04-12-2018, 19:34 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | canīt unlock j132. CANīT FIND SIMLOCK CHECK Code: SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY ... RUNNING S1_EROM VER "R5A038" EROM_AID : 0001 LOADER_AID : 0002 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 SIMLOCK STATE: "NOT TAMPERED" FLASH ID: "0020/88C0" LOADER VERSION: "R3A011" PHONE IMEI : 351588036xxxxx GOT SEED:85380BE18501301AC2007A35 P96 AUTH PASSED Searching ... CAN'T FIND SIMLOCK CHECK Unlock FAILED Elapsed: 57 secs. Any hint please? |
04-18-2018, 14:40 | #3 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | tried with latest version Flashed different versions from support Still get the same error. Plus the phone is now Bootloop. Also: with some firmwares, If I tick unlock when flashing, it does the process well, but phone keeps showing Insert Correct sim card screen |
04-18-2018, 16:46 | #5 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | checked first firmware, which was nearby : R1AA029 patch found fine, patch values in place flash firmware files Code: R1AA029_1211_2311_MAIN_LE_RED.software R1AA029_1211_1798_CENTRAL_EUROPE_MID_LE_RED.software R9A_J132_CDA_1213_3136__FS__Sony_Ericsson.software make sure you selected J132 as model, this is extremely important patch is tested on countless phones, so i'm sure that it is working. |
The Following User Says Thank You to the_laser For This Useful Post: |
04-18-2018, 17:55 | #6 (permalink) | |
Member: 220595 Status: Offline Thanks Meter: 355 | Quote:
will download the other 2, and will try then will comment back. | |
04-18-2018, 19:18 | #7 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | NO WAY Code: RUNNING v 1.1433/01.15/UNI CARD SERIAL 0013XXXX USBFLASH DRIVER VERSION 03.01.00.00 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110100000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY ... RUNNING S1_EROM VER "R5A038" EROM_AID : 0001 LOADER_AID : 0002 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 SIMLOCK STATE: "NOT TAMPERED" [ llcomm: 00001000,00080000 ] DEVICE ID: 0501301AC2007A350000000055480000 FLASH ID: "0020/88C0" LOADER VERSION: R3A011 PHONE IMEI : 35158803681314 GOT SEED: 8F7BBB8E8501301AC2007A35 P96 AUTH PASSED writing "A:\tmp\j132\R1AA029_1211_2311_MAIN_LE_RED.software" writing "A:\tmp\j132\R1AA029_1211_1798_CENTRAL_EUROPE_MID_LE_RED.software" writing "A:\tmp\j132\R9A_J132_CDA_1213_3136__FS__Sony_Ericsson.software" FINALIZING ... TOTAL CALL TIME RESET Searching ... SIMLOCK CHECK FOUND Writing ... USERLOCK RESET TO "0000" Elapsed: 233 seconds what else to write/test? Last edited by yurais; 04-18-2018 at 19:25. Reason: Added Setool version Log |
04-18-2018, 19:22 | #8 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | And... if after phone is flashed. I try to unlock again, then Get the so much hated message: Cant find Simlock Code: SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110110000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY ... RUNNING S1_EROM VER "R5A038" EROM_AID : 0001 LOADER_AID : 0002 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 SIMLOCK STATE: "NOT TAMPERED" [ llcomm: 00001000,00080000 ] DEVICE ID: 0501301AC2007A350000000055480000 FLASH ID: "0020/88C0" LOADER VERSION: R3A011 PHONE IMEI : 35158803681314 GOT SEED: 54FE18398501301AC2007A35 P96 AUTH PASSED Searching ... CAN'T FIND SIMLOCK CHECK Unlock FAILED Elapsed: 48 seconds |
04-19-2018, 16:21 | #9 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,150 | it is NORMAL and EXPECTED that you have this message AFTER you flashed phone with enabled "unlock phone during flash" options. alas, if phone not accept sim card after patch unlock, it is clear sign that phone have damaged security units ( most probably, cleared out simlock unit ) - and it can not be unlocked by patch unlock. |
04-19-2018, 17:26 | #10 (permalink) | |
I cant know,phone was brought to me as is for unlock. dont know teh story. so, there is no way to FIX this I guess, unless S1 servers are back? | |
