02-18-2010, 17:47 | #61 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | Quote:
02-18-2010, 19:04 | #62 (permalink) |
Freak Poster Join Date: Jan 2008 Location: phone care
Member: 667941 Status: Offline Sonork: 100.1611812 Thanks Meter: 61 | brother witch is correct gdfs plz give me if u..have or tell me that witch is gdfs ..in this gdfs file .tree file inside gdfs.bin ta.bin ta_misc.bin and why i cant write sofia_ta.ssw |
02-19-2010, 12:08 | #63 (permalink) | |
use this one . | |
The Following 4 Users Say Thank You to Mohsin-* For This Useful Post: |
02-21-2010, 19:11 | #65 (permalink) |
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | if mobile show wrong modle in identify then u need to move in hardware its some thing wrong with hardware, check in hardware |
02-22-2010, 06:43 | #66 (permalink) |
Freak Poster Join Date: May 2009 Location: UK Age: 38
Member: 1027187 Status: Offline Thanks Meter: 7 | Hi, I can't change to R&D because my only options are current, red, brown or blue... What do I need to do? I have same problem as this guy; http://forum.gsmhosting.com/vbb/showthread.php?t=862037 |
The Following User Says Thank You to BONDIE_86 For This Useful Post: |
02-22-2010, 07:34 | #68 (permalink) |
Member: 1027187 Status: Offline Thanks Meter: 7 | Ok, I worked out I should use "brown" instead. But I have followed the vid up until I can and it stops when "starting filesystem" shortly after I click write gdfs and have put the zip folder in the bottom box... I will post log in a second. |
02-22-2010, 07:42 | #69 (permalink) |
Member: 1027187 Status: Offline Thanks Meter: 7 | 22/02/2010 06:28:44 SIGNED MODE (USING SERVER) 22/02/2010 06:28:44 ALTERNATIVE SECURITY BYPASS ENABLED 22/02/2010 06:28:44 PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") 22/02/2010 06:28:44 CFG:110000000000 22/02/2010 06:28:50 ChipID:C802,EMP protocol:0401 22/02/2010 06:28:50 BOOTROM MODE DETECTED 22/02/2010 06:28:50 OTP DBG: [1,52,1,35441402002261] 22/02/2010 06:28:52 OTP LOCKED:1 CID:52 PAF:1 IMEI:35441402002261 CERT:BROWN 22/02/2010 06:28:55 LDR:2009-06-26 15:53 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 82 22/02/2010 06:28:56 DEVICE KEY:CBDBF57FC9FA7012BACFF67A0873B881 (0) 22/02/2010 06:28:56 LDR:2009-04-21 18:17 CXC1250781_DB31XX_RESET_LOADER_ACC_SDRAM_R2A081 22/02/2010 06:28:57 LDR:2009-04-21 18:18 CXC1250782_DB31XX_RESET_LOADER_APP_SDRAM_R2A081 22/02/2010 06:29:00 GOT SEED:C39D64AE34806E6825508D00 22/02/2010 06:29:00 P96 AUTH PASSED 22/02/2010 06:29:00 RESETTING SECURITY TO FACTORY STATE... 22/02/2010 06:29:02 RESTARTING... 22/02/2010 06:29:04 ChipID:C802,EMP protocol:0401 22/02/2010 06:29:04 BOOTROM MODE DETECTED 22/02/2010 06:29:04 OTP DBG: [1,52,1,35441402002261] 22/02/2010 06:29:07 OTP LOCKED:1 CID:52 PAF:1 IMEI:35441402002261 CERT:BROWN 22/02/2010 06:29:08 LDR:2009-06-26 15:52 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A0 82 22/02/2010 06:29:09 LDR:2009-06-26 15:53 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 82 22/02/2010 06:29:09 WRITING SEMCBOOT... 22/02/2010 06:29:12 PREPARING SECURITY... 22/02/2010 06:29:13 WRITING CLEAR SIMLOCK UNITS... 22/02/2010 06:29:15 ALL UNLOCK/LOCK CODES SET TO "33305003" 22/02/2010 06:29:16 CHANGING DOMAIN TO "BROWN" 22/02/2010 06:29:16 SIGNING... 