09-27-2011, 10:27 | #1 (permalink) |
Junior Member Join Date: Aug 2006
Member: 340837 Status: Offline Thanks Meter: 1 | 5 locks U10 AINO affter unlock Im unlocking the U10 movile. (cid:81) Im using those settings: check use server + full unlock + disable flash mode activation The log is the following: SIGNED MODE (USING SERVER) CFG:100011000000 ChipID:F002,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01229100303926 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation Backup security data ... Erasing locks ... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM16 PHONE READY TO PROCEED. GOT SEED:0005B262 ACTIVATION COMPLETED. USERCODE RESET TO "0000" Unlock DONE Elapsed: 52 secs. But the problem is that my phone is not unlocked... I the 5 locks are enable... I can fix this problem ( 5 locks)... but I cant unlock the phone... Could you help me??? Thanks |
09-27-2011, 10:36 | #3 (permalink) |
Product Manager Join Date: Sep 2009 Location: Pakistan Age: 36
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | Try this Method & Post result. 1. Select Proper Model from List 2. go to Settings & select 1,2,&5 Option From settings 3.Fill ur login Details 4. Press Unlock. Ur set 1000& Unlocked try & post result. |
09-27-2011, 15:01 | #4 (permalink) | |
Member: 340837 Status: Offline Thanks Meter: 1 | Quote:
when I must let the phone power down and power on?????? I mean, the phone is off .... what that you mean with : power down the phone? Thanks | |
09-27-2011, 15:03 | #5 (permalink) | |
But I think that this configuratios is not working with my cid (CID:81) is only for old cids.... any way... I will try! Thanks | |
09-27-2011, 15:06 | #7 (permalink) | |
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | Quote:
Try this method bro 1. select proper model 2. on settings, check "signed mode", "do full unlock instead usercode reset", "disable flash mode activation for semc a2 phones", fill login details 3. back to semc a2 tab, press unlock 4. when prompted, install phone modem drivers (they can be found in drivers\Modem_Drivers or will be automatically installed if you install semc pc suite) 5. when you will get message "unlock done" - do not remove cable or battery, wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure. Try & Post result ok | |
09-27-2011, 17:48 | #8 (permalink) | |
Alternative Security Bypass not supported for that phone Unlock Failed Elapsed: 18 secs any idea??' | |
09-27-2011, 17:53 | #9 (permalink) | |
Thanks!! Thanks!!!!!! YOU ARE RIGTH!!!!! I have wait..... and then... the phone is unlock! Best Regards! | |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
SP Lock 1&4 | dw | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 06-26-1999 06:22 |
Need info for unliocking 2 lock (with pic microprocesors) | Tomas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-26-1999 01:00 |
