05-13-2010, 13:23 | #1 (permalink) |
Junior Member Join Date: Dec 2007 Location: iran
Member: 660358 Status: Offline Sonork: 1585668 Thanks Meter: 13 | after recovery phone dead skipping empty loader... FAILED TO SETUP solutions CARD SERIAL 00014784 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 Will backup GDFS now. PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 106 secs. CFG:000000000000 Will backup GDFS now. PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 33 secs. Found 3 FTDI device(s). UFS #73305 READY CFG:000000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 5 secs. Found 3 FTDI device(s). UFS #73305 READY CFG:000000000000 Will backup GDFS now. NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35165302838491 CERT:RED PHONE CID NOT SUPPORTED IN THAT MODE Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100000000000 Will backup GDFS now. NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35165302838491 CERT:RED LDR:061205 1354 HAN_DB2012_FLASHLOADER_R2B012_CXC1326738 FLASH ID: 897E LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009 loader GDFS startup executed PROCEDURE WAS STOPPED BY USER can't get packet data (00006000/00007D7A) Failed. Elapsed: 93 secs. SIGNED MODE (USING SERVER) CFG:100000000000 Will backup GDFS now. NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 FAILED TO SETUP PHONE Elapsed: 11 secs. SIGNED MODE (USING SERVER) CFG:100000000000 Will backup GDFS now. NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35165302838491 CERT:RED PROCEDURE WAS STOPPED BY USER packet not acknowledged (3C) payload block 20 NAK Elapsed: 8 secs. SIGNED MODE (USING SERVER) CFG:100000000000 Will backup GDFS now. NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35165302838491 CERT:RED LDR:061205 1354 HAN_DB2012_FLASHLOADER_R2B012_CXC1326738 FLASH ID: 897E LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009 loader GDFS startup executed stated number of vars:1038 Found:910 units Found:128 units GDFS_35165302838491.BIN written Phone detached Elapsed: 28 secs. POSSIBLE GDFS FILE DETECTED, EXTRACTING PHONEBOOK DONE EXTRACTING. SIGNED MODE (USING SERVER) CFG:100100000100 Will write GDFS now. NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 skipping empty loader... FAILED TO SETUP PHONE Elapsed: 16 secs. SIGNED MODE (USING SERVER) CFG:100100000100 RESET MODE STARTED PROCEDURE WAS STOPPED BY USER Elapsed: 10 secs. SIGNED MODE (USING SERVER) CFG:100100000100 RESET MODE STARTED NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 RESET:070703 1100 NPACXC125870_DB2010_CERTRESETLOADER_P5F FLASH ID: 897E GOT SEED:E401B3A92380AF6D25B04961 P96 AUTH PASSED OTP: LOCKED:1 CID:51 PAF:1 IMEI:35575902398491 CERT:BROWN PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 10 secs. SIGNED MODE (USING SERVER) CFG:100100000100 RESET MODE STARTED NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 RESET:070703 1100 NPACXC125870_DB2010_CERTRESETLOADER_P5F FLASH ID: 897E GOT SEED60F34892380AF6D25B04961 P96 AUTH PASSED OTP: LOCKED:1 CID:51 PAF:1 IMEI:35575902398491 CERT:BROWN PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 5 secs. SIGNED MODE (USING SERVER) CFG:100100000100 RESET MODE STARTED NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 RESET:070703 1100 NPACXC125870_DB2010_CERTRESETLOADER_P5F FLASH ID: 897E GOT SEED:5C01DB762380AF6D25B04961 P96 AUTH PASSED OTP: LOCKED:1 CID:51 PAF:1 IMEI:35575902398491 CERT:BROWN PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 6 secs. SIGNED MODE (USING SERVER) CFG:100100000100 Will write GDFS now. NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 skipping empty loader... FAILED TO SETUP PHONE Elapsed: 1 secs. SIGNED MODE (USING SERVER) CFG:100100000100 Processing script "G:\sony ercsson\sony ericsson\v1.01\gdfs_35165302838491.bin"... NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 skipping empty loader... FAILED TO SETUP PHONE Elapsed: 0 secs. Found 3 FTDI device(s). UFS #73305 READY CFG:000000000000 RECOVERY MODE STARTED PROCEDURE WAS STOPPED BY USER Elapsed: 11 secs. POSSIBLE GDFS FILE