03-12-2013, 23:17 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Age: 46
Member: 152445 Status: Offline Thanks Meter: 16 | Can't create sd card Searching microSD disk... MicroSD disk found: Volume: H:\ Device: \\.\PhysicalDrive3 Label: XTCGOLDCARD Size: 506822656 Writing image to microSD disk... Can't read sector: 2048 from PhysicalDrive Can't write to Physical SD Disk! Please close all other applications and try again. Action cancelled |
03-13-2013, 00:39 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ~Lemuria~
Member: 942693 Status: Offline Sonork: 1592619 Thanks Meter: 2,204 | Hi! Try with another sd reader. Also check memory and not less than 2 Gb size. just inserting the SDcard and hitting Ok at the same time, for some reason if insert the SDcard and let it inside for some seconds LGTool sometimes not able able to write correctly to the SDcard. Ps: No use SD HC Card Best Regards |
03-13-2013, 03:46 | #3 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: *VODAFONE UK* Store Age: 31
Member: 1082892 Status: Offline Sonork: 100.1585374 Thanks Meter: 412 | Quote:
i hav mep0 9900 but need help i creat sd card all is ok but when i put sd card in fone then not detect qualqom driver etc,, plz solve problem how it work,, thanks 69 eyes.. br | |
03-13-2013, 04:05 | #4 (permalink) |
Member: 942693 Status: Offline Sonork: 1592619 Thanks Meter: 2,204 | Hello Friend: The problem is in the power supply to the sd card. Check if the 3 volt sd card needs are properly soldered. Also check that the wires are not shorted to each Best Regards |
03-13-2013, 04:09 | #5 (permalink) | |
br | |
03-13-2013, 07:42 | #10 (permalink) |
Freak Poster Join Date: Dec 2010 Location: Nigeria
Member: 1458806 Status: Offline Sonork: 100.16235306 Thanks Meter: 6 | i cant create sd card. here is d log. what am i doing wrong LGE Tool version: 2.07 Free space on disk D:\: 2.00 GB Free space on disk E:\: 1.00 GB Connecting with 9850 Searching microSD disk... MicroSD disk found: Volume: G:\ Device: \\.\PhysicalDrive2 Label: Size: 3956801536 Writing image to microSD disk... Can't get handle on PhysicalDrive Can't write to Physical SD Disk! Please close all other applications and try again. Action cancelled |
