03-29-2008, 23:07 | #16 (permalink) |
No Life Poster Join Date: Sep 2001 Location: GSM-TOOL Age: 52
Member: 6328 Status: Offline Thanks Meter: 3,595 | BUT EVEN THEN: There is NO PROBLEM to change the FAKE IMSI Just edit MccMnc (first 5 digits) to 00101 or the network code of the network where the phone is locked to, and the rest 10 digits put whatever you like. Also - using the IMSI MASK - the digits that you place as 1 will be replaced with the ones you write in FAKE IMSI Field, and the digits of the IMSI that you mask with 0 will be taken from the SIM CARD that you put together with the TORNADOSIM to the phone ... HERE IS ALL AGAIN DESCRIBED: http:///vbb/showpo...77&postcount=4 “REAL” MccMnc in FAKE IMSI Seems some operators DON'T accept IMSI like 0123456789 ... so you better use this trick if other options don't help Any OPERATOR SIM (the one you get as contract or prepaid card) is “asked” at phone startup for the IMSI. The IMSI (International Mobile Subscriber Identity) is a unique 15-digit code used to identify an individual user (his SIM CARD actually) on a GSM network. In the IMSI, the first 5 digits are the Mobile Country Code – MCC and the Mobile Network Code – MNC. This MCC / MNC code is used by the simlocked phone to check if the inserted card is accepted or not. What all this unlocksim was doing untill now was to send when “asked” about the IMSI, the MCC/MNC as 00101, and many phones takes this as accepted card and continue then theyr boot up and start working… If anything you tried untill now don’t work, then it is a posibility that the specific model of phone don’t work with MCC/MNC like 00101 in the IMSI. On some phones you can use software to read to what operator the phone is locked too, or if you know allready this – just check the attached MCCMNC archive that contains this information for the specific countrys and operators. Then you can customize more, by programming the TORNADO SIM to send to the phone the MCCMNC of that network that is locked to, so it will accept the card as own card.. “REAL” IMSI digits in FAKE IMSI Seems some operators like TIM ITALY - DON'T accept IMSI like 0123456789 ... so you better use this trick You can also customise the TORNADO SIM to send the rest of the IMSI (except the MCC/MNC part) the correct one from the card that will be used in that phone. Just use the menu ACTION à READ IMSI in the TORNADO SIM software and put the operator SIM that you want to use in that phone together with the TORNADO SIM in the programming dongle. Then just change the MCC/MNC Data to 00101 or to the ones for the network where the phone is locked too and program the card. From now on the Tornado will send to the phone when asked IMSI for simlockcheck the IMSI consisting of MCCMNC you have programmed and the rest of the correct card IMSI . IMSI MASK put also to 111110000000000 This will make the TORNADOSIM to send the first 5 digits from the FAKE IMSI field + the rest of the REAL IMSI (digits nr6 to 15) as FAKE IMSI to the phone. regards, Gobi P.S. We know about that problems with few networks/ sim cards that after some time loose signal - and we are working on that too |
03-31-2008, 07:52 | #17 (permalink) |
Freak Poster Join Date: Dec 2004 Age: 42
Member: 101262 Status: Offline Thanks Meter: 8 | Only for Romanian ppl. [PRESET] PRESET_NAME = "Vodafone810-Gigi_Kent" PRESET_IMSI = "001010123456789" PRESET_MASK = "111110000000000" PRESET_FAKE = "11110110000000000000000000000000" Vodafone-make call OK,not recieving Orange-all OK Cosmote-Not tested |
03-31-2008, 09:50 | #18 (permalink) |
No Life Poster Join Date: Jan 2004 Location: romania Age: 48
Member: 48215 Status: Offline Thanks Meter: 19 | for w200i [PRESET] PRESET_NAME = "W200I BY CRYSST" PRESET_IMSI = "001010123456789" PRESET_MASK = "111111100000000" PRESET_FAKE = "11111110000000000000000000000000" |
03-31-2008, 16:06 | #19 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | Worth to be tested also by other customer for U900 phones. Reported working by danr00: [PRESET] PRESET_NAME = "LG U900" PRESET_IMSI = "001010123456789" PRESET_MASK = "111110000000000" PRESET_FAKE = "10000000000000000000000000000000" Worked after flashing using VygisToolbox and this file: cu asta U900_V11g-H3G-IT[ORIGINAL]-EN_IT_GER_FR_SW_DA regards, Gobi |
03-31-2008, 16:23 | #20 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | Tested by alianu: [PRESET] PRESET_NAME = "BlackBerry 8320 alianu" PRESET_IMSI = "001010123456789" PRESET_MASK = "111110000000000" PRESET_FAKE = "10000000000000000000000000000000" regards, Gobi |
03-31-2008, 19:58 | #21 (permalink) |
No Life Poster Join Date: Oct 2005 Location: ROMANIA
