10-30-2008, 08:23 | #1 (permalink) |
Banned Join Date: Jan 2008
Member: 692226 Status: Offline Thanks Meter: 19 | Check It!v0.95 a: you need setool2 version >=v0.95 for that. 1. go to a2 tab 2. select correct model, that is important. 3. go to settings tab. 4. mark "use signed mode" , "use alternative security bypass" 5. go back to a2 tab 6. set "retail" domain 7. press unlock 8. follow program instructions 9. your phone is converted to "retail" state. you do not need credits for that procedure. q: how to unlock/repair a2 phone (db3000,db3150,db3210) using altbypass option? what problems can i encounter and how to avoid them ? how many credits i need ? a: you need setool2 version >=v0.95 for that. first, you can repair ANY software problems for currently released A2 phones. for that, you need to do several simple steps: 1. go to a2 tab 2. select correct model, that is important. 3. go to settings tab. 4. mark "use signed mode" , "use alternative security bypass", "unlock after flash" 5. go back to a2 tab 6. set desired domain ("retail" is best choice) 7. if you want to flash phone, add neccessary firmwares to firmware area and select correct custpack 8. if you selected firmwares, press flash, otherwise press unlock. 9. follow program instructions 10. your phone is repaired and unlocked (and flashed) you need 0.01 credit per phone if phone has unknown/retail domain (?). if phone is totally damaged (foreign trim area), you required to write gdfs package from normal phone and make unlock again. q: What is filemanager ? how to run it? why i can't read files ? a: you need setool2 version >=v0.914042 for that. filemanager is visual tool to play with files. create script (text files) with one string Code: fsManager: and select it in misc edit, then press "write script" button. note ! you can check only "signed mode", it will run filemanager fast, but you will not be able to read files, only write. in order to read files, you need: for db2000,db2010 phones <= cid49 - uncheck ALL settings for db2010,db2020,pnx5230 phones <= cid53 - check "use signed mode","use alternative security bypass", "use preloader security bypass" for a2 phones (db3150,db3210) <=cid52 - "use signed mode", "use alternative security bypass" and set domain to "r&d" or "factory" to rename file/directory press F2 or select "rename" from popup menu to delete file/directory press DEL or select "delete" from popup menu note, that directory should be empty in order to delete it. to write file/directory, drag-and-drop it from windows explorer to desired directory on phone. to read file/directory press F5 or select "read" from popup menu. note, that files/directory will be save to %setool2%\ph_out directory,existing files overwriting without notice. q: i want to service j132 phone, but it not have fastport connector, only minuUSB. what to do ? a: you need setool2 version >=v0.914042 for that. you should create connector yourself: select either ufs or com modification (pinout discovered by rockerdongle team) please note, that if you will create cable with 3 pins only, you should manually press power on button on phone when program displays "powering..." q: for curiosity i have flashed ROM image in my lg ku580/kf75x/kt52x. phone goes dead. i unlocked it and it came back to life, but i have no network. what to do ? a: you need setool2 version >=v0.95 for that. you need write gdfs package from working phone. just select correct model, add to misc. edit gdfs package and press "write gdfs". q: i can not connect lg ku580/lg75x/kt52x/sagem my805c to setool2 with supplied USB cable. phone simple turns on and setool2 don't recognize it. a: you need setool2 version >=v0.95 for that. you should use special service usb cable. pinout and conversion of supplied cable to "service" is attached (will be attached) or you can buy ready cable somewhere (will be filled) |
10-31-2008, 07:36 | #3 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Pakistan Age: 36
Member: 447849 Status: Offline Sonork: 100.1604076 Thanks Meter: 593 | when laser will release this version when we will check it anywayzz thanks for the information i think almost all of the member already knew that... B.R., Sonu |
11-01-2008, 13:13 | #4 (permalink) |
Member: 447849 Status: Offline Sonork: 100.1604076 Thanks Meter: 593 | you can download new version of setool which is support all A2 unlock by patch and more.... v0.915016 - updated phone model names - updated bypass packages - minor and major bugfixes - added script command for visual filesystem manipulating. - added support for j132 ODM SEMC phone - added support for unlock/repair/domain change of ALL CURRENT SEMC A2 phones (cid49,51,52) solution is standalone. please FULLY read THIS POST - added support for flash/fstools/unlock/repair of LG EMP-based phones, at the moment ku580/kf75x/kt52x (cid54) are supported. - added support for flash/fstools/unlock/repair of SAGEM EMP-based phones, at the moment my850c (cid60) is supported. rapidshare link HERE happy HALLOWEEN. download link http://rs501.rapidshare.com/files/15.../v0.915016.rar B.R., Sonu |
11-01-2008, 16:08 | #6 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Icosium
Member: 392373 Status: Offline Sonork: 100.1575353 Thanks Meter: 75 | try this one http://www.************/ftp/v0.915016.rar |
11-01-2008, 16:14 | #7 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Slovakia VT
Member: 59529 Status: Offline Thanks Meter: 115 | v0.915016 - updated phone model names - updated bypass packages - minor and major bugfixes - added script command for visual filesystem manipulating. - added support for j132 ODM SEMC phone - added support for unlock/repair/domain change of ALL CURRENT SEMC A2 phones (cid49,51,52) solution is standalone. please FULLY read THIS POST - added support for flash/fstools/unlock/repair of LG EMP-based phones, at the moment ku580/kf75x/kt52x (cid54) are supported. - added support for flash/fstools/unlock/repair of SAGEM EMP-based phones, at the moment my850c (cid60) is supported. rapidshare link HERE happy HALLOWEEN. http://rapidshare.com/files/159360435/v0.915016.rar WARNING. DUE SOME REASONS (HEHE) I BROKE K850 REPAIR, PHONES WILL BECAME 5-LOCKS AFTER BYPASS OPERATION. ATTACHED HOTFIX, ONLY FOR THOSE,WHO ALREADY DOWNLOADED 0.915016 RELEASE. IF HOTFIX REFUSING TO INSTALL, YOU DO NOT NEED IT. http://rapidshare.com/files/15956049...850_HOTFIX.rar |
The Following User Says Thank You to gsmpuky For This Useful Post: |
Bluetooth File Transfer OBEX FTP v0.95 (BETA) | mehedi.h.j | Nokia Multimedia | 0 | 08-27-2008 19:13 |
need 1x prl downloader v0.95 | yenni_khristina | Various CDMA/TDMA Cell Phones | 0 | 11-24-2006 05:52 |
I was trying this passord. It is incorrect. Please check it give another:eek: | gsm.ru | Phone Unlocking Codes & Maps | 0 | 11-01-2002 13:06 |
GD35/75/95 Check it out!!! | source | Panasonic | 6 | 09-23-2002 15:03 |
