| | #1 (permalink) |
| Product Supporter Join Date: May 2007 Location: Italy, Romania
Member: 499855 Status: Offline Thanks: 6
| Tornado SIM Not Found -Solution !! Here solution for " Tornado Sim not Found ". Use Tornado SIM v4 here and frrmware 2.02 (in attachment) 1. Open Tornado SIM v4 2. Insert in programmer Tornado sim + original sim 3. Action - Update firmware- select 2.02 firmware. Working in 90% cases Regards Techgsmnet Last edited by Gobi; 09-16-2008 at 08:13. |
| The Following 3 Users Say Thank You to Techgsmnet For This Useful Post: |
| | #4 (permalink) |
| Product Supporter Join Date: May 2001
Member: 4566 Status: Offline Sonork: 100.112355 Thanks: 15
| Tornado SIM Not Found: This happens when u update to firmware 2.07. Don't worry, your tornado sim was not dead, it just only need write to your desired settings. Write settings when failed, give a try few more times or unplug-replug usb card reader/writer. Also, this was reported with PC's using AMD and P3 processors. In some cases, it might be because of loose contact between the card reader/writer and tornado sim. Might as well, cut the the simcard slot of the usb card reader/writer like this: |
| The Following User Says Thank You to ren77 For This Useful Post: |
| | #6 (permalink) |
| Product Supporter Join Date: Jan 2005 Location: www.chiragp.com Age: 30
Member: 106367 Status: Offline Sonork: 1577436 Thanks: 106
| @tech On Tornado _4 [protection CARD Not Found ] New Version Working Fine Thanks Need Help |
| | #8 (permalink) |
| Product Supporter Join Date: Sep 2006 Location: georgia tbilisi Age: 32
Member: 341988 Status: Offline Thanks: 0
| 95% mobile phone supported there only pats of the supported models : http://yupiteri-gsm.com and my be we not have tested too for all handsets becouse 3 day ago i am perfect simple has try unlock smartphone XDA pola 200 (no free solution) and unlocked ok too with tornadosims , also some next smartphone too and tornadosims worked with 95 96% of models and we not test yet many brand too so tornadosims are best product B. R. http://yupiteri-gsm.com team |
| | #9 (permalink) |
| @yupiteri-gsm It would be nice for you to post those tested unlocked phones together with the presets you used, for others preference. BR, Ren |
| | #10 (permalink) |
| No Life Poster Join Date: Apr 2002 Location: Tutuban Age: 55
Member: 10635 Status: Offline Thanks: 2
| yes theres problem with 207 firmware, how to make this usable again?... Cannot run Tornadosim V4.. error "Protection card not found" but on tornadosim V4 on 206 folder working.... whats wrong on latest firmware release...?? BR, epic |
| | #11 (permalink) | |
| No Life Poster Join Date: Dec 2006 Location: iHotCake.com
Member: 420857 Status: Offline Sonork: 100.1576793 Thanks: 77
| Quote:
but my model is Toshiba 705T i try it not done what problem? | |
| | #13 (permalink) |
| Freak Poster Join Date: Jul 2001 Location: Malaysia Age: 48
Member: 5183 Status: Offline Thanks: 0
| I also facing problem with 207 firmware (Tornado Sim Not Found) Try to recover many times with v4 on 202 fimware but failed If try a new tornado sim with V4 on 206 firmware working without problem I don't try anymore with 207 firmware bcos i hv try 3pcs with 207 and now cannot be recover,is there any other solution to fix it..! |
| | #14 (permalink) |
| Try these: - using PC with P4 processor - write settings few more times - unplug - replug usb card reader/writer - try another simcard together with that tornado sim BR, Ren |
| | #15 (permalink) |
| Freak Poster Join Date: Jan 2002 Location: Enschede, The Netherlands Age: 27
Member: 8594 Status: Offline Thanks: 5
| With the tornado sim cardreader (v01 2007-10-24) I get not found almost every time. My current solution is to use the cardreader inside BB5Box. It works perfectly fine and I didn't get one error ever since. So it seems there is something wrong with this tornado sim cardreader. Do you have it's schematics? I could check for differences and maybe fix this reader. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Tornado SIM NOT FOUND!!! | wiky | TORNADO - SIM | 7 | 09-06-2008 20:55 |
| After 2.07 Update Tornado Sim Not Found | tikal | TORNADO - SIM | 12 | 08-11-2008 13:49 |
| hiii what solution for sim not found | mbourtelephone | TORNADO - SIM | 1 | 07-25-2008 17:39 |
| Tornado SIM not Work with Movistar Sim Mexico | gniusmx | TORNADO - SIM | 0 | 07-20-2008 21:08 |
| Tornado sim not found no work any solution | Miftahudin | TORNADO - SIM | 9 | 05-11-2008 10:58 |
