Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SmartKey
Old 02-19-2009, 01:56   #1 (permalink)
Member: 540199
LG KU990 VDF to ESA Version flashing
Hi~ I've currently got Vodafone NZ branded LG KU990 Viewty.
(Not KU990R) I've tried flashing this phone with different
region Flash files (e.g. Hong Kong ESA version) but it fails all the time
with something like 'AMSS Partition Error'. I can still flash it with normal
european language spec flash files but not Asian, or no flash files with asian languages. Is there any way to by pass this error and flash the phone with different language spec? I'm not talking about change the display language but to change actual language spec with proper input support as well.
Thank you in advance.
Old 02-20-2009, 07:25   #2 (permalink)
SmartKey.eu's Avatar
Member: 721981
Is the same error occurs always flashing? If yes, you may have insufficient RAM in your coputer. Turn off the programs working in the background, but if there are flashes with which you can flash the phone with, give me an exact name and what flash you want to write into the phone, I will try to change it for you.
Old 02-23-2009, 04:49   #3 (permalink)
Member: 540199
I don't think
It's the RAM problem. If that's the case, then I shouldn't be able to flash any firmware at all. The problem happens whenever I want to flash the KU990 VDF phone to ESA version firmware. If I try to flash it with any other European version or OPN version, it works.
KU990-DZ-V10g-AUG-12-2008-ESA_ESA.lpk
KU990-DZ-V10g-AUG-12-2008-ESA_THA.lpk
KU990-DZ-V10g-AUG-12-2008-ESA_TWN.lpk
KU990-DZ-V10g-AUG-12-2008-ESA_VIR.lpk
The following version flash files gives me same error.
As soon as smartkey finishes reading NVM, it says
Error AMSS [partition] <-- this kind of error message.
Also I'm using Infinity Tool Box as well on same PC.
I want to flash LG KP100 to Chinese firmware, but the Virtual COM port
is set up to COM3. Infinity uses Virtual COM port as COM4. Is there any
option or settings that I can change this COM port settings in SmartKeyLGKE?
Oh~! And one more thing. Where does SmartKey saves NV2 data?
It creates the folder OK, but I couldn't find any NV2 backup files. This is
critical as I believe backing up NV2 data is crucial for any LG flasher. So far
I've only used SmartKey for about a week, and I can tell you I'm losing
faith in your products. About the ESA firmware, I've already done it using
LGMDP program and normal ESA DZ files from the internet. But I believed that
SmartKey can do it without any problems, which in fact is NOT. I think I've wasted good NZ$500 for it.
So please give us some good solution about your product.
I appreciate your quick reply though. I hope you can do the same for this
reply as well. Thank you in advance.
Old 02-23-2009, 05:53   #4 (permalink)
Member: 540199
Same for LG KF700 ESA version Flashing...
This just came up. Error appears when I tried to flash ESA version Firmware
for LG KF700.
The file I've downloaded from your support page was
DZ_KF700-V10c-JUL-18-2008-HKG_HKG.lpk
And this time error message came up like this...
"AMSS Uploading... Error. [48xx]"
What's this? Can you please provide us with a solution as soon as possible?
Thanks~
Old 02-27-2009, 17:05   #5 (permalink)
Member: 721981
my sonork is 100.112959 please contact me on prv .i will help you to solve the problem, I am available on sonork all the time.
Old 05-16-2009, 07:21   #6 (permalink)
Member: 1032306
Sonork: 1
Arrow Potassium Persulfate
Excuse my interruption. Could anyone give me these chemical products' MSDS? Potassium Persulfate
KU990 Camera fails to start | How to upgrade LG KU990? | Factory menu messed up the-nature-one LG 8 02-28-2010 22:49
Lg Ku990 How To Enter Unlock Code Plzzz Help Me dharmdev allGSMunlock MultiOnline Remote Server 22 01-06-2009 00:50
LG KU990 unavailable to wallpaiper file ? cbcelular LG 3 10-12-2008 14:19
posible to read flash from lg ku990? SEMEN VygisToolbox 5 08-14-2008 12:10
Lg Ku990 New Version Unlock Nasmi LG 1 08-13-2008 20:30
Page generated in 1.86421 seconds with 11 queries