22/02/2010 06:29:21 DEVICE KEY RESTORED 22/02/2010 06:29:21 Unlock FINISHED 22/02/2010 06:29:22 Elapsed: 37 secs. 22/02/2010 06:30:33 CFG:000000000000 22/02/2010 06:30:41 ChipID:C802,EMP protocol:0401 22/02/2010 06:30:41 22/02/2010 06:30:41 PHONE STATE: "DEVELOPER" 22/02/2010 06:30:41 FLASH CID: 0052 22/02/2010 06:30:43 OTP LOCKED:1 CID:52 PAF:1 IMEI:35441402002261 CERT:BROWN 22/02/2010 06:30:44 LDR:2009-06-26 15:52 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A0 82 22/02/2010 06:30:44 LDR CAPS:SYSTEM FLASH SIGNATURE 22/02/2010 06:30:45 LDR:2009-06-26 15:49 CXC1250779_DB31XX_EXPLORER_LOADER_APP_SDRAM_R2A082 22/02/2010 06:30:46 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA 22/02/2010 06:30:46 writing "H:\Documents\Se Tool 3 Box\v0.915057\gdfs_in_ssw_format\A2\K850\Sofia_TA. ssw" 22/02/2010 06:30:47 ALLOWED DOMAINS:BLUE BROWN 22/02/2010 06:30:47 MAXIMUM CID:110 22/02/2010 06:30:47 Will flash 12 blocks... 22/02/2010 06:30:51 ssw file accepted 22/02/2010 06:30:53 Phone detached 22/02/2010 06:30:53 Elapsed: 19 secs. 22/02/2010 06:32:01 CFG:000000000000 22/02/2010 06:32:01 Will write GDFS now. 22/02/2010 06:32:13 ChipID:C802,EMP protocol:0401 22/02/2010 06:32:13 22/02/2010 06:32:13 PHONE STATE: "DEVELOPER" 22/02/2010 06:32:13 FLASH CID: 0052 22/02/2010 06:32:15 OTP LOCKED:1 CID:52 PAF:1 IMEI:35441402002261 CERT:BROWN 22/02/2010 06:32:15 LDR:2009-06-26 15:52 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A0 82 22/02/2010 06:32:16 LDR CAPS:SYSTEM FLASH SIGNATURE 22/02/2010 06:32:17 LDR:2009-06-26 15:49 CXC1250779_DB31XX_EXPLORER_LOADER_APP_SDRAM_R2A082 22/02/2010 06:32:17 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA 22/02/2010 06:37:17 [startFS] can't get NET header 22/02/2010 06:37:17 Elapsed: 315 secs. |
02-22-2010, 10:39 | #71 (permalink) | |
select GDFS in misc Area and write if error in writing Chang ecc mode and retry | |
02-22-2010, 10:51 | #73 (permalink) | |
Member: 1027187 Status: Offline Thanks Meter: 7 | Quote:
BR, Bondie | |
02-22-2010, 10:57 | #74 (permalink) |
Member: 1027187 Status: Offline Thanks Meter: 7 | it just gets stuck here; 22/02/2010 09:54:30 CFG:000000000100 22/02/2010 09:54:30 Will write GDFS now. 22/02/2010 09:55:01 ChipID:C802,EMP protocol:0401 22/02/2010 09:55:01 22/02/2010 09:55:01 PHONE STATE: "RETAIL" 22/02/2010 09:55:01 FLASH CID: 0052 22/02/2010 09:55:02 OTP LOCKED:1 CID:52 PAF:1 IMEI:35441402002261 CERT:RED 22/02/2010 09:55:03 LDR:2009-06-26 15:47 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A082 22/02/2010 09:55:04 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH 22/02/2010 09:55:05 LDR:2009-06-26 15:48 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A082 22/02/2010 09:55:05 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA And in the box underneath it says "Starting file system" for ages... |
02-22-2010, 11:47 | #75 (permalink) | |
1.FLASH xxxTA.ssw uncheck all settings 2.FULL FLASH 3.WRITE GDFS 4.UNLOCK PHONE http://forum.gsmhosting.com/vbb/show...8&postcount=30 amd see this video very carefully | |
GDFS File in AVR Format and GDFS File in MDC format - what is the difference? | FractalizeR | Cruiser Suite | 8 | 05-10-2009 07:52 |
** need s500i gdfs file in gdfs format ** | infogsm | Cruiser Suite | 5 | 11-15-2008 19:57 |
Who can help me to convert gdfs file from .bin to .gdf format? | kakala | Sony Ericsson | 5 | 07-08-2006 09:18 |
GDFS files for 8138. Flash Files Portuguese | Ejaf | LG | 0 | 11-14-2005 16:27 |
T616 Full GDFS file in .gdf or .bin format OR extract | anlog | Sony Ericsson | 2 | 01-29-2004 19:41 |
