Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 12-03-2011, 19:11   #1 (permalink)
Member: 1700109
Thanks Meter: 7
China Mobile Fake Charging,bad connect charging Solution 100% tested
[IMG]http://i1232.photobucket.com/albums/ff361/******/China%20Hardware/ChinaFakeCharging.jpg[/IMG]
Tested by me on few mobile
The Following 5 Users Say Thank You to smgsm For This Useful Post:
Old 12-03-2011, 19:14   #2 (permalink)
digicomm's Avatar
Member: 413149
Thanks Meter: 83
this is loade resistance. if long time charger connected to mobile then battery will b damage
Old 12-04-2011, 01:58   #3 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
what is value of resistance
u say 1R i think no any value in resistanse
Old 12-04-2011, 02:07   #4 (permalink)
markrhoden's Avatar
Member: 981198
Sonork: 100.1602386
Thanks Meter: 131
were you get 1R resistor? show image of your work successfully done
Old 12-04-2011, 02:09   #5 (permalink)
Member: 565908
Thanks Meter: 41
this is not 100% good solution...
its 1/2 of % solution.........
Old 12-04-2011, 03:04   #6 (permalink)
Member: 1282567
Sonork: Djianzil
Thanks Meter: 3
What u mean by 1R sir? is it 1K?
or what?
Old 12-04-2011, 03:24   #7 (permalink)
rajeshlehal's Avatar
Member: 666540
Thanks Meter: 354
its not a good solution we can use a simple diode instead of resistance, +ve side of diode should be connected battery +ve side on battery connector -ve side of diode should be connected with charger +ve side, it will work 100%
Old 12-04-2011, 05:24   #8 (permalink)
Member: 1700109
Thanks Meter: 7
IR Means 1Ohams .....
And Its 100% working.....
tested in china 6300,Ipro,Gfive,martix,and e400i
Old 12-04-2011, 06:31   #9 (permalink)
Member: 222066
Thanks Meter: 62
1r means 1 ohm not 10 ohm
there is no work 1 ohm resister
if 10 ohm resister works that should be the value 10r
just correction of confusing resistance value
thanks
Old 12-04-2011, 06:47   #10 (permalink)
Member: 169323
Thanks Meter: 28
yes i tested before many times.....but not 100% solution......
Old 12-04-2011, 07:47   #11 (permalink)
digicomm's Avatar
Member: 413149
Thanks Meter: 83
1 ohm resistance is too low value.10 ohm sufficent
Old 12-04-2011, 08:21   #12 (permalink)
Member: 1282567
Sonork: Djianzil
Thanks Meter: 3
i think 10ohms thats exactly what he mean... check the color code of the resistor in the picture above... ang determine the value...
Old 12-04-2011, 10:31   #13 (permalink)
asrar's Avatar
Member: 264520
Thanks Meter: 61
it's a 1 (one) ohm resistor..
it's a 1 ( one ) ohm resistor...
Thread poster and every one is saying right...you can use both component resistor and diode between Charging input and battery(+).
and every expert don't like both solutions bcz it's not long time solution.
bad for ( P.A, SOUND IC, LIGHT IC, Power IC, etc... and battery)...
anyway in this situation, I recommend (DIODE)... bcz diode is safe then resistors...
Micro
Old 12-05-2011, 11:31   #14 (permalink)
Member: 666540
Thanks Meter: 354
Micro
I agree with u only diode is best option, with resistance phone will show auto charging sometimes
Old 12-05-2011, 14:41   #15 (permalink)
Member: 36715
Thanks Meter: 22
thanks
you are right as far as resistence is concerned it offers very little but it limits the current, depending on the resistor used
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-10-2014 12:35
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 05:52
PERMANENT MOBILE PHONE SUPPLIER NEEDED MILLENNIUM-INTERNATIONAL Wanted Products 0 08-28-1999 21:23
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! spterminator Main Sales Section 2 08-13-1999 05:55
Page generated in 0.23832 seconds with 10 queries
