SmartKey Translator - updates, history, latest versions Being the first on the world we would like to show you SmartKey LG QUALCOMM Translator http://www.lg3gservice.com/pub/Language%20editor.jpg www.SmartKey.eu B.R. SmartKey.eu |
SmartKey editor can write all languages worldwide, including slang. Already existing languages from different phone models can be used as well. It runs as follows: we can do this in two ways: manually or automatically. If we find a language that has a similar standard in other model, while opening the language file the software will adjust it automatically itself and then it will inform us if the standard is compatible 1. We open the bookmark" files", next " load files" and select the model that is connected to SmartKey 2. We select a language that we need to translate 3. We open" load files" once again and select a flash, we click on it with a right mouse button, then an additional menu will appear and we select " convert language to.." and we select the language in which the software is meant to be written. The software will automatically add an existing language (in this way we can copy the whole language). It looks in the following way: we click on it with the right mouse button, we choose "select all "and then "copy selected to ..." Then it is enough to come to the " build " bookmark and choose " select setup", then select a language we want to write and exchange in the phone, then we select "build& upload to phone" |
http://www.lg3gservice.com/pub/arabski.jpg http://www.lg3gservice.com/pub/arabski1.jpg http://www.lg3gservice.com/pub/arabskii.jpg |
SmartKey Translator - updates, history, latest versions |
Vietnamese language needs to be written to this model. Unfortunately, the languge from any other model is not applicable . 1. You select a flash from the support, the best would be the same version that is already written in the phone (Files-Load Files) 2. The number of languages appear and you select the one you want to translate 3. When the translation is ready you can either save the whole project or write it into the phone 4. you enter the bookmark "build" with the phone connected, you select the language that is translated and the language in the phone you want to change.Then you press "bulid&upload to phone", it takes a few seconds. Then an information that everything is ok appears ,and you power the phone on.To make the language visible in menu you need to turn it on, if it was already selected before- you have to turn on any other language from the menu and finally the right one. |
Translator Manual Translator Manual "the library&dictionary bookmark"- we provide the access path to the flash with a languages base ,C:\Program Files\SmartKey\LG\library\ it will load the languages base, and we select those we are interested in, we move on to the bookmark Files, then we select a flash from the support, the best would be the same version that is written into the phone (Files - Load Files), the number of languages appears to you and you select the one you want to translate. We can also translate automatically. We press the right button on the mouse, we choose "select all", once again we click with the right mouse button, then we move on to the "Auto translate select to..." option and then the list of available languages is shown to us and we select the one we are interested in and we write it in. With the manual option, on the other hand, we translate each text separately.When the translation is finished you can save the whole project or write it into the phone. In order to do it we move on to the bookmark "built" with the phone connected , then you select the language that is translated and you select the language that you want to change.Then you press "build&upload to phone", it takes a few seconds, then the information taht everything is all right will appear.. Then you power the phone on.To make the language visible in the menu you need to start it . If it was already selected before you need to turn it on once again with the other language. |
SmartKey Translator -the selection of one or more languages needed for translation -preparation of other languages in progress -base of new languages is added, it is enough to click on a selected text,the software will show us an example of translation in the following languages: ARABIC BULGARIAN CATALAN CROATIAN CZECH DANISCH DUTCH ENGLISH ESTONIAN EUSKERA FARSI FINNISH FRENCH GALLEGO GERMAN GREEK HABREW HKGTRAD CHINES HUNGARIAN INDONESIAN ITALIAN KAZAKH KOREAN LATVIAN LITHUANIAN MALAY NEDERLANDS NORWEGIAN POLISH PORTUGUESE ROMANIAN RUSSIAN SERBIAN SIMPCHINES SLOVAK SLOVENIAN SPANISH SWEDISH TRADCHINES TURKISH THAI TWNTRADCHINESE UKRAINIAN VIETNAMESE\ MANUAL VIDEO http://pl.youtube.com/watch?v=cwYh2l002cY\ http://rs6tg.rapidshare.com/files/15...Translator.rar Manual "the library&dictionary bookmark"- we provide the access path to the flash with a languages base ,C:\Program Files\SmartKey\LG\library\ it will load the languages base, and we select those we are interested in, we move on to the bookmark Files, then we select a flash from the support, the best would be the same version that is written into the phone (Files - Load Files), the number of languages appears to you and you select the one