DETECTED, EXTRACTING PHONEBOOK DONE EXTRACTING. CFG:000000000000 Will write GDFS now. PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 4 secs. CFG:000000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 14 secs. Found 3 FTDI device(s). UFS #73305 READY CFG:000000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35575902398491 CERT:BROWN FLASH CID:51 COLOR:BROWN setGDFS_params failed failed to setup GDFS Elapsed: 14 secs. CFG:000000000000 Will write GDFS now. PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 20 secs. CFG:000000000000 Will write GDFS now. NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35575902398491 CERT:BROWN LDRB2010_RESPIN_PRODLOADER_SETOOL2 FLASH ID: 897E Setting up GDFS... will write 1038 units done Phone detached Elapsed: 43 secs. CFG:000000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 5 secs. CFG:000000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35575902398491 CERT:BROWN FLASH CID:51 COLOR:BROWN setGDFS_params failed failed to setup GDFS Elapsed: 4 secs. CFG:000000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35575902398491 CERT:BROWN FLASH CID:51 COLOR:BROWN setGDFS_params failed failed to setup GDFS Elapsed: 6 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 17 secs. SIGNED MODE (USING SERVER) CFG:100000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 skipping empty loader... FAILED TO SETUP PHONE Elapsed: 2 secs. POSSIBLE GDFS FILE DETECTED, EXTRACTING PHONEBOOK DONE EXTRACTING. SIGNED MODE (USING SERVER) CFG:100000000000 Processing script "G:\sony ercsson\sony ericsson\v1.01\gdfs_35165302838491.bin"... PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 3 secs. SIGNED MODE (USING SERVER) CFG:100000000000 Processing script "G:\sony ercsson\sony ericsson\v1.01\gdfs_35165302838491.bin"... NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 skipping empty loader... FAILED TO SETUP PHONE Elapsed: 3 secs. CFG:000000000000 Will write GDFS now. PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 12 secs. CFG:000000000000 Will write GDFS now. PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 12 secs. CFG:000000000000 Will write GDFS now. NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35575902398491 CERT:BROWN LDRB2010_RESPIN_PRODLOADER_SETOOL2 FLASH ID: 897E Setting up GDFS... will write 1038 units done Phone detached Elapsed: 51 secs. CFG:000000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 18 secs. CFG:000000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35575902398491 CERT:BROWN LDRB2010_RESPIN_PRODLOADER_SETOOL2 FLASH ID: 897E writing "G:\sony ercsson\sony ericsson\v1.01\gdfs_in_ssw_format\db2010\w200_gdfs _in_ssw_format.ssw" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is: 32 Will flash 32 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "48876587" SIGNING... Elapsed: 77 secs. CFG:000000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35575902398491 CERT:BROWN LDRB2010_RESPIN_PRODLOADER_SETOOL2 FLASH ID: 897E writing "G:\sony ercsson\sony ericsson\v1.01\eroms\db2010\db2012_erom_cid53.ssw" CURRENT FLASH FILE CID:36 Converting firmware... SSW uses dynamic hash, dynamic hash len is: 2 Will flash 2 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "06111384" |
05-13-2010, 13:42 | #2 (permalink) |
Member: 660358 Status: Offline Sonork: 1585668 Thanks Meter: 13 | Stage select interface ufs whrite gdfs bin empty fill repair select phone type add gdfs ssw no selctet settings pers to flash add eroms no selctet seting pers to flash |
The Following User Says Thank You to himtemobile For This Useful Post: |
05-13-2010, 13:43 | #4 (permalink) |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | GO to empty file section : -do reset operation -flash gdfs (ssw) -flash erom NOW GO to sonyericson tape: full flash phone main +fs |
The Following User Says Thank You to roney_nexus For This Useful Post: |
05-13-2010, 15:06 | #5 (permalink) | |
Member: 660358 Status: Offline Sonork: 1585668 Thanks Meter: 13 | Quote:
pars-gsm beat iranin mobile forum | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
