10-29-2008, 16:40 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | A2 can unlock/repair using alternative bypass what problems can i encounter and how to avoid them ? how many credits i need ? a: you need setool2 version >=v0.95 for that. first, you can repair ANY software problems for currently released A2 phones. for that, you need to do several simple steps: 1. go to a2 tab 2. select correct model, that is important. 3. go to settings tab. 4. mark "use signed mode" , "use alternative security bypass", "unlock after flash" 5. go back to a2 tab 6. set desired domain ("retail" is best choice) 7. if you want to flash phone, add neccessary firmwares to firmware area and select correct custpack 8. if you selected firmwares, press flash, otherwise press unlock. 9. follow program instructions 10. your phone is repaired and unlocked (and flashed) you need 0.01 credit per phone if phone has unknown/retail domain (?). |
5220 superdongle area damaged-can i repair using cyclone? | zone3 | Cyclonebox | 4 | 01-30-2010 07:50 |
5220 contact service-info posted-can i repair using cyclone? | zone3 | Cyclonebox | 3 | 01-29-2010 13:24 |
SeUltimateUnlocker CAN UNLOCK DB2020 USING DCU-60??? | alamgarh | Cruiser Suite | 3 | 11-25-2008 06:12 |
how can unlock k550i with absent bypass?? | wejwej | SETool2 | 1 | 09-29-2008 23:08 |
How I can unlock F480v using EU? | Nestor7 | Easy-Unlocker | 8 | 08-11-2008 11:33 |