you want to translate. We can also translate automatically. We press the right button on the mouse, we choose "select all", once again we click with the right mouse button, then we move on to the "Auto translate select to..." option and then the list of available languages is shown to us and we select the one we are interested in and we write it in. With the manual option, on the other hand, we translate each text separately.When the translation is finished you can save the whole project or write it into the phone. In order to do it we move on to the bookmark "built" with the phone connected , then you select the language that is translated and you select the language that you want to change.Then you press "build&upload to phone", it takes a few seconds, then the information taht everything is all right will appear.. Then you power the phone on.To make the language visible in the menu you need to start it . If it was already selected before you need to turn it on once again with the other language. |
LG u300,u310,u250,u450,u970,cu720 itd... video manual Language change in LG U250,U250C,U300,U300C,U310,U310C,U370,U370C,U370W, U450,U450C,U830,U830C,U960,U970,U970C KC910,HB620,HB620T,CB630,KB620,KF310,KF311,KF390,K F390Q,KF690,KF700,KF700Q,KF700GO,KU990,KU990MF,KU9 90GO, KU990R,KE990,KE990D,KE998,KU250,KU380,KU385,KU450, KU730,KU950,KU960,KU970,U990,U990C,CU515,TU515,CU5 75, TU575,CU720, TU720,CU320,CU400,MU515,MU550,CU405,KU310,KU311,KU 800,KU970,L600V, Language change in LG manual video http://smartkey.eu/pliki/Manual/Smar...eo%20Movie.rar manual http://smartkey.eu/pliki/Manual/Smar...tor_manual.rar the description in manual: the" files" bookmark- select the same flash that is in the phone and translate it into one of the languages that are available in the translator: Arabic ,Bulgarian,Catalan,Croatian,Czech,Danish,Dutch,Eng lish,Estonian,Euskera,Farsi,Finnish,French,Gallego ,German,Greek,Hebrew,Tradchinese, Hungarian,Indonesian,Italian,Kazakh,Korean,Latwian ,Lithuanian,Malay,Nederlands,Norwegian,Polish,Port uguese,Romanian,Russian,Serbian,Slovak, Slovenian,Spanish,Swedish,Thai,Turkish,Ukrainian,V ietnamese the bookmark"build"- write the translated language into the phone the whole opertaion takes 3 minutes, the languages are ready to be written into, you don't have to change the software and be prone to damage the phone at the same time. IMPORTANT: selected flash for edition is supposed to be of the same version that is in the phone Benefits you get: -language change in the phones where the change was impossible to be made and serviced by devices available on the market so far -no software damages (BT,Imei,Refleshing,Unable mediafiles,dead phone ;), no problems with network coverage, damaged battery,damaged OTP -impossibility of losing data from the phone -speed and effectivity of working -the only solution of this kind in gsm market -possibility of writing your own languages -creating the languages packages on customers demand |
SmartKey added LG KB770 28/12/2008 Translator SmartKey Translator added LG KB770 28/12/2008 New models added -KB 770 -the service of greater number of models -unpacking language files faster -wirting languages into the phone faster -the phone reset Language change in LG U250,U250C,U300,U300C,U310,U310C,U370,U370C,U370W, U450,U450C,U830,U830C,U960,U970,U970C KC910,HB620,HB620T,CB630,KB620,KB770,KF310,KF311,K F390,KF390Q,KF690,KF700,KF700Q,KF700GO,KU990,KU990 MF,KU990GO, KU990R,KE990,KE990D,KE998,KU250,KU380,KU385,KU450, KU730,KU950,KU960,KU970,U990,U990C,CU515,TU515,CU5 75, TU575,CU720,TU720,CU320,CU400,MU515,MU550,CU405,KU 310,KU311,KU800,KU970,L600V, Language change in LG manual video http://smartkey.eu/pliki/Manual/Smar...eo%20Movie.rar manual http://smartkey.eu/pliki/Manual/Smar...tor_manual.rar the description in manual: the" files" bookmark- select the same flash that is in the phone and translate it into one of the languages that are available in the translator: Arabic ,Bulgarian,Catalan,Croatian,Czech,Danish,Dutch,Eng lish,Estonian,Euskera,Farsi,Finnish,French,Gallego ,German,Greek,Hebrew,Tradchinese, Hungarian,Indonesian,Italian,Kazakh,Korean,Latwian ,Lithuanian,Malay,Nederlands,Norwegian,Polish,Port uguese,Romanian,Russian,Serbian,Slovak, Slovenian,Spanish,Swedish,Thai,Turkish,Ukrainian,V ietnamese the bookmark"build"- write the translated language into the phone the whole opertaion takes 3 minutes, the languages are ready to be written into, you don't have to change the software and be prone to damage the phone at the same time. IMPORTANT: selected flash for edition is supposed to be of the same version that is in the phone Benefits you get: -language change in the phones where the change was impossible to be made and serviced by devices available on the market so far -no software damages (BT,Imei,Refleshing,Unable mediafiles,dead phone ;), no problems with network coverage, damaged battery,damaged OTP -impossibility of losing data from the phone -speed and effectivity of working -the only solution of this kind in gsm market -possibility of writing your own languages -creating the languages packages on customers demand |
SmartKey Translator - updates, history, latest versions Here you can find history of our SmartKey Translator sw. |
