Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 06-05-2014, 17:19   #1 (permalink)
Member: 1813192
Thanks Meter: 60
i c,ant unlock lg E610 direkt
i c,ant direct unlock lg e610 with setool
Getting phone info Model: E610
Platform: LG Qualcomm
Software Platform: Android
SDRAM Size: 512 MB
NAND Flash Size: 3814 MB
CPU: MSM7225A
Firmware Released: Apr 11 2013 09:13:31
Firmware Compiled: Feb 22 2013 00:00:00
Firmware Version: E610/LGE610AT-00-V20b-EUR-XX-APR-11-2013+0
IMEI: 35570
Bluetooth Address: 10:68:3F:57:2A:F1
Connect mode: Normal
Info received
Unlocking phone
Unlock: Start
Dump Security: Start
This solution based on custom firmware.
You should reflash firmware if you have any problems after operations.
Getting phone info...
Getting phone info: OK
Checking Emergency Mode...
Mode: Normal
Switching to Emergency Mode...
Mode: Emergency
Checking connect in Emergency Mode...
Checking connect in Emergency Mode: OK
Checking connect with Loader...
Loader Not Found
Flashing Loader...
Protocol: Checksum error:
pless any solucion
The Following User Says Thank You to jehon For This Useful Post:
Old 06-05-2014, 17:32   #2 (permalink)
Member: 515559
Sonork: no
Thanks Meter: 121
use paid service for unlock this phone ; i think just 1 credit
The Following User Says Thank You to dindou78 For This Useful Post:
Old 06-06-2014, 04:05   #3 (permalink)
Member: 125632
Thanks Meter: 233
direct unlock working 100% with latest lgtool
here is log.for unlock e610 lg..
01:21.234 <B>LGE Tool version:</B> 2.39
01:21.234 <B>OS Version:</B> Windows XP [NT 5.1] Service Pack 2
01:21.234 <B>Administrative privileges:</B> yes
01:21.250 <B>Locale:</B> UnitedKingdom / English
01:21.250 <B>CPU frequency:</B> 2204 MHz
01:21.250 <B>Total memory:</B> 2047 MB
01:21.250 <B>Free memory:</B> 1411 MB
01:21.250 <B>Free space on system disk C:\:</B> 7.00 GB
01:21.250 <B>Free space on disk D:\:</B> 4.00 GB
01:21.250 <B>Free space on disk E:\:</B> 3.00 GB
01:21.250 <B>Free space on disk F:\:</B> 3.00 GB
01:21.250 <B>Free space on disk G:\:</B> 5.00 GB
01:21.250 <B>Free space on disk H:\:</B> 6.00 GB
01:21.250 <B>Free space on disk I:\:</B> 8.00 GB
01:21.250 <B>Free space on disk J:\:</B> 9.00 GB
01:21.250 <B>Free space on disk K:\:</B> 5.00 GB
01:21.250 <B>Free space on disk M:\:</B> 204.00 GB
01:21.250 <B>Free space on disk N:\:</B> 179.00 GB
14:35.234 Connecting with <b>E610</b>
14:35.250 > Model: E610
14:35.250 > Baudrate: 921600
14:35.953 Connected
14:35.953 Receiving phone info
14:35.953 Getting phone info
14:35.968 <b>Model:</b> E610
14:35.968 <b>Platform:</b> LG Qualcomm
14:35.968 <b>Software Platform:</b> Android
14:35.968 <b>SDRAM Size:</b> 512 MB
14:35.968 <b>NAND Flash Size:</b> 3814 MB
14:35.984 <b>CPU:</b> MSM7225A
14:38.765 <b>Firmware Released:</b> Jan 25 2013  14:19:21
14:38.781 <b>Firmware Compiled:</b> Apr 19 2012  06:00:00
14:38.781 <b>Firmware Version:</b> E610/LGE610AT-00-V10d-214-03-JAN-25-2013+0
14:38.796 <b>IMEI:</b> 355707-05-xxxxxx-2
14:38.812 <b>Bluetooth Address:</b> 98:xx:F7:xx:xx:DB
14:38.828 <b>Connect mode:</b> Normal
14:38.828 Info received
14:52.546 Unlocking phone
14:52.562 Unlock: Start
14:52.578 Dump Security: Start
14:56.750 This solution based on custom firmware.
14:56.765 You should reflash firmware if you have any problems after operations.
14:56.765 Getting phone info...
14:59.546 Getting phone info: OK
14:59.562 Checking Emergency Mode...
15:06.093 Mode: Normal
15:06.093 Switching to Emergency Mode...
