11-06-2015, 11:23 | #46 (permalink) |
Product Manager Join Date: Mar 2011 Location: kuwait Age: 32
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Release Note:
1st step: Power Off the phone and Connect your phone with PC via USB cable. Now go to My Computer>Manage> Other devices> MT65xx Preloader 2nd step: A window will appear like below and select Browse my computer for driver software 5th step: Wait until Windows has successfully updated your driver software 6th step: Now go to Driver Folder> Open MS_USB_ComPort_Driver_exe_v1.1032.1 > Install Driver 2. [glow=red,2,300]Open Flash Tools MultiportDownload.exe[/glow] (From "Download Tools" folder) 3. Select smart phone and press ok. 4. Click "Select file" for select scatter file 5. Select scatter file (MT6589_Android_scatter_emmc) from software folder (Under "WALTON_Primo_NX_Firmware" folder) 6. Download file load successfully will show. click "ok" button. 7. Press "Start all" 8. Under POWER OFF mode press & hold Volume up and down key together, then put USB cable in to Handset charging port (with battery). Software process will be start within few second. |
11-06-2015, 11:29 | #47 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Primo R Series Primo R Series Primo R1 Firmware,Flashtools & Drivers Primo R1 Firmware,Flashtools & Drivers Download Link:- R1 Software, tools and driver 1. Install driver. 2.Open Flash Tool 3.Open Download Agent and select MTK_AllinOne_DA 4. Open scatter_loading SW---> Walton_Primo_R1_SW MT6577_Android_scatter_emmc 5. Click Download and connect USB with mobile without battery 6. Insert Battery then start downloading .. 7.When it shows Download ok in green, the installation is completed. |
11-06-2015, 11:34 | #48 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Flash Tool Instruction of WALTON PRIMO RM2 Download Link- Walton Primo RM2 Firmware 1. Install driver 2. Open Flash Tool 3. Open scatter_loading and select scatter file (Walton_Rm2_V04_20150608ŕMT6582_Android_scatter) 4. Click Firmware Upgrade then select Download and then connect USB cable with mobile (mobile must be off) 5. Then start downloading/flashing firmware 6. When it shows Download Ok, it means the installation/flashing firmware is completed. |
11-06-2015, 11:35 | #49 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Walton Primo RM Driver, Flashtool & Firmware download Link: RM_4.4.2_1 1. Install driver. 2. Open Flash Tool 3. Open Download Agent and select MTK_AllinOne_DA 4. Open scatter_loading and select scatter file Software-Ă MT6592_Android_scatter.txt 5. Select Firmware Upgrade and click on Download and connect USB cable with mobile (mobile must be off) 6. Then start downloading.. 7. When it shows Firmware Upgrade , then installation is completed. |
11-06-2015, 11:36 | #50 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | ollipop Flashing Instructions of WALTON PRIMO RH2 Download Link- RH2 Lollipop firmware 1. Install Driver Software 2. Open Flash Tool. 3. Open scatter_loadingand select scatter file (RH2 Lollipop Firmware> Lollipop Firmware (MT6592_Android_scatter) 4. Click Firmware Upgrade then select Download and then connect USB cable with mobile (mobile must be off) 5. Then start downloading/flashing firmware 6. When it shows Download Ok, it means the installation/flashing firmware is completed. |
11-06-2015, 11:37 | #51 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Primo RH Official Driver, flashtools & firmware download Link: RH_4.4.2_1 # Install Driver by clicking “install” from “Driver” folder # Open Flash tool (MultiPortDownload.exe file from flash tools folder)
3. Connect USB cable & insert battery It will starts SW Upgrading and After several seconds, it will show “Cksm(FAT) OK…100% “ with green icon. Done. |
11-06-2015, 11:37 | #52 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Flash Tool Instruction of WALTON PRIMO RX4 Download Link- Primo RX4 Firmware 1. Install driver 2. Open Flash Tool. 3. Open scatter_loadingand select scatter file (Primo RX4 Firmware>Primo RX4 softwareŕMT6592_Android_scatter) 4. Click FirmwareUpgrade then select Download and then connect USB cable with mobile (mobile must be off) 6. When it shows Download Ok, it means the installation/flashing firmware is completed. |
11-06-2015, 11:38 | #53 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | |
11-06-2015, 11:39 | #54 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Primo RX2 Official Driver, flashtools & firmware download Link: RX2_4.4.2_1 Primo RX2 Firmware upgrade instruction: # Install Driver by clicking “install” from “Driver” folder # Open Flash tool (MultiPortDownload.exe file from flash tools folder) 1. Set Scatter-loading (“MT6592_Android_scatter.txt“ file from “SW” folder) 2. Click, Start All 3. Press and hold volume up key till progress start 4. Connect USB cable & insert battery It will starts SW Upgrading and After several seconds, it will show “Cksm(USRDATA) OK…100% “ with green icon. Done!!! |
