03-16-2010, 13:31 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Noise City
Member: 889564 Status: Offline Thanks Meter: 336 | >>>C905 Strange problem<<< Code: RUNNING v0.915062/UNI CARD SERIAL ******* USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:E800,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35760202279714] OTP LOCKED:1 CID:52 PAF:1 IMEI:35760202279714 CERT:RED LDR:2009-04-21 18:29 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A081 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2009-04-21 18:30 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A081 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA writing "D:\SonyEricsson\SETOOL\FLASHES\C905\R1FA035_APP_SW_1205_9079_GENERIC_SI_REDBROWNBLUE_CID53_52_49_DB3210.software" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:53Will flash 871 blocks... flash address (802F0000) not accepted,error:3B Elapsed: 35 secs. |
03-16-2010, 14:22 | #6 (permalink) |
Member: 889564 Status: Offline Thanks Meter: 336 | When I remove the main file and flash the set only with language pack,the flashing is ok-I mean no errors...Ofcourse the set is not alright at all...Where is the problem... |
03-17-2010, 09:36 | #10 (permalink) | |
Member: 889564 Status: Offline Thanks Meter: 336 | Quote:
After rehoting flash ic,I thought that it might be something from the latest version,so I tried with some of the old,but nothing again...In fact my logs here are from old version,cause after this came the part when i decide to ask for help here... | |
Strange characters (Answered) | JACKSON999 | MXKEY Blackberry Flasher and Unlocker (by Alim Hape) | 7 | 04-02-2010 00:23 |
I8510 strang problem | naslejavan | QUALCOMM Models (3G) | 4 | 03-30-2010 09:32 |
n95 (rm-159) strang problem | Tayyab_raja777 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 14:45 |
>>>ust Pro 2 Install Problem<<< | REMO | UST Pro II | 2 | 09-23-2007 07:33 |
>>>activation problem<<< | keaelite | UST Pro II | 24 | 06-10-2007 04:54 |
