Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SmartKey
Old 09-15-2008, 18:48   #1 (permalink)
SmartKey.eu's Avatar
Member: 721981
SmartKey Translator - updates, history, latest versions
Being the first on the world we would like to show you SmartKey LG QUALCOMM Translator
www.SmartKey.eu
B.R.
SmartKey.eu
The Following 5 Users Say Thank You to SmartKey.eu For This Useful Post:
Old 09-15-2008, 18:53   #2 (permalink)
Member: 721981
Old 09-15-2008, 20:22   #3 (permalink)
Member: 721981
SmartKey editor can write all languages worldwide, including slang. Already existing languages from different phone models can be used as well. It runs as follows:
we can do this in two ways: manually or automatically. If we find a language that has a similar standard in other model, while opening the language file the software will adjust it automatically itself and then it will inform us if the standard is compatible
1. We open the bookmark" files", next " load files" and select the model that is connected to SmartKey
2. We select a language that we need to translate
3. We open" load files" once again and select a flash, we click on it with a right mouse button, then an additional menu will appear and we select " convert language to.." and we select the language in which the software is meant to be written. The software will automatically add an existing language (in this way we can copy the whole language). It looks in the following way: we click on it with the right mouse button, we choose "select all "and then "copy selected to ..."
Then it is enough to come to the " build " bookmark and choose " select setup", then select a language we want to write and exchange in the phone, then we select "build& upload to phone"
Old 09-16-2008, 14:05   #4 (permalink)
Member: 721981
Originally Posted by tsarkh View Post
What about arabic language added to phone which does not contains arabic inside?????
Did any one test it ??
Good flashing for all
hi
Old 09-22-2008, 12:09   #5 (permalink)
Member: 721981
Old 10-06-2008, 09:57   #6 (permalink)
Member: 721981
Vietnamese language needs to be written to this model. Unfortunately, the languge from any other model is not applicable .
1. You select a flash from the support, the best would be the same version that is already written in the phone (Files-Load Files)
2. The number of languages appear and you select the one you want to translate
3. When the translation is ready you can either save the whole project or write it into the phone
4. you enter the bookmark "build" with the phone connected, you select the language that is translated and
the language in the phone you want to change.Then you press "bulid&upload to phone", it takes a few seconds.
Then an information that everything is ok appears ,and you power the phone on.To make the language visible in menu
you need to turn it on, if it was already selected before- you have to turn on any other language from the menu and finally the right one.
Old 10-22-2008, 15:01   #7 (permalink)
Member: 721981
Translator Manual
Translator Manual
"the library&dictionary bookmark"- we provide the access path to the flash with a languages base ,C:\Program Files\SmartKey\LG\library\
it will load the languages base, and we select those we are interested in, we move on to the bookmark Files, then we select
a flash from the support, the best would be the same version that is written into the phone (Files - Load Files), the number of languages
appears to you and you select the one you want to translate.
We can also translate automatically. We press the right button on the mouse, we choose "select all", once again we click with
the right mouse button, then we move on to the "Auto translate select to..." option and then the list of available languages is shown to us and we select
the one we are interested in and we write it in.
With the manual option, on the other hand, we translate each text separately.When the translation is finished you can save the whole project
or write it into the phone. In order to do it we move on to the bookmark "built" with the phone connected , then you select the language that is
translated and you select the language that you want to change.Then you press "build&upload to phone", it takes a few seconds, then the information
taht everything is all right will appear.. Then you power the phone on.To make the language visible in the menu you need to
start it . If it was already selected before you need to turn it on once again with the other language.
