Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SmartKey
Old 01-18-2009, 14:35   #1 (permalink)
Crazy Poster
Member: 831294
need help flashing these models!
@mods
I need to flash KM710, KC550 and KF510 phones as to change language in them, but i tried using KE500 and KG800 RJ45 cables and couldn 't connect the phones to the software, now could the moderators tell me how to actually flah this phones? what is the proicedure and which cables to use to flash them?
WBR
ReyTech.
Old 01-19-2009, 10:44   #2 (permalink)
Crazy Poster
Member: 831294
Originally Posted by ATSC L.L.C View Post
@mods
WBR
ReyTech.
@ALL
Nobody has any idea whihc cable to use for flashing and unlocking the above models! even mods?
WBR
ATSCLLC.
Old 01-19-2009, 16:28   #3 (permalink)
SmartKey.eu's Avatar
Member: 721981
you need ke 500 flash cable, i will check if there are any mistakes , there is no need to write 20 posts. I wasn't available for a few days and so far there has been nobody to reply on forum instead of me .
Old 01-22-2009, 16:25   #4 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Hi
today i try to change language on kc550 with smart key
but fail to flash the phone
is there any one test kc550 flashing with smart-key..?
i use ke500 flash cable
cable is working and tested but smart key cant start the process..
fail before the flashing starts
any idea..?
Old 01-24-2009, 06:52   #5 (permalink)
Member: 721981
please tested
http://lg3gservice.com/pub/ke/SmartKeyLGKE.rar
Old 01-25-2009, 15:17   #6 (permalink)
Crazy Poster
Member: 831294
Originally Posted by SmartKey.eu View Post
@SMARTKEY
This exe we tyoo have as its there in the support area as well! so give us something which works! i dont think so anybody has ever flashed anyphone with this soft succesfully until now!
WBR
ATSCLLC
Old 01-25-2009, 16:13   #7 (permalink)
Member: 721981
it's not the same. I changed calculating control sum of boot, everything works now. it has just been checked on kc550 . Test it first, please before accusing.
Old 01-26-2009, 16:59   #8 (permalink)
Crazy Poster
Member: 831294
@smartkey
OK which cable to use? KE500 cable works with this models? pls inform and also inform the pinouts as well so that we can check!
WBR
ATSCLLC
Old 01-26-2009, 17:07   #9 (permalink)
Member: 721981
KE500 FLASH
Cable name: KE500
keyboard top
1.........18
1: Gnd
2: phone Rx (RJ45 pin-2)
3: phone Tx (RJ45 pin-3)
5: Gnd
15: Gnd
18: Gnd
18: Gnd
B.R.
Tech Mobil
Old 01-28-2009, 14:15   #10 (permalink)
Crazy Poster
Member: 831294
KE500 FLASH
Cable name: KE500
keyboard top
1.........18
1: Gnd
5: Gnd
15: Gnd
18: Gnd
18: Gnd
B.R.
Tech Mobil
@Smartkey
Still nothing! i tried with the same pinouts and when u press the poweron key the phone goes on but nothing happens, i tried with a original KE500 cable witouth modifying it and then it to it the same! nothing happens when u press the power key! i dont think these models are supported by the software!
WBR
ATSCLLC
Old 01-29-2009, 09:28   #11 (permalink)
Member: 721981
Write exactly what phone odel you are doing and what box to co emulation you use, if SmartKey detects it in settings. Obviously, there is a problem in your case between connection of the phone and box. Yes, there was a problem with calculating boot , but software reacted on power on in the telephone, in your case it doesn't. The problem has already been removed in the last version, a lot of people confirmed that on forums that everything works!! I personally, tested on KC550- successfully.Please, write exactly the details I asked for at the beginning of this post. I need more details.
need file flash startech models VODAFONES Chinese Miracle & PinFinder 1 12-22-2008 09:49
please i need sechmatic for these models please tsarkh Nokia Hardware & Hardware-Repair Area 5 11-05-2008 10:46
Need support for these models.... sahil2000ind ET-BoX 7 12-26-2007 19:54
Lg 7030 And Lg W7000. How To Flash These Models MindPower LG 0 07-08-2004 21:06
I need help for these MY 3026 & MW 3026 kazak Phone Unlocking Codes & Maps 3 01-21-2003 08:28
Page generated in 0.35790 seconds with 11 queries
