Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #61 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2005 Location: Karor lal eason Age: 33
Member: 151792 Status: Offline Thanks: 32
| help tp upgrade dongle ----------Dongle upgrade started:1:05:52 PM---------- Locating Emeralda server... Emeralda server found! Connecting to Emeralda server... Server connection successfully established. Authenticating on server... Authentication stage error: Server reported error:No more upgrade logs. |
| | #62 (permalink) | |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: May 2008
Member: 765141 Status: Offline Thanks: 2
| Quote:
| | #63 (permalink) |
| first of all i installn main exe 3.00, then 3.14 , run dongle egate driver xp,connect dongle with pc, driver install successfully,run dongle upgrade tool, upgraded dongle success,run NFF.exe "NOKIa fault finder" arrived, after some time main set up arrived "LOADING" and when dongle seriel no came it vanished.after that i upgrade dongle again,then Dongle upgrade started:1:05:52 PM---------- Locating Emeralda server... Emeralda server found! Connecting to Emeralda server... Server connection successfully established. Authenticating on server... Authentication stage error: Server reported error:No more upgrade logs[/COLOR] i un instal egate driver remove dongle ,connect again,driver instal autometically,then i run NFF,exe b ut same problem. please help |
| The Following User Says Thank You to aswadsaad988920 For This Useful Post: |
| | #64 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2006 Location: Gpg MobileLab-Kerala-India Age: 35
Member: 351924 Status: Offline Sonork: 100.1581941 Thanks: 494
| Quote:
THIS EMAIL ADDRESS----------support@nff-box.com BUT MY OPINION UR DONGLE UP TO DATE NO NEED UPDATION? U FACCED ANY PROBLEM WITH OUT UPGRADING? POST RESULT | |
| | #65 (permalink) |
| i also pm my dongle serial no to support@nff-box.com but no reply came yet |
| | #66 (permalink) |
| i also instal fresh window xp servis pack 2, i have HP dv6000 latest laptop with Vista also, i try with vista , but same result, means ,when run NFF.exe NFF logo appear, then set up appear :LOADING" written and when dongle serial no appear suddenly it vanished |
| | #67 (permalink) |
| Prob. solved with the help of "KUKU" via phone. Thanks , alot of thank KUKU. solutioin: instal main set up 3.0, then 3.14, connect UFS, instal driver from c:/program/nff/driver/ufs driver , then instal egate driver setup of vista from c:/program/nff/driver/ egate driver/vista setup. then connect nff dongle with pc, it will ask driver ,either driver will be install auto or give the driver .now remove dongle then connect again, run NFF.exe every thing is ok |
| | #68 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2001 Location: Planet EARTH Age: 39
Member: 3194 Status: Offline Thanks: 10
| ---Dongle upgrade started:18:38:13---------- Locating Emeralda server... Emeralda server found! Connecting to Emeralda server... Connection to server failed: Socket Error # 10065 No route to host. i have turn off my firewall. help |
| | #70 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2007 Location: 2697b03f Age: 33
Member: 568700 Status: Offline Thanks: 192
| ----------Dongle upgrade started:11:25:37 PM---------- Locating Emeralda server... Emeralda server found! Connecting to Emeralda server... Server connection successfully established. Authenticating on server... Authentication stage error: Server reported error:Authentication failed! Check your password. If it is ok - contact your reseller. dongel id:BEFD132D3123CC483AB7DD2B cenkx_@yahoo.com.sg |
| | #71 (permalink) | |
| Quote:
help help mr ........................... | |
| | #72 (permalink) | |
| Quote:
| | #75 (permalink) |
| Junior Member ![]() ![]() Join Date: May 2007
Member: 514089 Status: Offline Thanks: 0
| Hello, i have the same problem. I canīt open the software. I install and reinstall the software and drivers 3 times and always the same result : The Software open for 2 seconds and then closed it... -I use main software 3.0 then updated to 3.14 - the dongle is upgraded to 2.0 Please help me, i have some phones to test. What can i do to run the software! THX t00sTr0nG |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Phones which have problems with JAF No Tp By Cinek, please post here | defa | JAF No Tp Unlocker by Cinek | 65 | 04-07-2009 00:38 |
| If you have a problem with your hwk (No more upgrade logs) post here !! | Supplier4unlock | HWK | 8 | 06-21-2008 06:05 |
| why all ust pro2 users having problems with it | ghost_team | UST Pro II | 10 | 08-26-2006 22:42 |
| i have problem with c55 if i open mobile say Wrong Software | gsm4libya | SIEM Service Tools | 4 | 01-20-2006 21:58 |
| Top sagem DD Team & to all user having problems with bootloader failed(Sticky please) | djyash | SAGEM JTAG UNLOCKER | 1 | 12-02-2005 09:39 |
