Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
12-10-2008, 05:44 | #1 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 744651 Status: Offline Thanks Meter: 20 | Need Code for CPU 6225 *#110*01# *#3646633# They do not work, can anyone help me on this? |
12-12-2008, 15:04 | #3 (permalink) |
Member: 744651 Status: Offline Thanks Meter: 20 | Hi My Friend, When i check IMEI using *#06# it gives me IMEI:358*******etc. and underneth it says IMEISV:78....does this help? Or do you want me to use Infinity box to Read Full Flash? |
12-12-2008, 16:56 | #4 (permalink) |
Junior Member Join Date: Jul 2006
Member: 305032 Status: Offline Thanks Meter: 7 | you can help me too. When i check IMEI using *#06# it gives me IMEI:000000000000000 and IMEISV:78 Result is I am getting Invalid Sim in one of the connection; the other one is working fine. Any suggestions how to correct this problem. I do not have any box Infinity/ spiderman etc. TIA |
12-12-2008, 21:21 | #5 (permalink) |
Insane Poster Join Date: Jun 2008
Member: 792296 Status: Offline Thanks Meter: 39 | @DualSimCell I'm pretty sure the code can be found in a fullflash, if you can do that??? Usually all you need is a text editor, search for the word "engineer" and you'll find the code right there. @ttk7 I changed the imei of one of my phones with a cracked version of Spiderman, no special cable needed, just the regular data cable. Maybe you can give this a try??? |
The Following User Says Thank You to ColonelZap For This Useful Post: |
12-13-2008, 12:36 | #6 (permalink) |
Member: 744651 Status: Offline Thanks Meter: 20 | Bro, thanks for your continued attention, i will try ur suggestions and let you know how it works. i also have a Spiderman Box, so no need for crack, just need to know instructions on how too?...for any project |
12-13-2008, 17:53 | #7 (permalink) | |
Member: 792296 Status: Offline Thanks Meter: 39 | Quote:
I've never worked with a Spiderman box, sorry I don't have the a clue on how to operate that thing | |
12-16-2008, 01:39 | #8 (permalink) |
Member: 744651 Status: Offline Thanks Meter: 20 | Here is a Read Full Flash of the Dual Sim Motorola A1800 Please Can You Tell Me Codes for Engineer Mode COM10 [VCP0] selected module v2.70 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0403:0002 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: M960_PCB01_GPRS_MT6225_S00.S560_07A_1_0T03_HW_M040 10_D.BIN ver. sw 2: S560_07A_1.0T03_HW_M04010_D, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98004900000002:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: flash[M960_PCB01_GPRS_MT6225_S00.S560_07A_1_0T03_HW_M040 10_D.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\flash[M960_PCB01_GPRS_MT6225_S00.S560_07A_1_0T03_HW_M040 10_D.BIN]_20081215-203201.B0M.bin Finished, time used: 1730 sec Remove/Install battery now ! |
12-16-2008, 01:58 | #9 (permalink) | ||
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
hi.. u have to add flash file for code.. or u have to apply this procedure... Quote:
12-19-2008, 04:21 | #12 (permalink) |
Junior Member Join Date: Dec 2008
Member: 927523 Status: Offline Thanks Meter: 1 | The other day i found out some very useful softwares. Here i would like to share them with you. Mac Mp4 Video Converter is a software which can convert all video formats such as 3GP, FLV, MPEG, MOV, VOB, WMV, AVI to MP4 video and AAC M4A audio to MP4 for MP4 video players such as iPhone, iPod, Apple TV, video mobile and PSP, with excellent output quality and high conversion speed. Mac iPhone Video Converter converts all popular videos and audios such as AVI, MPEG, WMV, MP4, AAC, AC3, MP3, and so on to iPhone (including iPhone 3G) supported formats such as MP4, MP3, etc. Mac iPod Video Converter converts video to iPod video and iPod audio on Mac OS X with powerful functions. Video Converter for Mac 4Media Video Converter for Mac is powerful video and audio conversion software for Mac users specially. Mac Video to AVI Converter is developed to convert all popular video files to AVI and convert video to audio for Mac OS X users. Enjoy your digital life! |
The Following User Says Thank You to desert333 For This Useful Post: |
need bin file cpu 6225 n flas 57200AD | vipinverma | Chinese Models & Cloned Phones | 0 | 06-14-2009 07:10 |
HELP ME>>> i need file N72i cpu 6225 flas samsung | vipiphone | Chinese Models & Cloned Phones | 2 | 05-21-2009 11:46 |
I need flash n99i cpu 6225 | goldenploto | SpiderMan | 4 | 11-24-2008 04:36 |
Help! Need code for grundig radio for smart for two | Smoothie | CAR Electronics | 1 | 08-31-2008 14:03 |
lock code 5310 Cpu 6225 help me? | dauyeuqn | SpiderMan | 1 | 08-18-2008 09:36 |
