Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 09-12-2008, 17:21   #1 (permalink)
Member: 474118
Sonork: 100.1620319
Thanks Meter: 20
sigmatel s90
sigmatel s90 flightmode solution
Old 09-12-2008, 18:32   #2 (permalink)
Member: 693055
Thanks Meter: 14
10000000000% tested
3 Fomatting according to flash's content.
16M: Start Addr:0x00E50000; Length:0x001A0000
If the phone still cannot be powered on,then try the following adderss.
Start Addr:0x00E00000; Length:0x00200000
Old 09-15-2008, 12:58   #3 (permalink)
Chandreshswami's Avatar
Member: 370998
Sonork: 100.1582579
Thanks Meter: 218
Solved by formatting
COM6 [VCP0] selected
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:A003:0002
Connecting, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: S90_TOSHIBA_MP_V003
Version: S90_V1.0_HW
detecting structure #2...
5 11 done
67 byte(s) read
imei: 35756900011962
connection Ok
building list...
done
items to clear: 157
warning: wrong packet cs
157 of 157 items cleared
building list...
done
0 items remains
Finished, time used: 20 sec
Remove/Install battery now !
The Following User Says Thank You to Chandreshswami For This Useful Post:
Old 09-19-2008, 16:48   #4 (permalink)
Member: 847570
Sonork: aaru.ganesh
i have sigmatel s90 ,i tried all type of video formats using xilli softconveters still it is showing invalid video format pls send some tips
Old 09-19-2008, 17:01   #5 (permalink)
Member: 59185
Sonork: 100.1593175
Thanks Meter: 4,882
u can also try this one bro
sigmatel s90 flight mode
with out sim type*#3646633#
then you wil get eng menu
choose option 5 misc
then choose option 6 assert testing
now menu will open
then select dual mode
NOW YOUR S90 WILL OK
The Following 7 Users Say Thank You to lalitjsraks For This Useful Post:
Old 09-26-2008, 11:20   #6 (permalink)
Member: 474118
Sonork: 100.1620319
Thanks Meter: 20
thanks brother
thanks thankyou
Old 09-27-2008, 15:38   #7 (permalink)
Member: 350571
Thanks Meter: 896
now menu will open
this is right solution already i am tested
Old 10-08-2008, 09:45   #8 (permalink)
md jawad's Avatar
Member: 729723
Thanks Meter: 209
i tried dis *#3646633# but its not working it shows dont submit as a bug then display goes blank again d same problem flight mode any one help
Old 10-22-2008, 16:11   #9 (permalink)
Member: 317953
Thanks Meter: 4
sigmatel s90 pinout, or how will u clear welcome note for flight mode condition, but menu is not working
The Following User Says Thank You to shoukatali For This Useful Post:
Old 10-23-2008, 14:01   #10 (permalink)
Member: 761820
Sonork: 100.1594410
Thanks Meter: 30
After you do that your fone menu will be working... make sure you chage the mode from flight mode to duel sim card before puting your line
Regards Tanzania
The Following 2 Users Say Thank You to xtream 08 For This Useful Post:
Old 10-25-2008, 08:22   #11 (permalink)
murthyy's Avatar
Member: 265133
Thanks Meter: 155
this code *#3646633# works on some phone and doesnt work on some
Old 10-31-2008, 16:32   #12 (permalink)
Member: 567543
Thanks Meter: 60
u can format with spider man box 100% working
Old 11-11-2008, 11:55   #13 (permalink)
Member: 898023
Sonork: amol
dear sir ,
*#3646633# after using this code i have entered in eng. mode.in the option MISC. i select the fast sim ,then my cell turned off
what can i do now to power on them?
Old 12-25-2008, 13:27   #14 (permalink)
Member: 765926
Thanks Meter: 57
i also selected the fast sim option but my set went off and doesnt switch on now.my phone doest have a cable connector/damaged. how do i connect the universal cable of spider to pcb
Old 05-12-2009, 06:55   #15 (permalink)
.::sravan::.'s Avatar
Member: 958436
Sonork: 100.1593478
Thanks Meter: 39
slgmatel s90 pinouts
slgmatel s90 pinouts give me any one pls urgent
Sigmatel s90 fm flightmode cellbhai Infinity-Box 17 01-22-2009 19:56
sigmatel s90 forrmeting code ~:Sujyot GSM Zone:~ SpiderMan 3 10-09-2008 17:58
sigmatel s90 SATISH Infinity-Box 2 09-20-2008 10:28
sigmatel s90 dhiraj_telecom Chinese Models & Cloned Phones 1 09-12-2008 16:32
Sigmatel S90 SATISH Chinese Models & Cloned Phones 1 08-27-2008 14:29
Page generated in 0.38752 seconds with 8 queries
