07-14-2010, 14:24 | #1 (permalink) |
Banned Join Date: Jul 2009
Member: 1073809 Status: Offline Thanks Meter: 78 | after recovery now error why first cid 50 CARD SERIAL 00022535 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:101000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 skipping empty loader... FAILED TO SETUP PHONE Elapsed: 13 secs. SIGNED MODE (USING SERVER) CFG:101000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 skipping empty loader... FAILED TO SETUP PHONE Elapsed: 9 secs. SIGNED MODE (USING SERVER) CFG:101000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 skipping empty loader... FAILED TO SETUP PHONE Elapsed: 13 secs. SIGNED MODE (USING SERVER) CFG:101000000000 RESET MODE STARTED NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 RESET:070703 1100 NPACXC125870_DB2010_CERTRESETLOADER_P5F FLASH ID: 897E GOT SEED:823292602280DD7015B08F81 P96 AUTH PASSED OTP LOCKED:1 CID:50 PAF:1 IMEI:35657301530683 CERT:BROWN PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 22 secs. SIGNED MODE (USING SERVER) CFG:101000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 skipping empty loader... FAILED TO SETUP PHONE Elapsed: 5 secs. |
07-15-2010, 12:53 | #4 (permalink) |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | CID 49 1. select proper model 2. on settings, check "unlock during flash process" 3. add to firmware area proper gdfs in ssw format 4. if desired, add to firmware area proper main,fsimage 5. press flash please note, if EROM damaged on such phones, you must execute reset operation. CID 50,51,52,53 that is so-called reset procedure. 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. |
07-21-2010, 11:34 | #12 (permalink) |
Member: 1073809 Status: Offline Thanks Meter: 78 | RUNNING v 1.081/UNI CARD SERIAL 00022535 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000100000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 loader payload not accepted FAILED TO SETUP PHONE Elapsed: 12 secs. CFG:000100000000 RECOVERY MODE STARTED NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 err: 32 (9) loader header not accepted PROCEDURE WAS STOPPED BY USER Elapsed: 11 secs. CFG:000000000000 RECOVERY MODE STARTED NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 err: 32 (9) loader header not accepted NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 err: 32 (9) loader header not accepted All possible recovery loaders failed. That phone not supported Elapsed: 14 secs. CFG:000000000000 RECOVERY MODE STARTED NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 err: 32 (9) loader header not accepted NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 err: 32 (9) loader header not accepted All possible recovery loaders failed. That phone not supported Elapsed: 9 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 RESET:070703 1100 NPACXC125870_DB2010_CERTRESETLOADER_P5F FLASH ID: 897E GOT SEED:A60E30152280DD7015D0DD4E P96 AUTH PASSED OTP LOCKED:1 CID:50 PAF:1 IMEI:35657301323037 CERT:BROWN PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 40 secs. SIGNED MODE (USING SERVER) CFG:100000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 skipping empty loader... FAILED TO SETUP PHONE Elapsed: 4 secs. SIGNED MODE (USING SERVER) CFG:100000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 skipping empty loader... FAILED TO SETUP PHONE Elapsed: 4 secs. SIGNED MODE (USING SERVER) CFG:100000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 skipping empty loader... FAILED TO SETUP PHONE Elapsed: 3 secs. |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? | MyKe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-26-1999 14:31 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
