11-06-2015, 09:26 | #16 (permalink) |
Product Manager Join Date: Mar 2011 Location: kuwait Age: 32
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Primo EM Firmware Flashing Instructions Software Download Link- Simple File Sharing and Storage. 1. Install the drivers 2.Open Flash Tool 3. Pac Loading a. Click "Load Packet". (number "a" showed in the image). New window will appear. b. Enter "Primo_EM_software_service+sw" folder and select "Walton_Primo_EM_W533_M00_S04S_150619" file (number "b" showed in the image). c. Click "Open" (number "c" showed in the image) 4. Now Click Firmware Upgrade (Click "Start") 5. Connect The Handset After clicking the "Start", press the volume down key of your handset, and connect it to your computer with USB cable. Remember: Before connecting the handset with your computer, you must turn it off. Also notice that the battery has to be kept inserted. Flash operation will begin, you will see this window: [IMG]http://s22.postimg.org/o***ln75d/image.png[/IMG] 6. There will appear "Passed". This means it is successful. Disconnect phone, open battery and reconnect again (If non-removable). Enjoy!! |
11-06-2015, 09:29 | #17 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Flash Tool Instruction of Primo EF3 Step 1: Driver Installation Step 2: Open Flash Tool Open the Flash Tool. Enter folder named "UPGRADEDOWNLOAD_R2.9.9001". Then enter file named "Bin". There you will see an icon named "FactoryDownload.exe" Step 3: Pac Loading a. Click "Load Packet". (Number "a" showed in the image). New window will appear. b. Enter "Primo EF3 Lollipop Firmware" folder, then select “Lollipop Firmware” then select "Walton_Primo_EF3_W821_M00_S02_151022.pac" file (number "b" showed in the image). c. Click "Open" (number "c" showed in the image) Step 4: Firmware Upgrade a.Click "Start". (Number "a" showed in the image). Step 5: Connect The Handset After clicking the "Start", press the volume down key of your handset, and connect it to your computer with USB cable. Try to hold the volume down button at least 30 sec. Flash operation will begin, you will see this window: Step 6: Notification There will appear "Passed". This means it is successful. |
11-06-2015, 09:30 | #18 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Primo EF2 Driver, Flashtool & Firmware download Link: EF2_4.4.2_1 1.Click on Install.bat File 2.Open SPMultiportFlashDownloadProject tool 3.Run download tool 4. Select the MT6582_Android_scatter.txt scatter file 5.Click “Start all”start download |
11-06-2015, 09:32 | #19 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | official Firmware Flashing Instructions of Primo E5 Firmware Download Link- Primo E5 Firmware 1. Install driver. 2. Open Flash Tool 3. Open scatter_loading and select scatter file (Primo E5 Firmware Ă softwareĂ MT6572_Android_scatter) 4. Click Firmware Upgrade 5. Now select Download and then connect USB cable with mobile (mobile must be off) 6. If you see below image, it means that mobile is detected through Usb cable 7. When it shows Download Ok, it means the installation/flashing firmware is completed. |
11-06-2015, 09:33 | #20 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Lollipop Firmware Flashing Instructions for Primo E4+ Software Download Link- Walton_Primo_E4+(Android 5.0 ) 1. Extract Downloaded Firmware. 2. Install driver software 3. Open SP Flash Tool 4. Open Download Agent and select MTK_AllinOne_DA 5. Open scatter_loading and select scatter file (Walton_Primo_E4+(Android 5.0 )\Primo_E4+_Lollipop\MT6582_Android_scatter) 6. Click Firmware Upgrade 7. Now select Download and then connect USB cable with mobile (mobile must be off). If you see below image, it means that mobile is detected through Usb cable. 8. Then start downloading/flashing firmware 9. When it shows Download Ok, it means the installation/flashing firmware is completed. Enjoy Lollipop. |
11-06-2015, 09:34 | #21 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Primo E4 Driver, Flashtool & Firmware Download Link: E4_4.4.2_1 1. Install driver. 2. Open Flash Tool 3. Open Download Agent and select MTK_AllinOne_DA 4. Open scatter_loading and select scatter file SW---> Primo_E4_V1.0.0_S - CopyĂ MT6582_Android_scatter 5. Click Firmware->Upgrade andconnect USB cable with mobile (mobile must be off) 6. Then start downloading.. 7. When it shows Firmware Upgrade , then installation is completed. |