15:10.328 Mode: Emergency
15:13.343 Checking connect in Emergency Mode...
15:13.359 Checking connect in Emergency Mode: OK
15:13.359 Checking connect with Loader...
15:13.375 Loader Not Found
15:13.375 Flashing Loader...
15:17.765 Checking Emergency Mode...
15:22.484 Mode: Emergency
15:22.500 Checking connect in Emergency Mode...
15:22.500 Checking connect in Emergency Mode: OK
15:22.515 Set Trust Mode...
15:22.515 Set Trust Mode: OK
15:22.531 Get DloadParams...
15:22.531 Get DloadParams: OK
15:22.546 Send Partition Table...
15:22.609 Send Partition Table: OK
15:22.625 Flashing Bootable Partitions...
15:22.625 Checking BCPL...
15:22.640 Checking BCPL: LOCKED
15:22.656 Sending BCPE...
15:22.656 Sending BCPE: 1
15:22.671 Checking BCPL...
15:22.687 Checking BCPL: UNLOCKED
15:22.687 Flashing Partition: QCSBLHD_CFGDATA...
15:22.703 Initializing partition: 0x00000002 [QCSBLHD_CFGDATA]...
15:22.703 Initializing partition: 0x00000002 [QCSBLHD_CFGDATA]: OK
15:22.718 Writing Partition...
15:22.734 Flashing Partition: QCSBLHD_CFGDATA: OK
15:22.750 Flashing Partition: QCSBL...
15:22.765 Initializing partition: 0x00000003 [QCSBL]...
15:22.765 Initializing partition: 0x00000003 [QCSBL]: OK
15:22.781 Writing Partition...
15:22.890 Flashing Partition: QCSBL: OK
15:22.890 Flashing Partition: OEMSBL...
15:22.906 Initializing partition: 0x00000004 [OEMSBL]...
15:22.906 Initializing partition: 0x00000004 [OEMSBL]: OK
15:22.921 Writing Partition...
15:23.187 Flashing Partition: OEMSBL: OK
15:23.187 Flashing Bootable Partitions: OK
15:23.203 Dload Finalization...
15:23.265 Dload Finalization: OK
15:23.281 Switching to normal mode...
16:05.468 Please power on the phone and wait some minutes to continue...
16:05.468 In some cases you should select the item "LG Software" in the dialog "USB connection" and reconnect USB-cable...
17:36.875 Switching to normal mode: OK
17:36.890 Flashing Loader: OK
17:36.906 Checking Emergency Mode...
17:44.031 Mode: Normal
17:44.046 Switching to Emergency Mode...
17:49.375 SetupDiEnumDeviceInfo failed
17:50.812 Mode: Emergency
17:53.828 Checking connect in Emergency Mode...
17:53.828 Checking connect in Emergency Mode: OK
17:55.875 Init Loader...
17:55.890 Init Loader: OK
17:55.906 Dumping Security...
17:55.906 Reading Part Table...
17:56.000 Reading Part Table: OK
17:57.546 Dumping Security: OK
17:57.578 Backuping Security to file: Backups\E610_security_355707050648352_2014-6-5_0-17-57.sbf
17:59.046 Dump Security: Finish
17:59.062 Flash Security: Start
17:59.796 Flashing Security...
17:59.812 Flashing Security: STEP 1...
17:59.812 Reading Part Table...
17:59.921 Reading Part Table: OK
18:01.359 Flashing Security: STEP 1: OK
18:01.375 Switching to normal mode...
18:32.906 Switching to normal mode: OK
18:32.906 Flashing Security: STEP 2...
18:32.921 Security-Finalizing...
18:39.187 Rebooting...
19:14.187 Security-Finalizing: OK
19:14.218 Flashing Security: STEP 2: OK
19:14.234 Flash Security: Finish
19:14.250 Unlock: Finish
19:14.250 Phone successfully unlocked
well done setool
The Following User Says Thank You to bcatlock1 For This Useful Post:
Old 10-09-2019, 07:34   #4 (permalink)
Member: 2900068
Thanks Meter: 4
Connecting with E612F
Connected
Getting phone info
Model: E612F
SDRAM Size: 512 MB
CPU: MSM7225A
Disconnected
how can i solve this issue????
Old 11-24-2019, 14:10   #5 (permalink)
Member: 315545
: خطأ في المجموع الاختباري:
كيف يمكن حل هذه المشكلة ؟؟؟ ؟
تقرير المشاركة
Page generated in 0.27084 seconds with 9 queries
