Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 01-24-2018, 13:02   #1 (permalink)
Member: 2014880
Sonork: 100.1673441
Thanks Meter: 26
tecno CA6 FRP AND PASSWORD
PLS HOW CAN I REMOVE PASSWORD ON TECNO CA6 AND FRP CUS CM2 NOT SUPPORT BOOT,MIRACLE BOX NOT SUPPORT TOO AND INFERNO PLS NEED URGENT . ALWAYS SHOW THIS ERRO
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 20 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x05000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : LOCKED with CERT
Processing DA stage
Sending and initialize DA ...
[DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED
Boot Error!
Operation Failed
Elapsed: 00:00:18
Reconnect Power/Cable!
Old 01-28-2018, 18:54   #2 (permalink)
Member: 2787248
Thanks Meter: 7
Wait for phone...
Phone found! [ 20 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:18
you have to select high boot in inferno, however, nck box remove it successfully
with cm2 try to install supplementary file and select generic boot / buy supported DA otherwise use bypass method.
Old 03-05-2018, 11:17   #3 (permalink)
Member: 2014880
Sonork: 100.1673441
Thanks Meter: 26
use correct DA FILE WILL WORK
Old 03-13-2018, 01:57   #4 (permalink)
Member: 1619636
Thanks Meter: 30
Show us the link for the custom da file
Old 03-14-2018, 18:09   #5 (permalink)
Member: 2332337
Thanks Meter: 35
Help
Pls i need link for tecno ca6 da file
Old 03-14-2018, 22:19   #6 (permalink)
Member: 1925987
Sonork: dearlex
Thanks Meter: 130
hey Dude, and stop spamming... i have sold this DA to many people and some has share it all over.. and on INFNITY CM2 iOS, so if you need open INFINITY iOS support check prove here INFNITY iOS SUPPORT DA Download therefore have you try with this easy metod shared on on this page ~ tecno ca6 frp remover
Old 03-17-2018, 04:07   #7 (permalink)
Member: 2332337
Thanks Meter: 35
Thanks so much, at last I found it. But y can't I download more dan one file? I'm only limited to download one file a day
The Following User Says Thank You to Oblinks1 For This Useful Post:
Old 03-17-2018, 13:35   #8 (permalink)
Member: 1677653
Thanks Meter: 2,769
because your support has expired.. to be able to download more than 1 file per day renew your support...
Page generated in 0.25276 seconds with 9 queries
