10-21-2008, 07:58 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Age: 47
Member: 76522 Status: Offline Thanks Meter: 30 | lg translator how 2 use? |
10-21-2008, 12:41 | #2 (permalink) |
No Life Poster Join Date: Nov 2004 Age: 45
Member: 93284 Status: Offline Thanks Meter: 202 | I also tried with U310 but it doesn't work with this model. If you connect phone and program shows you list of languages available in phone then you can change (edit) language, if it doesn't read languages in phone, you can't. Those are only my observations. BR |
10-22-2008, 15:05 | #6 (permalink) |
Product Supporter Join Date: Mar 2008
Member: 721981 Status: Offline Thanks Meter: 320 | Translator Manual "the library&dictionary bookmark"- we provide the access path to the flash with a languages base ,C:\Program Files\SmartKey\LG\library\ it will load the languages base, and we select those we are interested in, we move on to the bookmark Files, then we select a flash from the support, the best would be the same version that is written into the phone (Files - Load Files), the number of languages appears to you and you select the one you want to translate. We can also translate automatically. We press the right button on the mouse, we choose "select all", once again we click with the right mouse button, then we move on to the "Auto translate select to..." option and then the list of available languages is shown to us and we select the one we are interested in and we write it in. With the manual option, on the other hand, we translate each text separately.When the translation is finished you can save the whole project or write it into the phone. In order to do it we move on to the bookmark "built" with the phone connected , then you select the language that is translated and you select the language that you want to change.Then you press "build&upload to phone", it takes a few seconds, then the information taht everything is all right will appear.. Then you power the phone on.To make the language visible in the menu you need to start it . If it was already selected before you need to turn it on once again with the other language. |
10-22-2008, 19:27 | #7 (permalink) |
Member: 76522 Status: Offline Thanks Meter: 30 | seems another bug whis u370w. after chosing danish or english language and chose auto translate i got mostly empty strings. after writing it 2 phone i got empty menu. pls add status bar because we dont know is it working or just hang. |
10-22-2008, 20:53 | #8 (permalink) |
Member: 721981 Status: Offline Thanks Meter: 320 | the mistake is with the russian language, the rest is all right, we are fixing it at the moment. thank you for informing about any problems that occur, but with the library containing over 5.000000 strings - they sometimes happen. we will try to fix them at the very moment you inform about any of them.don't hesitate to report any problems. |
10-23-2008, 17:59 | #10 (permalink) |
Member: 76522 Status: Offline Thanks Meter: 30 | any news whis russian lp bug? my castomers r little angry at me because i lie them that i can translate their phones by the way seems u have such bug whis ukrainian lp too. |
10-23-2008, 19:20 | #11 (permalink) |
Member: 76522 Status: Offline Thanks Meter: 30 | another bug: ku380 branded by vodafone ver 10a. i try 2 write just rassian lang from 10b balcans. 1st. soft not correctly detect number of languages at phone (4 examle it find finland in phone ) after writing russiang lp i get damaged menu. some leeters r missing and structure also damaged. |
10-25-2008, 10:28 | #14 (permalink) |
Member: 721981 Status: Offline Thanks Meter: 320 | it definitely works, I'm giving you the link for the manual video http://rapidshare.com/files/15716134...lator.rar.html and 2 more important things: 1) flash the phone to this soft version you edit. If you have different soft versions in the phone and in the flash, use the CONVERT option. 2) after loading the language to the phone, firstly you have to start another language, not the one you translated, and secondly, you need to start the one that is translated. If you have any questions fell free to contact me at sonork: Tech Mobil 100.112959 or contact Grexor 100.77298. |
lg tu915 How to use the network lock vygis | wangbaojie | VygisToolbox | 1 | 05-03-2009 07:22 |
How 2 Use W550i 2 Access Net In Laptop | cliv | Sony Ericsson | 0 | 04-15-2007 21:26 |
