job
The Following User Says Thank You to mobile maker For This Useful Post:
Old 06-03-2008, 09:53   #30 (permalink)
Member: 782918
Thanks Meter: 3
camra mo
its cod *### then last option slect chang up key
Sigmatel S400 camera module not ready .:SARCAR:. Chinese Models & Cloned Phones 0 09-23-2009 11:01
Sigmatel s3+ camera module not ready shivamobiles Chinese Models & Cloned Phones 4 09-30-2008 17:56
Sigmatel s3 camera module not ready,Hot Solution mobileunlockerz Chinese Models & Cloned Phones 7 09-03-2008 10:29
sigmatel s3 camera madule not ready salution kisna Chinese Models & Cloned Phones 6 07-28-2008 12:34
Sigmatel S3 Camera module Not ready . amol_sm Infinity-Box 6 05-27-2008 17:04
Page generated in 0.21220 seconds with 9 queries