11-06-2015, 09:42 | #22 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Primo F Series New official firmware for primo F1 (Build Number: A51B_WALTON_V0_0_9) [solved: black screen, memory & others bugs] D/L text file from attachment "Primo F1 FW v. 0_0_9" you will get download link Guide: 1. Install USB cable drive software. (From "Driver" folder ) 2. Open Flash Tools MultiportDownload.exe (From "Download Tools" folder) 3. Select smart phone and press ok. 4. Click "Select file" for select scatter file 5. Select scatter file (MT6575_Android_scatter_emmc) from software folder (Under "WALTON_Primo_F1_Firmware" folder) 6. Download file load successfully will show. click "ok" button. 7. Press "Start all" 8. Under POWER OFF mode press & hold Volume up and down key together, then put USB cable in to Handset charging port (with battery). Software process will be start within few second. 9. Wait till complete software update process. ** NOTES... If auto driver installation failed (step 1) then install manually after ( step 8 ) connect USB Cable as soon as possible.) https://drive.google.com/uc?id=0B_h4...jBlY3JfaVRXTEk |
11-06-2015, 09:49 | #23 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Firmware Flashing Instruction of WALTON PRIMO F6 Software Download Link- Primo F6 firmware 1. Install drivers 2. Open Flash Tool 3. Open scatter_loading and select scatter file (Primo F6 Firmware>Walton_Primo_F6_S006_02072015ŕMT6580_Android_scatter) 4. Click FirmwareUpgrade then select Download and then connect USB cable with mobile (mobile must be off) 5. Now start downloading/flashing firmware 6.When it shows Download Ok, it means the installation/flashing firmware is completed. |
11-06-2015, 09:51 | #24 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Primo F5 Driver, Flashtool & Firmware download Link: http://www.mediafire.com/download/rqprxjcv7o3bxq0/F5_4.4.2_1.rar # Install Driver by clicking “install” from “Driver” folder # Open Flash tool (MultiPortDownload.exe file from flash tools folder)
3. Press and hold volume up key and then Connect USB cable It will starts SW Upgrading and After several seconds, it will show “Cksm(FAT) OK…100% “ with green icon. Done!!! |
11-06-2015, 09:55 | #25 (permalink) |
11-06-2015, 09:55 | #26 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Primo F4 Official Driver, flashtools & firmware download Link: F4_4.2.2_1 1. Install driver. 2. Open Flash Tool 3. Open Download Agent and select MTK_AllinOne_DA 4. Open scatter_loading and select scatter file SW--- MT6572_Android_scatter.txt 5. Click Firmware->Upgrade and connect USB cable with mobile (mobile must be off) 6. Then start downloading.. 7. When it shows Firmware Upgrade , then installation is completed. After Firmware Upgrade give Reset to Factory setting to get all apps. |
11-06-2015, 09:56 | #27 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Download Link: F3i Complete Release note: 1. Faster and better performance 2. New boot logo 3. Wallpaper changed 4. New ring Tone added 5. Bd Data plan & Walton flashlight (Latest Version) is included. 1.Install driver: 3. Select smart phone and press ok. 4. Click "Select file" for select scatter file 5. Select scatter file (MT6572_Android_scatter) from software folder (Under "WALTON_Primo_F3_Firmware" folder) 6. Download file load successfully will show. click "ok" button. 7. Press "Start all" 8. Under POWER OFF mode press & hold Volume up and down key together, then put USB cable in to Handset charging port(with battery). Software process will be start within few second. |
11-06-2015, 09:57 | #28 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Firmware, Flashtools & Driver Download Link: 1. Install driver. F2 firmware Instruction: 2. Open Flash Tool 3. Open Download Agent and select MTK_AllinOne_DA 4. Open scatter_loading and select scatter file SW---> WBW6803WA_0410_T8142 MT6577_Android_scatter_emmc 5. Click Firmware->Upgrade and connect USB cable with mobile without battery 6. Insert Battery then start downloading.. 7. When it shows Firmware Upgrade , then installation is completed. |
11-06-2015, 10:39 | #29 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Primo EM Firmware Flashing Instructions Software Download Link- 1. Install the drivers 2.Open Flash Tool 3. Pac Loading a. Click "Load Packet". (number "a" showed in the image). New window will appear. b. Enter "Primo_EM_software_service+sw" folder and select "Walton_Primo_EM_W533_M00_S04S_150619" file (number "b" showed in the image). c. Click "Open" (number "c" showed in the image) 4. Now Click Firmware Upgrade (Click "Start") 5. Connect The Handset After clicking the "Start", press the volume down key of your handset, and connect it to your computer with USB cable. Remember: Before connecting the handset with your computer, you must turn it off. Also notice that the battery has to be kept inserted. Flash operation will begin, you will see this window: [IMG]http://s22.postimg.org/o***ln75d/image.png[/IMG] 6. There will appear "Passed". This means it is successful. Disconnect phone, open battery and reconnect again (If non-removable). Enjoy!! Last edited by Dipankor-ctg; 11-06-2015 at 10:48. |
