Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Nokia Fault Finder Box
Old 06-17-2008, 07:19   #1 (permalink)
sagtel's Avatar
Member: 597666
NFF software not open after upgrade / install 1.90
what is this NFF team ??????????
helloooooooooo.... solve this problem ok.........
very bad support team....
Old 06-17-2008, 10:11   #2 (permalink)
Member: 765141
what do you mean very bad support team ?
you post here problem once and you immediately call us bad ?
anyways
make sure the NFF.exe is in capital
if its nff.exe it will not open , you will need to rename it to NFF.exe
NFF.exe ( NFF should be in capital letters)
Old 06-17-2008, 12:16   #3 (permalink)
sagtel's Avatar
Member: 597666
anyways
Hello i chek this all ok NFF.exe is in capital
my nff dongle upgrade all ok
i also try uninstall 1.90 and download from support area 1.90 and install it (5 time) i also try uninstall NFF driver and reinstall driver
but same problem NFF SOFTWARE IS NOT OPEN
all user same problem........
need solution to all user member
Old 06-17-2008, 13:59   #4 (permalink)
Member: 765141
NFF 1.90 software not open ?? i have 100% solution
open C:\Program Files\nff (need rename this folder in capital NFF)
rename folder nff(small) to NFF(capital)
Also we are uploading new setup file which does not have this problem
The Following 3 Users Say Thank You to NFF Box Team For This Useful Post:
Old 06-17-2008, 17:09   #5 (permalink)
sagtel's Avatar
Member: 597666
he he he... this is my solution see here http:///vbb/showthread.php?t=552389
Old 06-17-2008, 17:56   #6 (permalink)
neokia's Avatar
Member: 366974
not working for me !!!!
Old 06-18-2008, 09:49   #7 (permalink)
Member: 765141
@ neokia
please tell me your problem description ?
Old 06-20-2008, 06:10   #8 (permalink)
neokia's Avatar
Member: 366974
@ neokia
check this:
Old 06-20-2008, 15:50   #9 (permalink)
Member: 765141
@ neokia
please make sure you do this exactly
1) Delete all old NFF
2) download dongle upgrade tool
3) upgrade your dongle
4) download Setup 1.90
5) install setup 1.90
6) make sure c: /program files / NFF / NFF.exe ( both NFF Folder name and NFF.exe is written in Capital letters)
Old 06-21-2008, 12:19   #10 (permalink)
Member: 219015
@ neokia
When you fix bug with upgrade from server?
Old 06-21-2008, 16:21   #11 (permalink)
Member: 765141
@ Freshbol
as i see on server your dongle serial you already updated
try to run exe 1.90 now and see
Old 06-22-2008, 04:11   #12 (permalink)
neokia's Avatar
Member: 366974
@ neokia
where i can download dongle upgrade tool????
The Following User Says Thank You to neokia For This Useful Post:
Old 06-22-2008, 09:47   #13 (permalink)
Member: 765141
go to support area, you will see folder dongle upgrade tool
The Following User Says Thank You to NFF Box Team For This Useful Post:
Old 06-24-2008, 15:48   #14 (permalink)
Member: 219015
@ Freshbol
When I run Upgrade tool and start upgrade I have only errors w/o normal upgraded results.
And my software don't open.
I download your new update and run it but with new update it's dont open
The Following User Says Thank You to Freshbol For This Useful Post:
Old 06-24-2008, 16:06   #15 (permalink)
R@jusat's Avatar
Member: 745721
Sonork: 100.1605292
go to support area,........................
The Following 3 Users Say Thank You to R@jusat For This Useful Post:
NFF does not open/upgrade : Need Help ?? zeel_zeel Nokia Fault Finder Box 3 07-22-2008 10:03
HWK upgrade process completed but software not open sagtel HWK 7 06-08-2008 09:58
Sanyo software not opening GSMBALOCH FuriouS TeaM Products 4 11-03-2007 11:34
Please Help Ub Software Not Opening planetsahil Universalbox 9 05-21-2007 21:36
Software not open trentini VygisToolbox 3 08-28-2006 22:25
Page generated in 0.47430 seconds with 11 queries
