Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 08-05-2013, 22:02   #1 (permalink)
Umesh_Arora's Avatar
Member: 1792140
Sonork: 100.1618782,gaba
Thanks Meter: 6,087
Tutorial:how to write imei in mstar phone with usb if not show com option in phone
pop-up menu. You can do in the following way: plug out USB cable firstly, input “*#*#1705#” in your mobile and press “call” key, then you would enter into an engineer menu, select “Emmi Debug/Disable USB Menu”. After complete this, connect your mobile with PC with USB cable, then you can find that PC would detect the USB port and show it as a modem in the device manager.
Then up to now we build up the connection between your mobile and your PC, you can use operate the volcano box for write imei
select “Emmi Debug
After Emmi Debug/Disable USB, remove battery and insrt again then insert usb
See in device manager
check modem port property for com port
select modem port in volcano and read or write imei done
br
umesh gaba
Page generated in 0.13357 seconds with 8 queries
