Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
07-01-2008, 06:40 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | new problem apper in china sets |
07-01-2008, 07:12 | #2 (permalink) |
Junior Member Join Date: Jun 2008 Location: Argentina Age: 49
Member: 802887 Status: Offline Thanks Meter: 6 | you have to download chinese "imei changer"(search) conect the phone(on) to the usb, then load the soft, search for com port 30 o 31(this new com should appear after you connect the phone, if you want you can first load the soft(before conecting the phone), look at com ports, then exit) with the phone conected set the baudrate, write the imei that the phone has in the sticker below the battery and change the Imei... You should check the engineering mode(search for your code) of your phone and in Devices===>UART===>PS change to USB so you can use the USB to change IMEI. |
07-01-2008, 07:14 | #3 (permalink) |
Member: 802887 Status: Offline Thanks Meter: 6 | I have a problem, may be you can help.... I have an IFOE P168+ (CECT P168+) with the MT6225 Chip, dual sim. I have flashing software, imei changer, MTK Format, and so on... Have the USB Standard Cable and one Serial made by me. The problem is that i made a mistake: I changed PS to USB (instead of UART) and entered a dangerous code: *#6810# that DISABLED THE ENGINEERING MENU and several other codes. The question is: HOW CAN I CHANGE THE PS TO UART without entering the engineering mode? Is there a way to do that? To change to UART or to revert this bad code so i can use the Engineering menu. I've reseted the phone, entered all the codes i have found but nothing happened, and searched the forum for two days. If you could help me i would be very glad, so i continue investigating ways to modify my phone. Thanks in advance. Regards, Robert. |
07-01-2008, 07:22 | #5 (permalink) |
Product Manager Join Date: Oct 2007 Location: China Age: 39
Member: 608359 Status: Offline Sonork: 100.1576815 Thanks Meter: 6,678 | see here problem and solution http:///vbb/showthread.php?t=558654 |
07-01-2008, 07:27 | #6 (permalink) | |
Member: 802887 Status: Offline Thanks Meter: 6 | Quote:
Hi, can you tell me a solution to my problem? To re-enable engineering mode on the phone.... Thank you... | |
***New resseller updates in china 14-3-10*** | DITS | DISTRIBUTER & RESELLER SECTION | 1 | 03-15-2010 10:53 |
how to bilt imei number in china set | bgreat | Chinese Models & Cloned Phones | 2 | 11-27-2009 15:31 |
how to fing problem is in software or hardware in china sets | shahidali109 | Chinese Models & Cloned Phones | 1 | 04-07-2009 15:40 |
HOT HOT New problem 6020 in two phones | rodrigo.gsm | Nokia Hardware & Hardware Repair | 8 | 10-24-2007 14:31 |
New OLD Fones in China | gesundheit | Chinese Models & Cloned Phones | 0 | 10-23-2006 10:33 |
