Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Support (SIM Solution) > TORNADO - SIM
Old 12-04-2008, 21:09   #1 (permalink)
Member: 289563
Verizon Blackberry Storm 9350 Unlocked!
Today I went to the store and played with a Verizon Blackberry Storm demo phone to see if I could get Tornado SIM to work with it.
After after an hour or so I finally landed on a working firmware and setting combination. An important note about this Verizon phone is that is not network locked. It is SIM locked to the Vodafone sim that comes with the phone. This means that you must read the original IMSI from the SIM that the phone came with, and use the entire number.
Firmware: v2.15
Fake IMSI: Use Original IMSI From Verizon/Vodafone SIM
IMSI Mask: 111111111111111
Sequence: 010000000000000000000000
I was able to use my T-Mobile USA SIM and successfully make and receive calls. EDGE data also appeared to work fine. I didn't have a whole lot of time to play with it but it did appear to be stable for about 15 mintues before I had to leave and give the phone back.
I did notice while mucking around with the settings that I was getting a network error every time I booted up the phone, even when using the settings above. After I removed my T-Mobile SIM and put it back in my normal phone, and then put it back in the Storm, I was able to get everything working.
At this point I would say that it works somewhat, but it could definitely use some improvements in stability.
The Following 2 Users Say Thank You to .-=Omikron=-. For This Useful Post:
Old 12-05-2008, 19:01   #2 (permalink)
Member: 289563
Sorry guys, I had a typo with the model number. The Storm is the BlackBerry 9530, not the 9350.
Old 12-08-2008, 07:11   #3 (permalink)
Member: 542009
Firmware: v2.15
with that setting,call out ok,but can't received call
Old 03-02-2009, 21:33   #4 (permalink)
Member: 985093
Question
Did BLACKBERRY STORM 9350 was having sim card slot to put sim in? Because Verizon us CDMA technology and they phones do not even have slot for sim card!?
Old 03-02-2009, 21:52   #5 (permalink)
Member: 289563
The Verizon Storm does indeed have a SIM slot and a quad-band GSM radio. It is the only Verizon phone that I can think of that has this feature.
However, it is SIM locked to the specific Vodafone SIM that comes preinstalled, so you'll have to use the IMSI from that sim.
Old 03-04-2009, 21:21   #6 (permalink)
Member: 985093
I just bought on eBay exactly phone like you say Blackberry Storm 9530 with Verizon vodafone sim card in it (seller scammed me advetizing new unlocked phone and send me all screched derty sully minimum 5 month phone).
But any way can you guide me step by step how unlock it?
Keep in mind that i am born yestarday and do not know you slang as :
original IMSI from the SIM that the phone came with, and use the entire number.????????????????
Firmware: v2.15 ???????????????
Fake IMSI: Use Original IMSI From Verizon/Vodafone SIM ???????????????
IMSI Mask: 111111111111111 ??????????????
Sequence: 010000000000000000000000 ??????????????????????
I just tell you what i have:
on this verizon wireless vodafone simcard itself 3 levels of numbers:
1 level 032i010
2 level 8931440000
3 level 630966972
then under battery in the phone itself
PRD-19502-002 BlackBerry 9530 RBW71CW
IC: 2503A-RBW70CW
FCC ID : L6ARBW70CW
BT MAC : 00 23 7A F2 62 1D
MEID HEX:A000000D07EED3
some barr code
pin: 304FE2D9 8C8 Made in Mexico 5
Old 03-04-2009, 21:25   #7 (permalink)
Member: 985093
Heeeeeeeeeeeeeeeeeelp
It will be realy helpful if you define all your hi tech slangs and put my numbers as example and step by step what to do?:conf used::conf used:
Old 03-04-2009, 21:28   #8 (permalink)
Member: 985093
1 level 032i010
2 level 8931440000
3 level 630966972
IC: 2503A-RBW70CW
FCC ID : L6ARBW70CW
some barr code
9530 verizon blackberry unlocking done with mx rajesh_ch MXKEY Blackberry Flasher and Unlocker (by Alim Hape) 0 03-29-2010 11:57
Blackberry Unlock Codes (MEP code): Unlock Blackberry Storm, Bold, Curve, Pearl ..::: Naveed :::.. Main Sales Section 0 07-18-2009 20:10
I need by blackberry storm 9530 unlocked ill trade lg world b2b AZBMXRIDER18 Exchange Section 1 04-02-2009 14:44
Blackberry storm 9530 unlock price -luigi- All UnlockByLogs Server 23 03-31-2009 20:05
Blackberry Storm 9500 unlocking in Australia - First 5 ppl are FREE!!! xaviertidus BlackBerry (RIM) 8 01-17-2009 04:49
Page generated in 0.35923 seconds with 11 queries
