07-16-2008, 17:07 | #3 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 54
Member: 105625 Status: Offline Thanks Meter: 44 | I strongly advice you to NOT put TornadoSIM in the iPhone. I did try it, and the card is stuck inside. I have spent an hour trying to get it out now, without success. This is the exact same thing happened when i tried it in a SE K850i. Before i tried TornadoSIM i tried YesSIM with many different settings, but i didn't get signal on any setting. So i don't think these cards will work. Both Yessim and tornadoSIM bypasses the simlock, getting signal is the problem. |
The Following User Says Thank You to James_S For This Useful Post: |
07-17-2008, 11:00 | #4 (permalink) |
No Life Poster Join Date: Oct 2003 Age: 47
Member: 41491 Status: Offline Thanks Meter: 28 | it depends on how you piggyback the sim with the Tsim inside... better use double adhesive to be safe.. thats what i did before and no problem.. BUt now dont have a iphone 3g yet to test .. so those who has, pls give it a shot and post results... Thanks. |
07-17-2008, 17:26 | #5 (permalink) |
Member: 105625 Status: Offline Thanks Meter: 44 | Problem is that even if it works, I would never sell TornadoSIM to customers when there is a risk that it gets stuck like it did with me. I got it out finally (in pieces), but i have many scratches at the top of the phone, and the tray is also little damaged. I'm just lucky the SIM reader still works... |
07-18-2008, 20:55 | #6 (permalink) | |
No Life Poster Join Date: Jan 2004 Age: 45
Member: 49581 Status: Offline Thanks Meter: 73 | Quote:
i did use double side tape, but it just stuck inside ... i am lucky that the reader also works, but the mechnism that push the SIM Tray is now not working .... damn damn damn ... | |
07-18-2008, 22:10 | #7 (permalink) | |
Member: 105625 Status: Offline Thanks Meter: 44 | Quote:
I think a solution could be to use tape around the top of the tray, so that the chip is covered with tape. But i'm not going to try that and risk my iphone again. | |
07-19-2008, 23:26 | #8 (permalink) | |
i fixed the switch already .... had to make another one, gladly that I was a Dental Technician, so i can duplicate from another iPhone ... i am going to try another time, since my iPhone is disassembled already, so i am not afraid to be stuck again .... but too busy these days, i will give it a try later when i hv time ... but same thing here, even it works, i will not sell it too .... Last edited by gwaai; 07-19-2008 at 23:31. | |
07-20-2008, 01:18 | #9 (permalink) |
Member: 49581 Status: Offline Thanks Meter: 73 | UPDATE: tested on Rogers iPhone 3G, I use real MccMnc, got signal on FIDO, can call out, but not receive call, when ppl call, it just seems to be offline, but call out no problem. gotta go home, try more tomorrow tested with Real MccMnc, with first tick, Real + 2 ticks, real + 3 ticks ... all same result ... |
07-24-2008, 21:09 | #11 (permalink) | |
Freak Poster Join Date: Nov 2004
Member: 90106 Status: Offline Thanks Meter: 3 | Quote:
~Cheers~ | |
07-27-2008, 01:07 | #13 (permalink) |
Member: 49581 Status: Offline Thanks Meter: 73 | you have many post saying you have solution, and not sharing?? I didn't test with any other provider's iPhone, only TESTED and WORKING with Rogers or FIDO iPhone [PRESET] PRESET_NAME = "iPhone 3G" PRESET_IMSI = "001010123456789" PRESET_MASK = "111110000000000" PRESET_FAKE = "10000000000000000000000000000000" since mySIM doesn't have 3G, so I have to disable 3G option in iPhone, it is under Setting,->Network if I didn't disable 3G option, i cannot receive call, but call out no problem, when 3G option is disable in iPhone, all is working ... even after 48 hours, still running good ... don't blame me if not working good, i only tested on FIDO and ROGERS iPhones .... sold many Tornado SIM already, no complain yet ... Remember, my setting needs to disable 3G in iPhone, if someone has better solution that able to use 3G, use it then ... |
07-27-2008, 01:33 | #15 (permalink) |
Member: 49581 Status: Offline Thanks Meter: 73 | and again since iPhone 3G has thinner slot for SIM card, if you put ur SIM and T-SIM together into it, it will be a headache to take it out ... better way is to: 1. use double side tape to tape the SIM and T-SIM together, especially the TOP and BOTTOM, so it will not bend easily 2. trim you SIM a little bit, so it have an angle at the TOP, so when you wanna take the SIM out, it will not stuck. 3. better way, trim all SIM surface, so it become thinner |
what about A2 modle any news about | wisam_wa | DreamBox | 1 | 04-18-2008 00:32 |
Any news about T191 ver 1.87 ??? | mr_x4you | Motorola ODM | 0 | 09-19-2002 21:58 |
ANY news about MT 50 | G$M solution | x1x to x45/x50 | 0 | 05-31-2002 06:21 |
Any news about flashing Micron flash in new L01 Mars | misel | Mitsubishi | 5 | 04-17-2002 01:29 |
Any news about m3188 ? | SFlood | Motorola Old Legacy (EMMI) | 0 | 09-13-1999 11:12 |
