12-26-2009, 13:05 | #1 (permalink) |
Freak Poster Join Date: Oct 2005 Location: SOUTH AFRICA
Member: 193720 Status: Offline Thanks Meter: 16 | A2 and s1 phones imei change procedure this is the procedure that i do when changing A2 and S1 IMEI and is as follows:- • PLEASE TAKE NOTE THAT THIS PROCEDURE NEEDS 2 SETOOL CREDITS OR TRY AERIX MAYBE • All S1 phones doesn’t have OTP chip(So you can change the IMEI on them) • Create a script by opening a notepad an typing the following: • tawrite:000007D10212345600901234 = 02‐123456‐00‐901234(new IMEI(14 numbers only)) • Save the notepad as anything.txt. and follow the procedure below STEP BY STEP PROCEDURE 1. Open/run SETOOL application. 2. Go to settings tab and activate signed mode. 3. Go to ODM tab, select phone model and go to misc files and click open. 4. Search for the script anything.txt saved in your pc, select the script. 5. Click in write script and connect the phone in com ‐port mode(not usb mode) 6. Now your phone is dead (not to worry!). 7. Go to settings tab and activate signed mode and perform full unlock instead of user‐code reset. 8. Go to ODM tab with same phone model and press unlock/repair 9. Now the phone is working again and the MEI is changed and phone is fully unlocked. AS FOR THE A2 MODELS YOU NEED TO ENCRYPT THE IMEI AND DO THE SAME STEPS ABOVE(THAT’S IT) • BY USING THE SCRIPT MAKER MERRY CHRISTMAS ALL GSM WORLD PEOPLE! |
12-26-2009, 13:10 | #2 (permalink) | |
No Life Poster Join Date: Sep 2002 Location: Türkiye Age: 48
Member: 15880 Status: Offline Sonork: 100.1612155 Thanks Meter: 452 | Quote:
thanks bud have you tested in a2 platform i think dont work pls post log | |
12-26-2009, 13:26 | #4 (permalink) |
Member: 193720 Status: Offline Thanks Meter: 16 | 1. No but i think it's going to work on A2 platform sir(Lets just try) but it work 10000% on S1 platform. 2. by creating the using this application sir http://www.4shared.com/file/18150225..._for_SEMC.html. thank you! |
12-27-2009, 14:02 | #6 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: SWEDEN-China-Thailand-Singapor
Member: 917893 Status: Offline Sonork: 100.1584763 Thanks Meter: 3,156 | Quote:
The Following User Says Thank You to GSMman187 For This Useful Post: |
12-31-2009, 18:24 | #10 (permalink) |
Member: 917893 Status: Offline Sonork: 100.1584763 Thanks Meter: 3,156 | S1 100% possible 1,read TA from phone use setool 2,find the address of IMEI 3,change it use winhex 4,write TA into phone use setool 5,unlock (full unlock with credit) |
Nokia Imei change procedures | egreen1956 | Universalbox | 19 | 01-29-2010 00:19 |
A2, and S1 connect to mobile phones, please help | licheng | Universalbox | 2 | 01-02-2010 12:28 |
3530 ESN IMEI Changing Procedure - with sourcecode | ulymar | GSM Programming & Reverse Engineering | 25 | 06-23-2006 07:53 |
Siemens IMEI change procedure?!!!! | meisam | DreamBox | 4 | 02-25-2006 14:51 |