Member: 188484 Status: Offline Thanks Meter: 117 | vodafone 810 unlocked ok vodafone orange cosmote wuth this preset. [PRESET] PRESET_NAME = "vodafone 810" PRESET_IMSI = "001010123456789" PRESET_MASK = "111110000000000" PRESET_FAKE = "01100000000000000000000000000000" |
04-01-2008, 19:19 | #22 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | In order to keep this at TOPIC, i will keep it closed. @Romanian customers Please post tested stuff in the FEEDBACK THREAD, and i will copy it also here http:///vbb/showthread.php?t=518116 thx, Gobi |
04-01-2008, 23:30 | #23 (permalink) |
Freak Poster Join Date: Apr 2005 Location: romania Age: 46
Member: 135188 Status: Offline Sonork: 81798 Thanks Meter: 9 | [PRESET] PRESET_NAME = "6120c mobiserv-all ro" PRESET_IMSI = "001010123456789" PRESET_MASK = "111110000000000" PRESET_FAKE = "11000000000000000000000000000000" [PRESET] PRESET_NAME = "lg u970-3au mobiserv" PRESET_IMSI = "001010123456789" PRESET_MASK = "111110000000000" PRESET_FAKE = "11101111111110000000000000000000" |
04-02-2008, 08:57 | #24 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | ONE MORE SETTINGS TESTED BY SCRISTEFAN. If with the N95 you loose signal after some time, please use this one: [PRESET] PRESET_NAME = "6120c scristefan" PRESET_IMSI = "001010123456789" PRESET_MASK = "111110000000000" PRESET_FAKE = "10000000000000000000000000000000" Last edited by Gobi; 04-02-2008 at 09:08. |
04-02-2008, 09:03 | #25 (permalink) |
Freak Poster Join Date: Jun 2001 Location: Romania Age: 53
Member: 4875 Status: Offline Thanks Meter: 9 | Problemm with LG U310 I did make the presets like alunecosu_hd told and I did 566366#*# and the FA 10850 setting. The phone still have no good signal and after I did entered in the 566366#*# Factory Settings the PHone have no signal anymore. So with LG U310 if u are in a good signal strong signal area maybe the phone will work but can not say for how long but if the signal from the operator becomes low power then the phone might lose the netorw and never gain back. I have a 3 card from Italy the original card and the phone enter in Roming and have signal on Vodafone and Orange, Romania. So the phone is not damaged but some setting are no good enough. I will post some results with Sagem W8 also couse there is also problems with the signal. For shure TSIM work great with BlackBerry 8*** series I did tested an a 8700 a 8320 with this presets Preset IMSI: 00101 then 10 digit of ORIGINAL IMSI or 0123456789 (better use the original part of IMSI Preset MAsk : 111110000000000 Preset Fake : 10000000000000000000000000000000 Keep testing and I will post the results. Best regards u all, alianu. |
04-02-2008, 18:43 | #26 (permalink) |
Banned Join Date: Apr 2005 Age: 52
Member: 135599 Status: Offline Thanks Meter: 14 | Lg U370 Disney Mobile Preset [preset] Preset_name = "lg U370 Prologic_gsm" Preset_imsi = "001010123456789" Preset_mask = "111110000000000" Preset_fake = "10110000000000000000000000000000" |
04-03-2008, 08:45 | #27 (permalink) |
Junior Member Join Date: Sep 2001 Location: ROMANIA
Member: 6556 Status: Offline Thanks Meter: 1 | K530i settings Tested cu Vodafone,Orange,Cosmote Ro [PRESET] PRESET_NAME = "K530i Adi M" PRESET_IMSI = "001010123456789" PRESET_MASK = "111110000000000" PRESET_FAKE = "11111111111000000000000000000000" |
04-03-2008, 09:38 | #28 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | tested by Horiadxt PRESET-NAME =SE V630 horiadxt BODEA: PRESET_IMSI = "001010123456789" PRESET_MASK = "111110000000000" PRESET_FAKE = "11111111111111111111111111111111" |
04-03-2008, 10:57 | #29 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | Tested by Tokes Endre Blackberry 8700 [PRESET] PRESET_NAME = "BlackBerry 8700 Tokes Endre" PRESET_IMSI = "001010123456789" PRESET_MASK = "111110000000000" PRESET_FAKE = "10000000000000000000000000000000" USE THE REAL MccMnc of the network where the Blackberry is locked to - in the FAKE IMSI FIELD. This is recommanded for all Blackberry and Vodafone 810 unlock.. regards, Gobi |
04-03-2008, 12:17 | #30 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Narnia Age: 44
Member: 236667 Status: Offline Thanks Meter: 12 | Blackberry 8700v vorks only if you use the first 5 digits of Mcc Mnc where phone locked to and the rest of digits (6-15)you read out the IMSI from Sim card you vant to use.Combine this two together in the preset Fake.This is only for BB 8700v(vodafone).The others works as above |
looking for job (repairin phones) in romania | paintman | Job Opportunities / Vacancies | 3 | 09-03-2009 16:08 |
Smart Test Point Cable in ROMANIA | gsm9l | Wanted Products | 3 | 10-19-2007 17:25 |
Easy-Unlocker in-stock ready to ship in Romania | GSM Brothers | Main Sales Section | 0 | 11-29-2006 07:27 |
