11-23-2013, 10:47 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: colombo Age: 40
Member: 645987 Status: Offline Sonork: 100.1612601 Thanks Meter: 112 | c1505_xperia_E Unlock FAILED current setool2 version: 1.1403 SERVER CREDITS LEFT/USED: 20/10 CARD COUNTERS: FLASH 7769, UNLOCK 1601 Elapsed: 5 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_BOOT VER "R10D030" ACTIVE_COMP_AID : 0002 HWCONF_AID : 0002 LOADER_AID : 0002 BOOT_AID : 0002 DEVICE ID: A2C4FEAF53C40D33502DE76C3585A99A4BADB4B5 FLASH ID: "0003/00000015" LOADER VERSION: "R5D030" PHONE IMEI : 357421058 Checking for signature ... signature found, skipping calculation REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED WARMING UP ... USING ADB v1.0.26 RecvANSW(): failed to recv status, got: FFFFFFFF (code: 10054 / Connection reset by peer) Unlock FAILED Elapsed: 137 secs. my 1 credits lost |
11-23-2013, 12:07 | #4 (permalink) |
No Life Poster Join Date: Jan 2002 Location: 24° 51′ 36″ N, 67°
Member: 8353 Status: Offline Sonork: 113276 Thanks Meter: 335 | reflash phone with another generic firmware ...root phone and repeat process.. today i unlocked 1 o2 c1505 phone without any error.... |
11-24-2013, 09:51 | #6 (permalink) |
No Life Poster Join Date: Jan 2012 Location: prAy for nEpal
Member: 1710706 Status: Offline Sonork: 100.1645371 Thanks Meter: 61 | xperia C1504 carrier : Boost Mobile Australia android : v4.1.1 production : 13W18 super user installed Code: Rooting status Bootloader unlock allowed : NO is dis fone supported for unlock setool new ver |
11-24-2013, 10:10 | #7 (permalink) |
Freak Poster Join Date: Jul 2010
Member: 1356821 Status: Offline Thanks Meter: 85 | Yes its supportet just flash it first whit a other fw than unlock it without any probleme change usb port 2.0 and try with a orginal sony cable to a usb port 3.0 this phone was a sfr france SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_BOOT VER "R10D030" ACTIVE_COMP_AID : 0002 HWCONF_AID : 0002 LOADER_AID : 0002 BOOT_AID : 0002 DEVICE ID: BCCB443BF273AF4DD4F6886EAFE31015DE8EDC41 FLASH ID: "0003/00000015" LOADER VERSION: "R5D030" PHONE IMEI : 35960805213719 Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1520] REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED WARMING UP ... CHECKING ROOT ACCESS ... GETTING ROOT ACCESS ... PROCESSING ... C1505 [7e466194] FINALIZING ... Unlock DONE Elapsed: 268 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED Envoyé depuis mon GT-I8530 avec Tapatalk |
11-25-2013, 09:29 | #8 (permalink) | |
Member: 1710706 Status: Offline Sonork: 100.1645371 Thanks Meter: 61 | done thnxxx Quote:
Code: RUNNING v 1.1403/01.15/UNI CARD SERIAL 00 USBFLASH DRIVER VERSION 03.00.00.00 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 short credits consumption list : Services OFFLINE S1 v1,v2,S1 OPEN AID 004,FLASHMODE activation Services ONLINE A1 phones unlock/repair 03 credits S1 OPEN unlock/repair 03 credits A2 phones, CSCA way unlock/repair 03 credits W100,W150 unlock codes 01 credits S1 v2 alternative bypass unlock/repair 01 credits ST21,ST21i2,ST23 alternative bypass unlock 01 credits ST26,C150x,C160x alternative bypass unlock 01 credits S1 v2 alternative bypass STANDALONE activation 10 credits You CAN NOT unlock next phones without S1 server: u1/u5/u8 with loader AID 004, LoCosto,Neptune-based phones with damaged security zone, LoCosto,Neptune-based phones with loader AID 004, w100,w150 full unlock,ck13,ck15,wt13, any SONY phone, released from 2012 year,except ST21,ST21i2,ST23,ST26,C150x,C160x phones current updater version: 0.95 current setool2 version: 1.1403 SERVER CREDITS LEFT/USED: 11/19 CARD COUNTERS: FLASH 193, UNLOCK 45 Elapsed: 6 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_BOOT VER "R10D030" ACTIVE_COMP_AID : 0002 HWCONF_AID : 0002 LOADER_AID : 0002 BOOT_AID : 0002 DEVICE ID: E89A37F8423A57929E FLASH ID: "0003/00000015" LOADER VERSION: "R5D030" PHONE IMEI : 3555 Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1520] REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED WARMING UP ... CHECKING ROOT ACCESS ... PROCESSING ... C1504 [e090449b] FINALIZING ... Unlock DONE Elapsed: 143 secs. phone should b rooted ADB Driver should b installed antivirus turned OFF u'll loose credit if stopped in mid-way i lost one also | |
11-25-2013, 09:42 | #9 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | 1. phone should not be rooted, setool2 will handle everything. 2. you will not lose credit in any way. any subsequent operations with this phone will be free, so feel free to stop process in any step. |
The Following User Says Thank You to the_laser For This Useful Post: |
11-26-2013, 19:59 | #13 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Ukraine
Member: 260346 Status: Offline Thanks Meter: 4 | Please help me PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_BOOT VER "R10D030" ACTIVE_COMP_AID : 0002 HWCONF_AID : 0002 LOADER_AID : 0002 BOOT_AID : 0002 DEVICE ID: 12AB0E1482672275F4B1FA3F4E24C3544540774B FLASH ID: "0003/00000015" LOADER VERSION: "R5D030" PHONE IMEI : 35742105253669 MODEL (from GDFS): C1505 SOFTWARE VERSION: 1267-9537_11.3.A.2.23 CUSTOM VERSION: 1279-9996_R2E FILESYSTEM VERSION: WORLD-i_11.3.A.2.23 Network LOCK : 26801-* MINOR ERROR [ read_TA_unit_fail, err: 0013 ] Elapsed: 10 secs. Last edited by Death Rider; 11-26-2013 at 20:09. |
11-27-2013, 17:40 | #14 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Poland
Member: 1704846 Status: Offline Sonork: 1617108 Thanks Meter: 117 | Read this http://forum.gsmhosting.com/vbb/9893144-post938.html and unlock phone (1 credits). Error not to worry |
The Following User Says Thank You to koperta4512 For This Useful Post: |
