08-13-2011, 15:24 | #1 (permalink) |
No Life Poster Join Date: Apr 2006
Member: 263686 Status: Offline Thanks Meter: 62 | all xperia unlock problem can't get ROOT rights Unlock FAILED PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" BUTTON ... RUNNING S1_EROM VER "R8A029" SOFTWARE AID: 0001 LOADER AID: 0001 FLASH ID: "0020/00BC" LOADER VERSION: "R4A045" PHONE IMEI:01256000143749 Checking for signature ... signature found, skipping calculation REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED MAKE SURE PHONE HAS ANDROID 2.x FIRMWARE WARMING UP ... GETTING ROOT ACCESS ... APPLYING ROOT RIGHTS ... PROCESSING ... failed, err: [error: protocol fault (no status) ] Unlock FAILED Elapsed: 154 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" BUTTON ... RUNNING S1_EROM VER "R8A013" SOFTWARE AID: 0001 LOADER AID: 0001 FLASH ID: "002C/00B3" LOADER VERSION: "R4A024" PHONE IMEI:01237900278625 Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1187] REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED MAKE SURE PHONE HAS ANDROID 2.x FIRMWARE WARMING UP ... GETTING ROOT ACCESS ... can't get ROOT rights Unlock FAILED |
08-13-2011, 16:27 | #3 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: I N D I A
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | Quote:
Make sure in settings tab trick 1,2,5 than unlock | |
08-13-2011, 17:19 | #7 (permalink) | |
Freak Poster Join Date: Jan 2007
Member: 438969 Status: Offline Thanks Meter: 9 | Quote:
04-10-2013, 19:00 | #9 (permalink) |
Junior Member Join Date: Feb 2012
Member: 1720836 Status: Offline Thanks Meter: 3 | daemon not running. starting it now on port 5037 * * daemon started successfully * ** hi to all, any one knows exactily about this ???? when i try to unlock x8,x10 with setool, i get this error,, daemon not running. starting it now on port 5037 * * daemon started successfully * ** cant get root rights, faile i have flashed with 2.1.1.A.0.6 have 2.1 version i have tried after disabling anti virus and firewall i have tried on 3 diffrent computers with windows xp an 7.. i have tried to root many times and mobile gets root but,,,,,,,,, any other solution would be highly appreciated............ you can say its a challenge for senior bros............ |
04-26-2013, 10:32 | #10 (permalink) | |
No Life Poster Join Date: Jan 2004 Age: 44
Member: 50603 Status: Offline Thanks Meter: 59 | Quote:
same problem, then, i am rooted manualy and same problem flashed with e15 2.1 from support, and same problem. ticked 1 2 and 5 and same prblem. | |
04-26-2013, 12:03 | #12 (permalink) |
Freak Poster Join Date: Mar 2007 Location: In the skies
Member: 460298 Status: Offline Thanks Meter: 32 | Not all xperia, others supported Xperia unlock with testpoint was fine. Try flash firmware 3_0_1_G_0_75 at support site. I unlocked many X10 with that. |
05-31-2013, 13:50 | #14 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Romania,Buc
Member: 694535 Status: Offline Thanks Meter: 70 | same problem solution ? SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_EROM VER "R8A029" EROM_AID : 0001 LOADER_AID : 0001 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 DEVICE ID: CDED8647FE0CC5C1551A84C1C399529DA98028CC FLASH ID: "0020/00BC" LOADER VERSION: "R4A060" PHONE IMEI : 01256000277372 Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1187] REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED MAKE SURE PHONE HAS ANDROID 2.x FIRMWARE WARMING UP ... GETTING ROOT ACCESS ... * daemon not running. starting it now on port 5037 * * daemon started successfully * E15i-user 2.1-upda ... can't get ROOT rights Unlock FAILED Elapsed: 141 secs. |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
