PadFinder box Smart universal box for Chinese phones ( for all phones ) with automatic pinouts search functions. |
06-26-2009, 08:00 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Afrique du sud Age: 42
Member: 430612 Status: Offline Thanks Meter: 301 | Padfinder cant connect with phone Profile file not exist! Default file will be created Reconnecting power...OK Press and hold power on button...Timeout! Reconnecting power...OK Press and hold power on button... Box communication timeout! Please check connections and reset box Reconnecting power...OK Press and hold power on button... Box communication timeout! Please check connections and reset box Reconnecting power...OK Press and hold power on button...Timeout! Profile file not exist! Default file will be created Reconnecting power...OK Press and hold power on button...Timeout! Reconnecting power...OK Press and hold power on button...Timeout! Profile file not exist! Default file will be created Reconnecting power...OK Press and hold power on button...Timeout! Reconnecting power...OK Press and hold power on button...Timeout! Reconnecting power...OK Press and hold power on button... Box communication timeout! Please check connections and reset box Reconnecting power...OK Press and hold power on button... Box communication timeout! Please check connections and reset box please help me best way to connect padfinder with chinese model or do i need multi box? |
06-29-2009, 15:12 | #7 (permalink) | |
Crazy Poster Join Date: Sep 2006
Member: 346364 Status: Offline Thanks Meter: 12 | Quote:
Solder better crocodile power connectors. Check black & red conn. for contact with wire. 100% it will helps You. | |
06-30-2009, 17:36 | #8 (permalink) |
Freak Poster Join Date: Jun 2005 Location: indonesia
Member: 154427 Status: Offline Thanks Meter: 61 | i have to try but no luck.. i try to question with my reseller but no answer.. i buy this box 5 mounth ago but until now i cant make money with this box. i have Pinfinder and woking find... |
06-30-2009, 22:50 | #9 (permalink) | |
No Life Poster Join Date: Mar 2001 Age: 44
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | Quote:
2. Read support docs before cry there | |
07-01-2009, 04:02 | #10 (permalink) | |
Member: 154427 Status: Offline Thanks Meter: 61 | Quote:
1. I buy this box to repair chinese phone soft but until 5 month i cannot used this box,so i cant get money from this box. 2. I have to read and follow instruction but still same result(cannot connect),even with normal phone.but with PINFINDER i can make it... your answer only READ FAQ,READ FAQ......that not SOLUTION | |
09-05-2009, 15:24 | #11 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Brazil Age: 43
Member: 48037 Status: Offline Sonork: edermix Thanks Meter: 21 | Instead of sending your customers to read the manual should help you giving information so that the problem is resolved. I myself also did read the manual and have the same problem it seeks to pinout 100% more to connect can not succeed without a friend then use your time by helping the User of your device. Detecting pinout: please press and HOLD power button! (Push box button to Abort) Processing, please wait...OK Rx - 1 Tx - 7 Reconnecting power...OK Press and hold power on button...OK Loading Boot.... Box communication timeout! 6 Please check connections and reset box |
samsung(usb-smart) cant connect to phone | crossroads | Samsung (USB-Smart) | 2 | 06-09-2006 06:12 |
cant connect to phone | davidjollie | Smart-Clip | 1 | 07-22-2005 13:21 |
cant connect my phone via nokia pc suite using bluetooth | Koponen | Bluetooth-Software | 1 | 05-08-2005 18:58 |
my twister box cant connect to phone.... | josaix | Twisterflasher | 2 | 12-06-2004 19:51 |
Emmi Droid Box detected but cant connect to Phones | kingbode | Motorola Old Legacy (EMMI) | 2 | 05-31-2003 17:26 |
