07-26-2011, 19:19 | #1 (permalink) |
No Life Poster Join Date: Jun 2002 Location: Bosnien Age: 43
Member: 12904 Status: Offline Sonork: 100.1576801 Thanks Meter: 409 | anybody with locked or not locked e10,e15,e16,u20 please come here. Let's make some tests. 1. download setool2 v1.1099 https://rapidshare.com/files/3246771165/v1.1099.rar 2. make sure you have firmware with android 2.x, NOT 1.6. flash required firmware, if needed. 3. power on phone without sim card, go to menu->settings->applications->development, enable "usb debugging" connect phone to PC, install drivers from setool2 v1.1099 distr ( drivers\ADB_Drivers) hint: i suggest to import DisableADBNumbering.reg, however that is not required. 4. select proper phone model. on settings check signed mode, use alternative security bypass, do full unlock instead usercode reset press unlock follow program directions. hint: when program tells "warming up...", manually power on phone fully, cause it will automatically enter charging mode. after you see "GETTING ROOT ACCESS ..." DO NOT TOUCH PHONE until procedure complete. it can happen ( very unlikely, though ) that ADB server will not recognize phone after reboot, so IF phone not detecting automatically and on status bar you can see "waiting for phone...", again - only in that case - disconnect phone from usb and connect it again, procedure should continue. if not, well, repeat from start. 5. during testing period procedure will be free, however testing period will be very short ( until i wake up ) and credits will be taken after that,depending on testing results. we tested service thoroughly and all went fine, but... well, you got idea. no any warranty, your phone can be killed,etc,etc,etc. |
The Following User Says Thank You to DarkSkir For This Useful Post: |
07-26-2011, 21:15 | #6 (permalink) |
No Life Poster Join Date: Jul 2005 Location: player /-GSM-\ Field
Member: 161115 Status: Offline Sonork: Here you can find it... Thanks Meter: 3,039 | |
The Following User Says Thank You to SHOEB AHMED For This Useful Post: |
07-26-2011, 22:15 | #9 (permalink) |
Junior Member Join Date: Sep 2005 Location: germany Age: 57
Member: 184470 Status: Offline Thanks Meter: 0 | Thankkksssssss... A Lotttttttttttttt... E15_XPERIA X8 unlocked... SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" BUTTON... EROM "R8A029" AID: 0001 SOFTWARE AID: 0001 LOADER AID: 0001 FLASH ID: "00EC/00BC" LOADER VERSION: "R4A045" PHONE IMEI:01xxxxxxxxxxxxx Checking for signature... signature found, skipping calculation REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED MAKE SURE PHONE HAS ANDROID 2.x FIRMWARE WARMING UP... GETTING ROOT ACCESS ... APPLYING ROOT RIGHTS ... PROCESSING ... FINALIZING ... Unlock DONE Elapsed: 213 secs. BR ISI |
07-26-2011, 22:57 | #10 (permalink) | |
No Life Poster Join Date: Jun 2006
Member: 303419 Status: Offline Sonork: Fes Thanks Meter: 209 | another U20i good luck every body Quote:
07-27-2011, 07:51 | #12 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 624567 Status: Offline Thanks Meter: 256 | X 8 E15i Unlock Done SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" BUTTON... EROM "R8A029" AID: 0001 SOFTWARE AID: 0001 LOADER AID: 0001 FLASH ID: "00EC/00BC" LOADER VERSION: "R4A045" PHONE IMEI:01244800********* Checking for signature... Waiting for calculation process... RESPONSE: "SUCCESS" [1187] REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED MAKE SURE PHONE HAS ANDROID 2.x FIRMWARE WARMING UP... GETTING ROOT ACCESS ... APPLYING ROOT RIGHTS ... PROCESSING ... FINALIZING ... Unlock DONE Elapsed: 83 secs. |
07-27-2011, 09:08 | #13 (permalink) |
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | unlock ok ! But a small problem with adb driver : After installing se pc compagnion from official se website, all went ok ! Code: EROM "R8A029" AID: 0001 SOFTWARE AID: 0001 LOADER AID: 0001 FLASH ID: "0020/00BC" LOADER VERSION: "R4A045" PHONE IMEI:01244800797342 Checking for signature... signature found, skipping calculation REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED MAKE SURE PHONE HAS ANDROID 2.x FIRMWARE WARMING UP... GETTING ROOT ACCESS ... APPLYING ROOT RIGHTS ... PROCESSING ... FINALIZING ... Unlock DONE Elapsed: 148 secs. |
07-27-2011, 13:41 | #14 (permalink) |
Member: 12904 Status: Offline Sonork: 100.1576801 Thanks Meter: 409 | SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" BUTTON... EROM "R8A029" AID: 0001 SOFTWARE AID: 0001 LOADER AID: 0001 FLASH ID: "002C/00BC" LOADER VERSION: "R4A045" PHONE IMEI:-------------------- Checking for signature... Waiting for calculation process... RESPONSE: "SUCCESS" [1187] REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED MAKE SURE PHONE HAS ANDROID 2.x FIRMWARE WARMING UP... GETTING ROOT ACCESS ... APPLYING ROOT RIGHTS ... PROCESSING ... FINALIZING ... Unlock DONE |
07-27-2011, 19:07 | #15 (permalink) | |
Freak Poster Join Date: Jun 2009
Member: 1049869 Status: Offline Thanks Meter: 25 | Quote:
hi brother plz can u tell about e15i driver when i install adb driver show me cannot intall this hardwere any idea about e15i drivers | |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