The Following 3 Users Say Thank You to SmartKey.eu For This Useful Post:
Old 10-24-2008, 17:56   #8 (permalink)
Member: 721981
SmartKey Translator
-the selection of one or more languages needed for translation
-preparation of other languages in progress
-base of new languages is added, it is enough to click on a selected text,the software will show us
an example of translation in the following languages:
ARABIC
BULGARIAN
CATALAN
CROATIAN
CZECH
DANISCH
DUTCH
ENGLISH
ESTONIAN
EUSKERA
FARSI
FINNISH
FRENCH
GALLEGO
GERMAN
GREEK
HABREW
HKGTRAD CHINES
HUNGARIAN
INDONESIAN
ITALIAN
KAZAKH
KOREAN
LATVIAN
LITHUANIAN
MALAY
NEDERLANDS
NORWEGIAN
POLISH
PORTUGUESE
ROMANIAN
RUSSIAN
SERBIAN
SIMPCHINES
SLOVAK
SLOVENIAN
SPANISH
SWEDISH
TRADCHINES
TURKISH
THAI
TWNTRADCHINESE
UKRAINIAN
VIETNAMESE\
MANUAL VIDEO
http://pl.youtube.com/watch?v=cwYh2l002cY\
http://rs6tg.rapidshare.com/files/15...Translator.rar
Manual
Old 12-14-2008, 15:24   #9 (permalink)
Member: 721981
Thumbs up LG u300,u310,u250,u450,u970,cu720 itd... video manual
Language change in LG U250,U250C,U300,U300C,U310,U310C,U370,U370C,U370W, U450,U450C,U830,U830C,U960,U970,U970C
KC910,HB620,HB620T,CB630,KB620,KF310,KF311,KF390,K F390Q,KF690,KF700,KF700Q,KF700GO,KU990,KU990MF,KU9 90GO,
KU990R,KE990,KE990D,KE998,KU250,KU380,KU385,KU450, KU730,KU950,KU960,KU970,U990,U990C,CU515,TU515,CU5 75,
TU575,CU720, TU720,CU320,CU400,MU515,MU550,CU405,KU310,KU311,KU 800,KU970,L600V,
Language change in LG manual
video
http://smartkey.eu/pliki/Manual/Smar...eo%20Movie.rar
manual
http://smartkey.eu/pliki/Manual/Smar...tor_manual.rar
the description in manual:
the" files" bookmark- select the same flash that is in the phone and translate it into one of the languages that are available in the translator:
Arabic ,Bulgarian,Catalan,Croatian,Czech,Danish,Dutch,Eng lish,Estonian,Euskera,Farsi,Finnish,French,Gallego ,German,Greek,Hebrew,Tradchinese,
Hungarian,Indonesian,Italian,Kazakh,Korean,Latwian ,Lithuanian,Malay,Nederlands,Norwegian,Polish,Port uguese,Romanian,Russian,Serbian,Slovak,
Slovenian,Spanish,Swedish,Thai,Turkish,Ukrainian,V ietnamese
the bookmark"build"- write the translated language into the phone
the whole opertaion takes 3 minutes, the languages are ready to be written into, you don't have to change the software and be prone to damage the phone
at the same time.
IMPORTANT:
selected flash for edition is supposed to be of the same version that is in the phone
Benefits you get:
-language change in the phones where the change was impossible to be made and serviced by devices available on the market so far
-no software damages (BT,Imei,Refleshing,Unable mediafiles,dead phone , no problems with network coverage, damaged battery,damaged OTP
-impossibility of losing data from the phone
-speed and effectivity of working
-the only solution of this kind in gsm market
-possibility of writing your own languages
-creating the languages packages on customers demand
Old 12-28-2008, 13:20   #10 (permalink)
Member: 721981
SmartKey added LG KB770 28/12/2008 Translator
SmartKey Translator added LG KB770 28/12/2008
New models added
-KB 770
-the service of greater number of models
-unpacking language files faster
-wirting languages into the phone faster
-the phone reset
KC910,HB620,HB620T,CB630,KB620,KB770,KF310,KF311,K F390,KF390Q,KF690,KF700,KF700Q,KF700GO,KU990,KU990 MF,KU990GO,
TU575,CU720,TU720,CU320,CU400,MU515,MU550,CU405,KU 310,KU311,KU800,KU970,L600V,
video
manual
at the same time.
IMPORTANT:
Benefits you get:
Old 01-25-2009, 17:32   #11 (permalink)
Member: 721981
Here you can find history of our SmartKey Translator sw.
SmartKey KE - updates, history, latest versions gsminfo SmartKey 8 02-13-2010 12:24
Universal box cannot update to latest version AbdulKadir Universalbox 2 07-29-2009 21:44
SmartKey Qualcomm - updates, history, latest versions DZStorm SmartKey 14 01-25-2009 17:28
SmartKey Translator/Repair/Unlock On Youtube SmartKey.eu GSM News & Updates 0 10-26-2008 13:13
Nokia Griffin Box Clone Free Update To Latest Version 2.895!!! techgsm Main Sales Section 0 10-03-2005 08:29
Page generated in 2.73087 seconds with 11 queries
