All UnlockByLogs Server UnlockByLogs.com |
03-27-2008, 15:19 | #1 (permalink) |
Product Manager Join Date: Nov 2007 Location: @Unlockbylogs (Direct 555+)
Member: 637358 Status: Offline Sonork: 100.112299 Thanks Meter: 741 | >>Fenix Logs Instant For SonyEricsson Permanent Unlock << Fenix Accounts for SE Unlocking Available Instant with UnlockByLogs.com Server 05 Phones Account : 250 Logs x 20 Euro Each = 100 Logs ( 100 Euro ) 10 Phones Account : 500 Logs x 18 Euro Each = 180 Logs ( 180 Euro ) Instant Account Activation Supported Phones Z310, D750, K310, K320, K510, K530, K550, K550im, K600, K608, K610, K610im, K618, K750, K758, K770, K790, K800, K810, K850, K880, M600, P1, P910, P990, S500, T650, V600, V630, V640, V800, V802, W200, W300, W550, W580, W600, W610, W660, W700, W710, W800, W810, W830, W850, W880, W888, W900, W910, W950, Z310, Z520, Z530, Z550, Z610, Z710, Z750, Z800 It means that you phone will be unlocked forever, whether you flash it with SEUS or Davinci software or any other tool. We can unlock ANY db2020 phone with ANY CID inside from ANY network including CID52, CID53 ! Price is 20 credits per one phone unlock. Requirements: the latest client software standard DCU60 or DCU65 usb cable Manual: Preparation: Download and extract phone and USB flash drivers from hereDownload Switch on the mobile Plug in the USB cable and your computer will find NEW hardware Install the drivers as per the tutorial here : Unplug the USB cable from the mobile RESTART PC before installing the USB Flash drivers After Restart install USB Flash drivers by takeing out battery and then put it in again and then press C when plugging cable. Unplug the cable, remove and insert the battery back Unlock Step 1: Start client.exe (of course ensure you have purchased credits before hand - ) Whilst pressing "C" plug the USB (or holding 2 in case of W880) Mobile authentication starts .. Then you get a screen to choose service choose Unlock Step 1 A DVL file is generated and sent directly to the system and then you have to wait between 1 min to max.24h (all depend by how many pcs is in server, because is calculated one by one) You can check unlock status here: http://www.gsmunlock.eu Unlock Step 2: When you get the email that your MAP is ready (or you see MAP READY status at CIS webpage) Make sure the mobile is switched off Start client.exe Holding C plug the cable into the mobile (or holding 2 in case of W880) When you get the services screen, scroll down and in bold red you will see the next step to unlock - press it Then it will tell you to take out cable and switch on the mobile, take out battery, put it back in, and then switch it on and choose "Normal Mode", then plug in the USB Cable, ignore if it Says incorrect SIM It will continue the process and soon enough you are ready If the process somehow hangs, remove cable, shut down the client. Then turn the phone on (it will have Insert Correct SIM Card message), run client again, connect the cable to powered phone. Select CSCA Activation script from the list of scripts. B.R., UnlockByLogs Team Last edited by viru; 03-27-2008 at 15:44. |
>> BB5 Movistar SL3 and SL2 INSTANT Codes, Motorola INSTANT Codes, BB NEW SECURITY << | AtrixJ | Main Sales Section | 0 | 09-07-2009 10:37 |
Final Solution For SonyEricsson J100 Unlock+Flash+Repair imei | ufuktakiadam | Sony Ericsson | 0 | 05-18-2009 13:02 |
!!! D-Client - World Cheapest solution for SonyEricsson DB2020 unlocking !!! | Mizar | Main Sales Section | 0 | 09-08-2007 06:21 |
best box for sonyericsson flash/unlock | sonetek | Sony Ericsson | 1 | 07-18-2006 23:36 |