11-06-2015, 11:40 | #55 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Primo RX Official Driver, Firmware Download Link: Primo RX official firmware 1. Install Driver by clicking “install” from “Driver” folder 2. Open Flash tool ( Flash tool.exe file from flash tools folder) 3. Set Scatter-loading (“MT6589_Android_scatter_emmc.txt “file from “SW” folder) 4. Click Firmware->Upgrade in Flash tools 5. connect the handset to PC with USB cable It will starts SW Upgrading and After several seconds, it will show “Firmware Upgrade… “ and a green-circle popup . |
11-06-2015, 11:41 | #56 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Release Note: ------------------- 1. Firmware upgraded from 4.2.1 to 4.2.2 2. Improved UI with fine tuned system performance. 3. Internet Data Plan: You will get all Internet Data Plan offers within one app (Bangladeshi Operators) 4. Flash Light: Walton Android Flash Light comes with widget facilities. Firmware & Flashtools Download Link: PrimoR2_Jellybean_4.2.2 Drivers Download Link: 1.Install driver: 1st step: Power Off the phone and Connect your phone with PC via USB cable. Now go to My Computer>Manage> other devices> MT65xx Preloader 2nd step: A window will appear like below and select browse my computer for driver software 6th step: Now go to Driver Folder> Open MS_USB_ComPort_Driver_exe_v1.1032.1 > Install Driver 3. Open Download Agent and select MTK_AllinOne_DA 4. Open scatter_loading and select SW---> Primo R2_BGG_EN_BN_0.94.711 MT6589_Android_scatter_emmc 5. Click Firmware->upgrade and connect USB with mobile (with Battery and mobile must be off) 6. When it shows Firmware Upgrade ok in green, the installation is completed. |
11-06-2015, 11:46 | #57 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Primo S Series Primo S1 official firmware & flashtools Download Link : ****************************/download/x...l%20firmware.r 1. Install Driver by clicking “install” from “Driver” folder 2. Open Flash tool ( Flash tool.exe file from flash tools folder) 3. Set Scatter-loading (“MT6589_Android_scatter_emmc.txt “file from “SW” folder) 4. Click Firmware->Upgrade in Flash tools 5. connect the handset to PC with USB cable It will starts SW Upgrading and After several seconds, it will show “Firmware Upgrade… “ and a green-circle popup . |
11-06-2015, 11:48 | #58 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | S2 Official Firmware, Flashtools & Drivers Download Link: https://forum.gsmhosting.com/vbb/****************************/?0fawlk80ujghz4z First: Install the driver Please double-click on the program to install. Program [GN_QC_EN_Driver_V1.1.0.0.exe] Second: Download instructions Before download, Need to check the following point: Need to select USB connection mode to "Charge Mode" in order to identify the port and start downloading (The default USB connection mode is "Charge Mode"). Download tool: GNQC_DownLoadV1.6.8.0_EN.rar After Downloading complete, please follow the steps: 1. Open GNQC_DownLoad flash tools 2. Click on the "BP Path" Button and "AP Path." Buttons and select BP and AP from software,Download mode drop-down(DL Mode) options is choose"General download (BP + AP)… 3. Connect Mobile with PC (Mobile must be remain off) and after found port then click download. Then start downloading…. 4. Wait until the appears as shown in below figure,then the download is completed: 5. After the download completed, wait a few seconds, the phone automatically restart, the whole process is over。 6. To get all apps after on handset give the “Factory data reset” |
11-06-2015, 11:49 | #59 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | S3 Official Firmware, Flashtools & Drivers download link: S3_4.4.2_1 # Install Driver by clicking “install” from “Driver” folder # Open Flash tool (Flash_tool.exe file from flash tools folder) 1. Set Scatter-loading (“MT6592_Android_scatter.txt “file from “Firmware” folder) 2. Select “Firmware upgrade” 3. Click, Download 4. Connect USB cable & insert battery It will starts SW Upgrading and After several seconds, it will show “ Download OK “ with green icon. |
11-06-2015, 11:49 | #60 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Firmware Flashing Instruction of WALTON PRIMO S4 Download Link- Primo S4 Firmware 1. Install driver 2. Open Flash Tool. 3. Open Download Agent and select MTK_AllinOne_DA 4. Open scatter_loadingand select scatter file (Primo S4 Firmware>Primo S4 softwareŕMT6592_Android_scatter) 5. Click FirmwareUpgrade then select Download and then connect USB cable with mobile (mobile must be off) 6. Then start downloading/flashing firmware 7. When it shows Download Ok, it means the installation/flashing firmware is completed. |
