Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 08-15-2017, 17:32   #16 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 40
Originally Posted by rubymunna View Post
No need tp. No need to remove cover.
Only need correct driver
I have done now.
Sent from my iPhone using Tapatalk
Can you share Driver then , please
Old 08-16-2017, 08:49   #17 (permalink)
moshman's Avatar
Member: 193192
Thanks Meter: 327
Download latest Setool, look for file ggsetup in drivers directory
Old 08-16-2017, 12:44   #18 (permalink)
rubymunna's Avatar
Member: 550683
Sonork: 100.1649601
Thanks Meter: 43
driver for Sony Lastest Phone
here driver
https://www.4shared.com/s/fQk7UNsSyca
i got after flash...FACTORY STARTUP SERVICE
Dont worry
select attached file in misc.write script
https://www.4shared.com/s/fjSjyEWp2ca
Have a good day!
The Following 7 Users Say Thank You to rubymunna For This Useful Post:
Old 08-18-2017, 20:01   #19 (permalink)
Member: 2462504
Sonork: 1001681026
Thanks Meter: 19
this test point
http://sony.yt/index.php?app=core&mo...attach_id=6022
The Following 2 Users Say Thank You to bassemsky For This Useful Post:
Old 08-19-2017, 06:44   #20 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 40
here driver
Dont worry
Have a good day!
Mine is f3213
The Following User Says Thank You to 1R0niC For This Useful Post:
Old 08-19-2017, 14:57   #21 (permalink)
Member: 2462504
Sonork: 1001681026
Thanks Meter: 19
its ok tested by me 100% ok
boot repair f3112
Old 08-19-2017, 16:29   #22 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 40
boot repair f3112
Ok im trying this on f3213
Old 08-20-2017, 03:19   #23 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 40
boot repair f3112
Thanks a lot
Boot repaired
Software repaired and downgraded
Frp removed
Thanks Sir
Old 08-28-2017, 00:03   #24 (permalink)
Member: 880191
Thanks Meter: 6
f3111 dead
plz geet me nice drive
Old 09-02-2017, 13:13   #25 (permalink)
GSMsurgeon's Avatar
Member: 6524
Thanks Meter: 246
done f3111
Originally Posted by body.gsm View Post
f3111 dead
procedure done by me
1) install fash driver from setool folder
2) select flash file
3) select option 1+2 in settings
3 ) flash
4) ready
5) connect phone by -vol down
and wait..
The Following 2 Users Say Thank You to GSMsurgeon For This Useful Post:
Old 09-17-2017, 17:23   #26 (permalink)
Member: 2758698
Thanks a lot
Boot repaired
Frp removed
Thanks Sir
sir, this solution needs a box?
or only install Setool2 in PC?
please help me.
Old 09-19-2017, 03:26   #27 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 40
Box needed
Old 09-23-2017, 16:12   #28 (permalink)
Member: 2758698
Box needed
Thanks my friend
Another question:
what kind of box is suitable for the new xpria series(2015, 2016, 2017 series)?
z3x easy jtag or Riff or ... Which one do you suggest?
thanks
Old 09-24-2017, 15:22   #29 (permalink)
moshman's Avatar
Member: 193192
Thanks Meter: 327
Originally Posted by twhhhco View Post
Thanks my friend
Another question:
thanks
You would be better asking this question in the 'Market Feedback' Section NOT in a support section for Setool, don't you think ??????
Old 09-25-2017, 06:47   #30 (permalink)
Member: 2132910
Thanks Meter: 29
where is test point m5
Elapsed: 109 seconds
SIGNED MODE (USING SERVER)
ALTERNATIVE SECURITY BYPASS ENABLED
CFG:110000000000
DETACH USB CABLE FROM PHONE
ATTACH TESTPOINT
PRESS "READY", THEN ATTACH USB CABLE TO PHONE
PROCEDURE WAS STOPPED BY USER
CAN'T FIND PHONE IN BROM MODE
FAILED TO SETUP PHONE
Elapsed: 1085 seconds
The Following User Says Thank You to extra_xpert For This Useful Post:
Page generated in 0.22089 seconds with 9 queries
